Sjors B
Location: Zevenaar, The Netherlands Joined: 31 Aug 2011
Posted: Tue 20 Sep, 2011 4:38 am Post subject: Messer training |
As already said in the discussion about cuttlas techniques i am a member of a trainingsgroup that, among others, trains with langes messer.
Finding proper training material is however a big problem. We currently use wooden wasters or small shinai but they come with limits such as being unbendable, or bouncing to much.
Any suggestions on what we might use as training weapons?
i do know for example that there is a blacksmith that makes messer-shaped fechtfeders.
Thanks in advance
member of the langenort school for European martial arts in Nijmegen (NL)
http://www.historicalshows.com/
T. Arndt
Posted: Tue 20 Sep, 2011 4:49 am Post subject: |
I recently took Christian Tobler's introductory messer class at WMAW. There were a number of blunt steel messers there, as well as very nice synthetic (nylon?) ones. Unfortunately I don't recall who the maker was, I would recommend PMing Christian.
A HEMA Alliance Affiliate
Christopher Treichel
Posted: Tue 20 Sep, 2011 5:19 am Post subject: |
Last time I trained with Christian at ISMAC he was using the steel messer trainers from Albion. Scott at Darkwood is also working on a steel messer trainer.
Mike Capanelli
Posted: Tue 20 Sep, 2011 5:27 am Post subject: |
Christian uses the Albion Maestro line messer. He had two at a seminar I attended for Seloharr Staten Island. They handled great and while they were brand new I'd assume, judging from the quality of the other offerings in that line, they'll hold up great. If that's out of your budget you can either go to Arma Bohemia and order there's, an image of which is right here I'm pretty sure it's blunt by default but I'd check anyway and get them to round out that tip while your at it. Or you could wait for the Hanwei one that's coming out but I'm not sure they have a release date on that one yet. You can check it out right here
Winter is coming
Sean Manning
Posted: Tue 20 Sep, 2011 7:11 am Post subject: |
Arms & Armor is working on a messer blunt. I think I saw several in use at WMAW 2011 and handled one, but you would have to contact A&A to see if they are in full production yet.
Using a blunt steel arming sword is almost a possibility, since they are fairly similar weapons.
Sjors B
Posted: Tue 20 Sep, 2011 7:28 am Post subject: |
thanks for the heads-up everyone.
we tried training with steel messer in the past and they are great for practicing techniques but when you start sparring even blunt steel is considered to dangerous. Also there is a risk when you do drills at high speed.
Andreas Auer
Posted: Tue 20 Sep, 2011 7:54 am Post subject: |
have you tried these...?...http://www.trainingsschwerter.com/Training/Trainingswaffen/Alu/Langes-Messer-aus-Alu-Typ-Sparring.html....i use them and they are great....
Andreas
The secret is,
to keep that pointy end thingy away from you...
Mackenzie Cosens
T. Arndt
Posted: Tue 20 Sep, 2011 8:33 am Post subject: |
| Sjors B wrote: | thanks for the heads-up everyone.
we tried training with steel messer in the past and they are great for practicing techniques but when you start sparring even blunt steel is considered to dangerous. Also there is a risk when you do drills at high speed. |
I'm curious, what do you wear for protection during sparing?
Personally, I wear a thick gambeson, WTC gorget, hourglass gauntlets and a Windrose WMA helmet. I consider this good enough for mildly intense longsword and never considered it not being safe enough for blunt steel messer.
[Edit: Forgot about my gauntlets]
Johan Gemvik
Posted: Tue 20 Sep, 2011 8:49 am Post subject: |
The WMA helmets are a very good idea for hard messer training. So would torso protection, an athletics cup, metal or plastic greaves and gauntlets be too. Going true full force all out with a rebated steel great messer, similar to those Polish full on battles would probably require a proper full plate harness or equivalent to be decently safe like they use and my guess is that some injuries will still occur.
For lighter sparring you wouldn't need any of that of course, but that's something very different.
Sjors B
Posted: Tue 20 Sep, 2011 12:09 pm Post subject: |
| T. Arndt wrote: | | Sjors B wrote: | thanks for the heads-up everyone.
[Edit: Forgot about my gauntlets] |
for general sparring we use fencing masks, gambersons or fechtmeistersjacke, eskrima padding and different type of gloves (padded gloves to Lacross gloves). however, not everybody has, or can afford these sets so we are always looking for some middle way. Nylon wasters and feders often do the job, but they are hard to get in messer shape (except the aluminium ones, i'm checking those out now)
David Teague
Posted: Tue 20 Sep, 2011 3:21 pm Post subject: |
Answers... from WMAW 2011.
