Forum Index > Historical Arms Talk > Warhammer beak or hammer, when ? Reply to topic
PostPosted: Sat 08 Dec, 2007 10:08 pm    Post subject: Warhammer beak or hammer, when ?         Reply with quote
I have the A & A warhammer and the beak is rather short of fat diamond section and not of the very slim and long ones that might find uses in hooking armour or deep penetration against lightly armoured foes.
http://www.arms-n-armor.com/view.html?pole005a.jpg
Now my question would be: Against someone in full armour when would one favour using the hammer side and when the beak side ? Is one better for striking at the plate or better aimed between plates ( chinks in the armour )
Use of the point ( dag ? ) is sort of a third option in an armpit or under a visor if one has the opportunity to thrust or range of movement in a press make a wide swing impossible.
So: What are the merits of hammer side versus beak side ? Assuming one had time to choose, as both seem as they would do about the same amount of damage ?
Concussive damage with the hammer followed by a focussed carefully aimed piercing by the beak ?
This might vary depending on the design of a specific warhammer or the longer poleaxe
Hugh Knight
Reading list: 34 books
PostPosted: Sat 08 Dec, 2007 10:25 pm    Post subject:         Reply with quote
In all the Fechtbücher I've seen the one-handed warhammer is shown only once, in Talhoffer's 1459 Alte Armatur und Ringkunst:
http://base.kb.dk/pls/hsk_web/hsk_vis.side?p_...p_lang=eng
and that's obviously unarmored, so it has little relevence.
I can say, however, that I've made a special study of the pollaxe, and with the pollaxe, the hammer head is the only surface used for striking. The spike on the back is used only to hook, never to strike. While the specific reason for this is never explicitly stated in any book, I believe from the context that it's because the hook, as pointed as it is, is far too likely to slip when it hits plate whereas the teeth on the hammer face are designed to "grip" the metal to transmit the maximum force of the blow into the target.
Hugh
www.schlachtschule.org
PostPosted: Sat 08 Dec, 2007 10:59 pm    Post subject:         Reply with quote
I can see the hooking with the much longer and slimmer spikes and have no reason to disagree.
Specifically with the short spike of the A & A I was sort of wondering already how useful for hooking the short spike can be ?
1) It could be there mostly just to counterbalance the hammer.
2) Against an un-armoured opponent or an un-armoured body part the spike would be nasty ! But then so would be the hammer. Eek!
3) The top spike as well as the two side spikes would at least be useful again against the un-armoured.
4) If used against a body part only protected by maille the back spike would concentrate the force on one point and not risk slipping as it might on plate.
The period documented uses of warhammers do seem light in quantity though to be 100% certain about the use of the spike, although it does seem that hooking is the only use shown.
So, we may be forced to speculate or just " guess " since the sources are so limited: There might be other schools of use in period that used the spike in some special situations for other things than hooking but we just don't have that information to support any theories?
Sort of frustrating have to accept that the back spike was just used for hooking, even if true: I just hate short debates. Wink Laughing Out Loud
This could be a record for arriving at a final conclusion and a really short Topic. Laughing Out Loud
Greyson Brown
Reading list: 15 books
PostPosted: Sun 09 Dec, 2007 12:34 am    Post subject:         Reply with quote
Based on a barbute in the Germanisches National Museum, Nuremburg, I am inclined to say that the spike was used for more than just hooking. That does not mean that it was the "proper" way to do things, but it seems it still happened.
I think sometimes we get too wrapped up in fechtbuchen. They are mostly prescriptive (meaning they talk about how things should be done), not descriptive (in this case, meaning they talk about how things are done). Don't get me wrong, I have nothing against fechtbuchen, but just because they don't mention something doesn't mean it never happened.
-Grey
 Attachment: 27.67 KB
Einar Drønnesund
PostPosted: Sun 09 Dec, 2007 3:25 am    Post subject:         Reply with quote
-Grey
Not only that, but I doubt that the manuals contain ALL of the effective techniques of any given weapon.
PostPosted: Sun 09 Dec, 2007 4:26 am    Post subject:         Reply with quote
-Grey
From the damage one can conclude at least in this one case that the spike/ beak ( or BEC in French ) can hole plate.
