Forum Index > Historical Arms Talk > Greyson Brown's ProjectsDIY Project Reply to topic
This is a standard topic Go to page Previous  1, 2, 3, 4
PostPosted: Thu 26 Apr, 2007 2:06 pm    Post subject:         Reply with quote
J. Bedell wrote:
Thanks for those shots Greyson! The bevel is obvious but it isn't ugly and certaintly doesn't affect the piece in any negative way. Excellent work! Eek!
If you do decide to part with it sometime, let me know! Laughing Out Loud Big Grin
-James
From the review I did of this sword (a sharpened version):
Greyson Brown
Reading list: 15 books
PostPosted: Thu 26 Apr, 2007 3:59 pm    Post subject:         Reply with quote
Thanks, Chad. Your lighting was slightly better, so it probably makes the bevel stand out a bit more. My bevel is perhaps slightly less obvious than it would be from Albion, but nothing to go bragging about. And Albion's work is more consistent than mine. Neither one, at lest in my opinion, has a huge effect on the appearance or affectiveness of the sword.
Robin Smith wrote:
Awesome job G... So when are you going professional? Laughing Out Loud
I'm always willing to entertain the possibility of this kind of work, be it grips, or scabbards, or what have you, but I haven't been serious enough about any of it to really go advertising myself, either. So to answer your question, when people ask me to, I guess.
-Grey
Greyson Brown
PostPosted: Mon 04 Jun, 2007 7:19 am    Post subject:         Reply with quote
I spent this weekend blacksmithing and working on scabbard projects. I started early on by burning myself pretty good, but that seems to have placated Murphy somehow, and the rest of my projects went fairly well.
I started by making a chape for my Steward scabbard. It is just a simple U shaped chape, and I left it with some of the pitting from the forge to give it a slightly rugged appearance. I'm happy with this one, though I possibly should have made the sides longer.
The next order of business was to make a buckle. Unfortunately, I have not done any blacksmithing in four years, and a well made buckle really requires that the ring be welded. This makes it stronger and avoids gaps that will interfer with the movement of the tongue. I never claimed to be an expert forge welder, but I used to be fairly comfortable with it. Having not kept up with it, though, I only had one successful weld out of three attempts. It's not a very pretty buckle in the end, but it works. Since the buckles were going to be for me, and not a customer, I decided not beat my head against the wall. One buckle is good enough for now (though I am still debating whether or not I will actually use it), and I will work more on buckle making in the near future.
I also made a chape for my Sherriff scabbard. It turned out fairly nice, and I set to work cleaning it up. I wanted to remove all of the pits, but in the proccess I filed through a portion on the front left side. The material I was using came from the local salvage place and was, I think, a piece of metal edging used in landscaping. Unfortunately, it had been sitting outside and had rather noticable rust pits. That, in addition to the material lost to scale and hammering, meant filing out all of the pits could be rather risky work. Still, I got most of them out and then welded a patch onto the spot that I filed through. In cleaning up my weld, I discovered that I still have several thin spots, so I decided to compromise and left several pits in the chape. I also had one thin spot on the edge of the chape that was causing me problems. I tried to do a little decorative file work to remove it (and mirrored it on the other side, of course), but I don't think it looks very good. The little point filed into the end was deliberate, was planned from the begining, and turned out decent, so I would say that I am about 75% happy with this chape.
That's all I got done on my scabbards this weekend, but at least I have a couple that are closer to completion.
-Grey
 Attachment: 67.16 KB
 Attachment: 58.99 KB
 Attachment: 55.04 KB
 Attachment: 15.98 KB
 Attachment: 60.99 KB
 Attachment: 58.55 KB
 Attachment: 52.83 KB
Greyson Brown
PostPosted: Mon 04 Jun, 2007 7:38 am    Post subject:         Reply with quote
Almost forgot! I also put a buckle on my 101 MI scabbard. This is just an economy buckle from Tandy Leather, so it's nothing really special, but this one is finally complete and wearable.
-Grey
 Attachment: 57.05 KB
Page 4 of 4 Reply to topic
Go to page Previous  1, 2, 3, 4 All times are GMT - 8 Hours