The follow companies have steel blunts in production:
Albion (Hits like a mule in free play)
Darkwood Armoury (Looks like it would hit like a mule in freeplay, lighter than the Albion )
Arms & Armour (Lightest of the bunch, freeplays well with proper gear)
CHT owns a set of Albion blunts that he did not bring to WMAW. He ended up buying a set by Arms & Armour at the event the first day. He had Jessica Finley & I use them for the demo bout at the feast. They played well even if we did not.
I'm the one that brought a bag of synthetic messers that one of my students made, for CHT's class as lenders (non production item)
I also had a few of the aluminum messers made by Walter Neubauer of Germany. He has a lighten model for fencing that is quite popular in Germany. His prices are quite fair. PM me for info. I think his base prices are about $250 US
It was nice to see such an offering of steel blunts at one event .It's becoming the golden age of messer. YAY!!!
Of everything I saw, held and used last weekend, I would buy the A&A one for $380 as a nice solo, drilling, freeplay weapon as they handle very nicely.
Plan on hand, forearm, neck, head protection with a padded coat (and control, control, control) for freeplay.
DT
Sean Manning
Posted: Tue 20 Sep, 2011 4:25 pm Post subject: |
| Sjors B wrote: | | for general sparring we use fencing masks, gambersons or fechtmeistersjacke, eskrima padding and different type of gloves (padded gloves to Lacross gloves). however, not everybody has, or can afford these sets so we are always looking for some middle way. Nylon wasters and feders often do the job, but they are hard to get in messer shape (except the aluminium ones, i'm checking those out now) |
Unfortunately, the better something is at simulating a sharp sword the more dangerous it is. The problem with wood, split bamboo, or nylon wasters is that they behave very differently from sharp steel in the cross (and wood is just as dangerous as a steel blunt). I have no experience with aluminum.
Personally, I chose to wait until I have enough skill and kit to spar safely with my chosen weapons; a few hundred hours of practice and $1,000 of kit aren't really very much.
Sjors B
Posted: Wed 21 Sep, 2011 12:09 am Post subject: |
I agree with you, my personal intention in Historical martial arts is quite the same. I dont mind investing time and money in my training, but there are also members who participate on a lower level (of skill, interest, investment etc.) and we want to offer them a chance to participate as well.
Christian Henry Tobler
Posted: Thu 22 Sep, 2011 5:01 am Post subject: |
Dear all,
As David said, the trainers in my class were the new Arms & Armor messers. They are nothing short of awesome. I was also impressed with Scott Wilson of Darkwood Armory's new messer trainers. Those are a little heavier, but handled extremely well too.
The Albions are lovely, and I love the two I own, but they're best suited for drilling and more controlled bouting.
Echoing, and perhaps augmenting, some of the safety gear suggestions, I'd say for the A&A's you'd need a gambeson or otherwise padded jacket, hard elbow protection (get some inexpensive steel elbows from Windrose), a reinforced fencing mask w/back of the head protection or, better yet, a Windrose Fiore bouting helmet, and good hand protection of some form. Oh, and of course, a cup.
That's all you need, along with discipline and control, to fight with this trainers.
All the best,
Christian
Order of Selohaar
Sa'ar Nudel
Posted: Thu 22 Sep, 2011 5:27 am Post subject: |
I just came back from the Czech Republic where I had met with Ing. Jiri Krondak of Fabri Armorum. He produces a vast array of arms & armor for a lot of groups all over europe and emphasize on safety and rigidity. While can make fine & sharp display or cutting weapons as I've seen, most of the products are plain (hence affordable for large numbers, as in fencing groups) and have very good price-to-quality ratio. Check his messers here: http://fabri-armorum.com/english/?id=tesaky.php
I handled both versions of #4, while the regular one is robust the "feather" version is considerabely lighter.
Sjors B
Posted: Thu 22 Sep, 2011 5:58 am Post subject: |
i'm familiar with Jiri's messer, fought with them myself often.
they are very fine on weigth and balance and still very strong
checking out his site now, for the first time in years, i like his new stuff
Mike Capanelli
Posted: Thu 22 Sep, 2011 9:34 am Post subject: |
Does anyone have a link to the A&A trainers? I can't find them on their site.
Winter is coming
Craig Johnson
Posted: Thu 22 Sep, 2011 11:23 am Post subject: Messer Trainers |
Hello
As Christian mentioned I am working on assembling a couple to take pictures of for the website as I did not get a chance to on the first group. Literally ran out the door to get to WMAW with weapons still warm from being worked on in my hand. Should have them up in a couple of days. They look quite similar to the ones I did for Bill Grandy pictured here with some slight changes and a lighter weight.
Best
Craig