One could object that the damage to this barbute might not have been caused during a fight or even in period ? Maybe someone a couple of centuries ago tried the BEC of a warhammer on this specific barbute. ( just playing devil's advocate ).
On the other hand the damage is real no matter how and when it was done.
One " speculation " is that in a battle one's weapon could get the beak stuck in the plate and effectively disarm one !? So the hammer side might be preferred ?
Battle use versus duel use might be somewhat different, as well as armour used: Against plate might be different, the hammer side may be the best, but how about maille, a jack or brigantine ? The bec might be good in tearing these last apart.
Armour coverage would vary more on a battlefield and opponent wouldn't always be evenly matched i.e. full plate man-at-arms against another full plate man-at-arms: Optimum usage might vary ?
Look at it like any tool giving you choices, example: A ball peen hammer. If I'm using it to drive a nail using the ball part is stupid and much harder to do, but the ball part is there for a reason or we would not bother to make this type of hammer.
So the bec serves a purpose ( hooking ) or other purposes in specific cases that we are not 100% sure about or even sure if they were rare or common exceptions to the hooking use.
For my part I do want to explore " possibilities " for other uses even if we cannot in the end make statements of fact.
Ivo Malz
PostPosted: Sun 09 Dec, 2007 4:44 am    Post subject:         Reply with quote
In the press of hand to hand combat you can´t absolutely accurately use a weapon. Not as in your fechtbuch "user´s manual".
Whichever side of your warhammer you use, you have its sheer mass plus a dangerous device at two sides which gives you a chance to hurt, cripple or kill your opponent, or just stun him and win a second to place your next blow more effectively. A warhammer is not just a beak and a hammer face or axe blade.
It is technically a mace "with extras". Even if you can´t manage the proper angle to use the "extras" efficiently, you can always land a massive blunt impact.
Ivo
Bob Burns
Reading list: 112 books
PostPosted: Sun 09 Dec, 2007 6:24 am    Post subject:         Reply with quote
In a fight or man to man (face to face) armed battle, you (hypothetical) are going into a Nightmare. Anyone going into battle, armed or unarmed with a choreographed plan will find himself half dead or dead, those seconds that are used by a fighter or a warrior whether in a street fight or in a 13th century battle with a bludgeon, are the precious seconds that can and often will determine life or death! This is why "muscle memory" is taught, and this is learned only by practicing with a particular weapon repeatedly, over and over and over, until it becomes instinct.
A warrior should also have keen instincts to read his opponents body mechanics by means of watching the shoulders and hips, stance, relative distance, whether the opponents body is balance 50 / 50, 70 forward 30 back, etc. These should all be instinctive, because there is no time to "think"!
I am sure the Roman gladiators trained in these things for hours, day in and day out, just as a modern day boxer, karate fighter, UFC fighter, so it would be the same for a swordsman, samurai, man at arms, knight, foot soldier, etc.
In a medieval battle, you are trying to kill your opponent and your opponent is trying to kill you, there are no rules of engagement, it's kill or be killed and that second or two seconds a warrior spends to think out his next move could well be his death sentence Exclamation
So it would seem obvious to me that any part of the business end of a warhammer (incidently I have the same warhammer as Jean and a Windlass warhammer too). Whether it be the hammerhead, back hook, side spikes or the top spike.
This is why for instance in karate, a person training with a nunchuku will practice any of the numerous strikes, blocks, trappings, etc. over and over and over again, until each and every movement is muscle memory and instinct. So I would think it would be the same principle whether the weapon be a sword, warhammer, poleaxe, halberd, spear, etc.
Also, practice drills against friendly opponents would be done repeatedly so that each warrior could develop the instinct to read his opponents body position, distance, balance, etc. So that when he went into battle in the real thing, he would have developed all the necessary instincts and muscle memory of his particular weapon or weapons against a variety of weapons.
I am not a medieval weapons expert but I did earn a black belt in karate from Keith Hackney of UFC Fame and a former Navy SEAL in October of 2004.
Well, this is what makes sense to me.
Bob
Ben C.
