Forum Index > Historical Arms Talk > Maille cuts Reply to topic
Manuel Gutierrez
PostPosted: Wed 01 Nov, 2017 2:07 pm    Post subject: Maille cuts         Reply with quote
Hello! I recently bought a hauberk but it hasnt any cuts in the skirt so it reduces my legs mobility a lot. My kit is from early middle ages so i thought in side cuts but i dont know if front/rear cuts are better in mobility terms. Which do you recommend?
Thanks!
Mart Shearer
PostPosted: Wed 01 Nov, 2017 5:29 pm    Post subject:         Reply with quote
You could do both.
http://manuscriptminiatures.com/4902/22557/
The biggest issue is that the body of most of the Indian-made mail is a tube, with no expansions over the hips. If you look at miniatures and effigies, you might notice that the slit tends to be rather small, and doesn't run to the groin as many reenactors hauberks do. To maintain mobility and minimize or eliminate the slit, the mail must be expanded over the hips.
Philip Dyer
PostPosted: Wed 01 Nov, 2017 7:14 pm    Post subject:         Reply with quote
Mart Shearer wrote:
You could do both.
So it sorta is pushed upwards on horseback? Because I know the Warriors in the bayed tapestry had crotch high slits , it is not ahistorical. I could seen that would be detrimental in foot combat because you have less mail to potentiall save from sower to the crotch or inner thigh.
PostPosted: Wed 01 Nov, 2017 7:59 pm    Post subject:         Reply with quote
The Bayeux Tapestry is pretty crude. We can't infer those kinds of details from it
