Forum Index > Makers and Manufacturers Talk > circa 1600 sword breaker Reply to topic
Leo Todeschini
(3 total ▮ 100% positive)
PostPosted: Thu 01 Aug, 2013 1:38 pm    Post subject: circa 1600 sword breaker         Reply with quote
Hi All,
I have just finished this sword breaker based on a composite of pieces from around 1600 and I hope you like the result.
This style of knife came in at the end of the 16thC and lasted perhaps as late as the mid 17th and were used defensively to trap an opponents blade and take control of it and they do this very well. When a blade enters the void between the teeth, a pull or a twist will catch the and hold the blade. Whether they truly did 'break blades' I am not so sure, but they certainly do work.
They were not a very common form of knife and perhaps this was ether because they were bulky or expensive to make or indeed deemed to not be very useful however they are certainly very striking. The teeth were either fixed like this example or were articulated and must have been very much more expensive. They do look inherently weak, but this is partially offset by a thick blade with very little distal taper.
This example has a 6.5mm/ 1/4" thick blade, 275mm long/11.5" and has a steel guard and pommel with a steel and bronze wrapped grip with steel turks heads top and bottom.
 Attachment: 162.58 KB
 Attachment: 136.76 KB
 Attachment: 137.38 KB
 Attachment: 185.41 KB
 Attachment: 170.86 KB
 Attachment: 146.27 KB
www.todsworkshop.com
www.todcutler.com
Boris Bedrosov
PostPosted: Thu 01 Aug, 2013 1:51 pm    Post subject: Re: circa 1600 sword breaker         Reply with quote
Leo Todeschini wrote:
...... and I hope you like the result.......
Of course, we like it - excellent masterpiece as usual.
When I saw the pictures, but before reading your text, a couple of questions rose in my mind. Just a bit latter I saw you've answered to all of them.
For now, I have just one, purely technological question - how the ring is attached to the guard? It seems that the easiest way are integral pins, riveted at the other side, but there could be (in my opinion) at least a couple of other ways.
Of course, I hope this is not a craftsman's secret!
Tokugawa Ieyasu
Find my works on Facebook:
Boris Bedrosov's Armoury
Patrick Kelly
(6 total ▮ 100% positive)
PostPosted: Thu 01 Aug, 2013 4:39 pm    Post subject:         Reply with quote
Outstanding work. I have a particular fondness for these daggers and yours is a beautiful rendition.
Mark Moore
PostPosted: Thu 01 Aug, 2013 8:45 pm    Post subject:         Reply with quote
I guess you know....Down here in Texas, we call that a saw-back Bowie knife..... Razz .......Just kidding! Fantastic work! Laughing Out Loud ...McM
Marik C.S.
PostPosted: Thu 01 Aug, 2013 10:00 pm    Post subject:         Reply with quote
You are a very bad person, now I want to see a 17th Century version of Rambo with such a knife Big Grin
That dagger is awesome, would it be honed to a full edge and completely sharpened seeing as it is mainly used for parrying and controlling the opponents blade?
Europe - Where the History comes from. - Eddie Izzard
View user's profile Send private message Visit poster's website ICQ Number
Patrick Kelly
PostPosted: Thu 01 Aug, 2013 11:42 pm    Post subject:         Reply with quote
Leo,
Where did you get the inspiration for the scabbard? I've never seen a photograph of a surviving specimen. I'd love to see one if you have it.
Leo Todeschini
PostPosted: Fri 02 Aug, 2013 12:04 am    Post subject:         Reply with quote
Thanks all for your comments - I really appreciate the kind words.
This is in fact a casting, but I made the master in steel as I often prefer to do this rather than wax if I am going this route. The master was fabricated with the arms and block forming one piece and the ring brazed on as a second. This is the normal method of construction.
I will have to disappoint you I am afraid. I also have never seen a scabbard for one of these, so this has to be conjecture. A chape on a clipped point looks weird if it is conical, so I tend to favour the form I have used here and you see this historically on falchions etc. The locket is a usual wrapped and soldered form and as this was for a lady I cheesily used the heart motif - fitting anyway, but perhaps more so because she asked for a 'feminine sword breaker' - if that is not a contradiction!
The decoration is acanthus leaf vines and that is a timeless motif. I made one of these knives 15 years ago and tried to use an all leather scabbard and it just tended to bind and didn't really work, so I chose a wood cored scabbard this time.
www.todcutler.com
Patrick Kelly
PostPosted: Fri 02 Aug, 2013 8:49 am    Post subject:         Reply with quote
Well, it's a beautiful piece of conjecture. I particularly like the decorative motif on the scabbard. I assume you use some kind of stamp to form the teeth? How challenging is that? It looks like there would be plenty of opportunity to muck it up and start over.
Boris Bedrosov
PostPosted: Sat 03 Aug, 2013 5:34 am    Post subject:         Reply with quote
OK!
I guessed about brazing as a variant, but didn't about casting.
Thanks for the answer!
Tokugawa Ieyasu
Leo Todeschini
PostPosted: Sun 04 Aug, 2013 9:47 am    Post subject:         Reply with quote
Thank you.
15 years ago I made one of these, by drilling and filing and it took days. I then hardened it and dropped it before tempering - snapped in half and `i swore a great deal. It was not particularly challenging, it just took a long time.
This time I profile cut the blade.
www.todcutler.com
Matt Corbin
PostPosted: Sat 14 Sep, 2013 10:52 am    Post subject:         Reply with quote
Hi Tod,
I know this reply is a little late, but that is absolutely stunning Eek! Very nicely done.
It looks quite a lot like this sword breaker from the Wallace Collection
http://www.wallacecollection.org/whatson/treasure/120
- R. Ewart Oakeshott
Leo Todeschini
PostPosted: Sun 15 Sep, 2013 7:32 am    Post subject:         Reply with quote
Hi Matt,
Yes this was a major source of inspiration, the two principle differences is that I made mine a little shorter and the grip is not spiral carved.
www.todcutler.com
Russ Ellis
PostPosted: Mon 16 Sep, 2013 5:37 am    Post subject:         Reply with quote
Nice work as always Leo. I've often thought that these sword breakers were evidence that even in the 16th and 17th century there were gadget guys that liked things that had a certain "cool" factor, along the same lines as those "trident" main gauches and a little later the dagger pistols.
TRITONWORKS Custom Scabbards
Lancelot Chan
PostPosted: Mon 16 Sep, 2013 6:05 am    Post subject:         Reply with quote
Hello! Nice work Leo! I'm wondering about the teeth. Wouldn't the points of the void area create stress riser and cause problem during heat treat? Or did you made those voids after heat treating the blade? I'm interested to know. Please let us know more about how you approached the heat treatment in prepare with the teeth. Thanks!
Leo Todeschini
PostPosted: Mon 16 Sep, 2013 11:46 am    Post subject:         Reply with quote
In this case the blade was profile cut from steel that was heat treated prior to being cut. However the last one I made was heat treated after the teeth were cut and it did not cause any problems. The cuts in the blade are all radiussed slightly rather than left sharp and this helps.
Thanks for the kind words.
www.todcutler.com