PostPosted: Sun 09 Dec, 2007 10:42 am    Post subject:         Reply with quote
I'd have to disagree with this somewhat. I've done boxing, muay thai, judo and Brazilian jujutsu and have competed in around 2 dozen amateur bouts (hoping to try some professional MMA at some stage), not to mention a number of out of the ring altercations in my younger (i.e. stupider days). I'm by no means an expert but what I've learned is that thinking, planning and anticipating are an important part of fighting. Of course a lot of the stuff we train and do is done on instinct; slipping a punch or knowing when someone is open for a shot or submission needs to be done with split second timing. However being able to think two moves ahead and constantly surprising your opponent is a major factor in being both a good counter or attacking fighter. Experienced competitors are always thinking and almost always know what they want to do in advance. When things don't go to plan instincts often have to take over but both sides are important for a successful fighter.
To an inexperienced eye boxing, kickboxing, MMA and grappling matches often look like the fighters are just attacking wildly without thinking but this is not the case more often than not. There really is a lot of tactics/strategy to it and I'm sure medieval combat wasn't a lot different in this regard.
Hugh Knight
PostPosted: Sun 09 Dec, 2007 10:51 am    Post subject:         Reply with quote
I could drive nails with a wrench, too, in an emergency, but that doesn't mean that's what it's *for*.
Hugh
Allen W
PostPosted: Sun 09 Dec, 2007 11:09 am    Post subject:         Reply with quote
While I tend to agree that to much weight is given to fechtbucher, it is worth noting that almost every encounter the French poleaxe manual "Le Jeu Della Hache"(certainly misspelled as I haven't seen my copy in years) ends with the bec (in this manual referred to as bec-de-faucon rather than bec-de-corbin) wedged into the opponent's eyeslit from which his head is levered to the ground. I have yet to read of an armoured pole axe duel ending in death and personally tend to view it as a sporting tool, at least in the bec-de-corbin/faucon form.
Bill Grandy
Reading list: 43 books
PostPosted: Sun 09 Dec, 2007 1:51 pm    Post subject:         Reply with quote
Despite the fact that I consider the fencing treatises our Rosetta Stone into historical combat, I agree with you. Happy Fencing manuscripts are invaluable direct resources, but (sadly) they don't tell us everything, and I think outside evidence (such as this wonderful photo you have of this helmet) needs to used in conjunction. I once had a guy tell me that leg cuts were never used in medieval swordplay, despite the Wisby finds. Happy
Well, the Thott has some examples:
HistoricalHandcrafts.com
Bob Burns
PostPosted: Sun 09 Dec, 2007 4:20 pm    Post subject:         Reply with quote
To answer Ben Condon, one scenario is a referee controlled sport fight, wherein yes you can go in there with a strategy and think as your grappling or clinching. But this has No relation to a real life street fight, medieval battle or any other true life situation of life or death with an opponent, meanwhile when the chaos of melee is all around you and at any second you could be attacked by a comrade of your enemy opponent.
In this situation, one must react with instinct, muscle memory, but this is not the situation where you have the luxury of planning your strategy. There are arrows flying, swords hitting shields, warhammers banging into helms, limbs plopping off of bodies, horrendous screams of terror and pain.
This is not the boxing ring, UFC cage or any other sport fight. This is war, life or death and seconds are precious!
I also heard this same analogy in a seminar I attended that was taught by Joe Lewis the former full contact "karate" heavyweight champion of the world in the late 60s and early 70s, the seminar was in November of 2001.
Joe Lewis world karate champion, not to be confused with Joe Louis the former world heavyweight boxing champ.
Attached is a photo of me with Joe Lewis in November of 2001 at Hackney's Combat Academy, so as to show who
Joe Lewis is, for those not familiar with him.
Sincerely,
Bob
 Attachment: 36.18 KB
Hugh Knight
PostPosted: Sun 09 Dec, 2007 7:36 pm    Post subject:         Reply with quote
Then you are very much mistaken. First, I am not aware of any techniques in Le Jeu de La Hache which end with the Bec stuck in your opponent's Occularium, to lever or otherwise. You use the Bec to hook the neck, the shaft of your opponent's axe, and his knee, but never the Occularium. Second, as Bill showed, the pollaxe was a lethal weapon designed for combat; that it was also popular in more sportive events reflects the desire of medieval knights to perform manly deeds rather than implying anything about its relative lethality. Just as one small example to the contrary, the pollaxe was a very popular knightly weapon in the battles of the Wars of the Roses.
