Etienne Hamel
Posted: Fri 29 Jun, 2007 11:49 am Post subject: what weapon is the easier to make? |
I was wondering if the mace is good for a first project and what is the others weapons is easy to make?
Iknow it look like an open ended question but i need to know.
Posted: Fri 29 Jun, 2007 11:57 am Post subject: |
I'd go for a godendag first. That's just a tapered pine haft, a short length of iron or steel pipe, a steel disk, a short length of square-section steel rod and a nail for a rivet. A little filing, a little drilling, a little hammering. No welding needed. Should be much easier than all the steel cutting and welding you'd have to do for, say, a flanged mace. Plus, the godendag is expected to look rather crude.
If you can find a blade, a rondel dagger is quite easy to make, too.
Kenton Spaulding
Posted: Fri 29 Jun, 2007 12:33 pm Post subject: |
Just to expand a little bit on what Sean was saying about the Rondel. I had a bayonet for an old musket which would have made a very nice looking Rondel dagger in my opinion, without a terrible amount off effort. You can get a similar blade here if you are interested http://www.fcsutler.com/fcbayonets.asp
Good luck,
Kenton
George Hill
Posted: Fri 29 Jun, 2007 6:54 pm Post subject: Re: what weapon is the easier to make? |
Etienne Hamel wrote: | I was wondering if the mace is good for a first project and what is the others weapons is easy to make?
Iknow it look like an open ended question but i need to know. |
IF you are willing to make a mace from any culture... you can get a rock, drill a hole in it, and put a shaft in the hole. Instant mace. And a very popular item in some parts of the world.
Richard Eskite
Posted: Fri 29 Jun, 2007 7:56 pm Post subject: You can have a lot of fun with... |
a sling. Two leather boot laces and a scrap for a pouch and you can be flinging rocks with the best of them. I used to use mine to throw tennis balls for my dog.
Matthew D
Posted: Fri 29 Jun, 2007 9:15 pm Post subject: |
slings are great, I made them as a kid to have something to mess with when I was out checking the cows. Also a quarter staff would be an easy and effective one to make..
Posted: Sat 30 Jun, 2007 1:27 am Post subject: |
A club. Or a primitive spear--just a pointed stick with a fire-hardened tip. You can't get any simpler than that.
Stephen Murray
Posted: Sat 30 Jun, 2007 1:04 pm Post subject: |
Kenton Spaulding wrote: | Just to expand a little bit on what Sean was saying about the Rondel. I had a bayonet for an old musket which would have made a very nice looking Rondel dagger in my opinion, without a terrible amount off effort. You can get a similar blade here if you are interested http://www.fcsutler.com/fcbayonets.asp
Good luck,
Kenton |
In fact, Eric Meulemans did a very nice job of converting a bayonet into a rondel dagger, as described in this thread: http://www.myArmoury.com/talk/viewtopic.php?t...hlight=sks
C. Stackhouse
Posted: Wed 04 Jul, 2007 3:21 pm Post subject: |
How simple do you want and what sorts of materials/facilities do you have access to??
There are a lot of different things you can make. Don't expect it to be professional quality but they are functional and you can make them with common things found in hardware stores.
Above all else, be armed
-Niccolo Machiavelli
Gavin Kisebach
Posted: Wed 04 Jul, 2007 3:33 pm Post subject: |
It depends on the tools an materials you have available. I assume from your question you have a way of shaping metal with fire?
Christopher Finneman
Posted: Wed 04 Jul, 2007 11:07 pm Post subject: |
All yah need is a wooden rod or dowel a larger dowel and a metal band times 5 and lastley a chain or leather cord and you got yoursef a nice flail.
Proudly it stands until the worlds end. The victorious banner of love.
C. Stackhouse
Posted: Thu 05 Jul, 2007 5:48 am Post subject: |
You should be careful when making flails though. Weapons like that are illegal in some places.
But as long as you don't run down the street swinging it around your head. You should be fine.
Shawn Shaw
Posted: Thu 05 Jul, 2007 6:42 am Post subject: |
When I was a kid, I made a flail out of wooden dowel, a piece of chain, and a corquet ball. :-) It was for a school project back before something like that would have had me expelled.
Etienne Hamel
Posted: Fri 06 Jul, 2007 8:25 am Post subject: |
i did one with a shovel haft the only thing that stuck the chain was some big staples i don't have a big budget so we do as we can.. it lasted almost a week .
C. Stackhouse
Posted: Sat 07 Jul, 2007 9:02 am Post subject: |
The easiest weapon I can think of making is a spear with a slotted head.
All you need is a long dowel, twine and a piece of 16-14 gage steel to cut a head out.
Cut a slot into one end of the dowel (make dam sure the slot doesn't go in on a slant)
Trace out a simple spear head design on the metal, and cut it out.
fix the head to the shaft with twine, and there you have it; a spear.
C. Stackhouse
Posted: Sat 07 Jul, 2007 9:25 am Post subject: |
Here is a simple layout of a spear idea.
You can use the side of a file to cut the notches into the metal. If you want precise lines, you will probably be able to get them cut at the place you buy the piece of sheet steel/ flat bar; it will be significantly easier on your hands than trying to cut it yourself.
If you decide to cut it by hand, get a hold of a cold chisel (a chisel used to cut metal when it hasn't been heated in a fire) This will either cut the steel or etch the lines and make it easier to cut with snips. (depending on how much you use said tool)
:::Note:::
After you hit the chisel, double check that you are lined up to your markings before you hit it again
Attachment: 24.2 KB
Etienne Hamel
Posted: Sat 07 Jul, 2007 9:41 am Post subject: |
it look some kind of primitive, but are you sure that it would be tough enough to resist a blow?
Posted: Sat 07 Jul, 2007 11:09 am Post subject: |
Ok last night I had free time to do this
I think they are called mourning stars, morning star. What have you.
Its a basic pole arm with metal bands and spikes welded to the bands and a center top spike.
What I did was found a nice dried piece of iron wood made it into a shaft about 5 foot and made the top wider than the bottom. Took a lil work but came out nicely.
C. Stackhouse
Posted: Sun 08 Jul, 2007 2:37 pm Post subject: |
Etienne Hamel wrote: | it look some kind of primitive, but are you sure that it would be tough enough to resist a blow? |
It is primitive. That is the kind of spear people made before they knew how to make socket-headed ones.
As to the durability, if you get some good, tough twine/thin rope and use one continuous piece to secure the head you should be fine.
I actually use this design for arrow heads, I haven't had a chance to adapt them into a spear; but they hold up really well when fired a half inch into wood.
I could also draw up a design for a socket head spear I've been fooling around with in my head if you want.