Nor was the hammer and Bec form of the pollaxe any less lethal; indeed, there's little evidence for striking with the axe blade of a pollaxe even in the axe and Bec configuration: even there the Mail (hammer) was still the preferred striking weapon as can be seen in Codex 11093, the only 15th-century fechtbuch to show this sort of pollaxe.
The Fechtbücher were not, in general, directed toward sportive combat. Le Jeu is one of the few exceptions, containing techniques for both sportive and lethal combats (or, more correctly, implying finishes to specific techniques that could be more or less lethal as the wielder required), however most German Fechtbücher were entirely concerned with Kampffechten, or lethal combat.
And Bill, while I agree with you that the Fechtbücher should not be considered the final authority on all medieval combat, in this case they represent all we're likely to find out.
Hugh
Ryan Moody
PostPosted: Sun 09 Dec, 2007 8:45 pm    Post subject:         Reply with quote
I don't have any experience with a hammer against a steel target, but as a student of geology I've had ample experience with a hammer against rock outcrop, and I found that you get much more "bang for your buck" with the broad hammer side than the point. I would guess that against a hard target like a man in plate armour and/or a helm one would use a similar strategy, as it would send some pretty nasty shockwaves into the soft bits inside. You could use the beak against plate, but it would probably do quite a bit more damage to the armour than the man inside. On the other hand, if you managed to get the beak into a seam in the armour and pry it apart it would leave a pretty big opening for your next strike.
This is just a hypothesis, but I would suggest the beak would be more for use against lighter armoured opponents, like someone in maille. With the combination of maille and the padding underneath, the impact from the blunt hammer side would be lessened by the 'give' of the armour. If you used the beak, you might penetrate further into the man, maybe even through the links, and have a greater chance of snapping bones.
View user's profile Send private message Send e-mail MSN Messenger
Gregg Sobocinski
Likes: 5 pages
Reading list: 12 books
PostPosted: Sun 09 Dec, 2007 8:58 pm    Post subject:         Reply with quote
As a huge fan of the bec de corbin and the war hammer, I'm pleased to see it depicted often-enough in large battle scenes in later medieval period art. Unfortunately, I don't collect those images, but checking the direction of the hammers in these types of work should give you a most basic answer.
I'll try to poke around and look for an example or two. This one here is too crude to determine a definitive direction.
http://www.myArmoury.com/view.html?features/p...trai08.jpg
Would the spike be used on the neck after stunning an opponent, similar to the way this fellow is doing-in the green-garbed knight with his rondel dagger?
http://www.myArmoury.com/view.html?features/p...recy06.jpg
In addition, Alexi Goranov's review of a Higgins Armory pole axe mentions, "...poleaxes were also used on the battlefield, as revealed by period art. This is further supported by recent archeological finds and forensic investigations of skeletal remains associated with medieval battles." I'm assuming that triangle-shaped punctures would be the forensic evidence mentioned, but I guess you could email Alexi and ask.
http://www.myArmoury.com/feature_higgins_pole.html
Personally, I wonder why almost all surviving examples I've seen are either the 2 foot/60cm variety, or the 5 foot or longer bec de corbin/Lucern hammer variety with very little in-between. Since intermediate sized swords and axes have always had their proponents, why don't we see a longer (~3ft) hammer more often, which would offer more reach in combat, and could be used one or two handed? For those of you who've acquired a war hammer, does it seem short to you, or 'just right'?
Perhaps in extremely close combat, getting inside the reach of longer weapons may have been a reasonable strategy with heavily armored knights.
PostPosted: Sun 09 Dec, 2007 10:14 pm    Post subject:         Reply with quote
First Ryan: thanks for your post and I basically agree with it. The comment below are not a rebuttal but just additional speculations. Cool
Maybe that prying apart could count as a form of hooking ?
With the hammer part I don't think anyone seriously disagrees that it was the most important most used part of the design, it's with the beak that we can ask questions:
1) For only hooking. ( Historically documented default position: Only use we can prove ! )
2) Mostly hooking and a little wedging into gaps in armour which might expose targets or distort/displace the armour in ways that would restrict an opponents mobility i.e. bents or half torn off armour bit being annoying at the least. Wink
3) Against the right target used for piercing. ( Armour type as suggested above as a possibility ).
Even if not ideal or even considered very bad technique in period one might use the pointy bits on a warhammer instead of the hammer if there was no time to readjusts one grip or weapon orientation in the middle of a melee ? A blow with the beak, even if not as good as with the hammer, would still be dangerous if it connected !
Design question: If the hammer was much more useful than the beak why not design the warhammer with a double hammer head ? I'm sure one could still design the hammer heads in a way that some hooking could be done ?
But, not as well as with a beak I guess.
At the very least, if hooking is almost the only reason for the beak then it follows that the use of the beak in hooking was/is design-wise as important as the hammer !? The beak setting up opportunities to use the hammer, maybe ?
Since double hammers seem to be rarer or non-existent I assume that the combination hammer/beak is a better design.
Oh, someone did mention that with the warhammer and it's multiple points ( A & A version ) one has a mace with options and specialities, but all parts of the head could be used to strike even if there was the much preferred use of the hammer.
Hugh Knight
PostPosted: Sun 09 Dec, 2007 10:43 pm    Post subject:         Reply with quote
In fact, they made those: They're called maces. <grin>
They also made them as pollaxes; I have a picture of a very rare form of pollaxe with two hammers.
Woah! We haven't reached the conclusion that the beak on a warhammer was only used for hooking: All we've proven is that's all we have evidence *for*. Those two ideas aren't the same, not at all. I tried to draw a parallel with pollaxes, but that's not a perfect match, not by a long shot, it's just an indication.
I will say this, however: Punching plate isn't easy. That square hole in the helmet above could have been done by a siege crossbow with several hundreds of pounds of draw or by an Ahlspiess; there's no indication is was done with a war hammer. Of course, one-handed weapons got extra impetus on horseback from the motion of the horse; we know this from Dom Duarte's treatise, at least as far as arming swords go, but I think it's no stretch to extend that to the war hammer, and that might explain its use.
Still, while it's possible to punch plate, I think it's unlikely enough that it's not a good fighting strategy, if that makes sense. Conversely, if you look at how much emphasis some Fechtbücher place on grappling on horseback, it's no great reach to think that pulling someone off of his horse might be a great tactic.
Remember, too, that people are *far* to fixated on the use of weapons to overcome armor. The evidence from the Fechtbücher, again, suggests that your best bet in armored combat is to go tro grappling and dagger combat; indeed, von Danzig tells us that most Harnischfechten comes down to that. That's not directly applicable, because, excepting the picture from Talhoffer I posted above (which, remember, shows an unarmored encounter) and one picture from Freydahl (which isn't a realistic depiction of combat) I, personally, tend to think of warhammers as *mounted* weapons.
Hugh
PostPosted: Sun 09 Dec, 2007 11:19 pm    Post subject:         Reply with quote
Woah! We haven't reached the conclusion that the beak on a warhammer was only used for hooking: All we've proven is that's all we have evidence *for*. Those two ideas aren't the same, not at all. I tried to draw a parallel with poleaxes, but that's not a perfect match, not by a long shot, it's just an indication.
Ah, I apologize I may have interpreted your previous posts as meaning that hooking was the only use or 99.9 % of the time.
The distinction you make about " evidence " or lack of, and what we do know is a precise one: Maybe I was trying too hard to respect your views while still speculation about the other possible uses. ( Walking on eggs or bending over backwards to be respectful. Wink Cool )
Warhammer as a mostly mounted weapon makes sense as it's mostly a short one handed version of a poleaxe ? The horseman's axe by A & A comes to mind. http://www.arms-n-armor.com/pole006.html But then that brings up the question of the hook combined with axe instead of hammer head ......... Same function as with a hammer ? Probably yes. Semi sharp axe with strong concussive effect ? ( Hammer equivalent or very different design intent ? ).
Hugh Knight
PostPosted: Mon 10 Dec, 2007 12:56 am    Post subject:         Reply with quote
As to mounted use, by the 15th century (and I don't see many war hammers from prior to that period; the hammer is largely a function of combat against plate) practically all one-handed weapons used in war were either used by lightly-armored support troops (e.g., archers with an arming sword and buckler) or were used on horseback; in foot combat men at arms (meaning anyone who had a full harness) tended to use two-handed weapons.
I haven't studied the use of one-handed axes in the iconography so I can't speak to that, but if Dom Duarte felt that the motion of a horse added enough impetus to make an arming sword useful against men at arms, then it seems to follow that the same would be true for a one-handed axe.
Hugh
