Forum Index > Historical Arms Talk > Peening on brazil nut pommels Reply to topic
Jeremy V. Krause
PostPosted: Tue 26 Feb, 2019 7:41 am    Post subject: Peening on brazil nut pommels         Quote
Hi everyone,
We don't always get a good look at the appearance of the peening on swords in photographs.
I am interested in what folks know about how the peening was finished in brazil nut (and tea cozy) pommels.
We see some reproductions (like Albion's) who seek to blend the peen-end into the pommel and others who leave the end of the peen.
I've even seen two high end makers reproducing the St. Maurice of Turin sword finish the peen differently when both are seemingly trying to faithfully recreate the original.
What was done historically? I am guessing both were but am not sure.
Thanks for your help!
Michael P. Smith
PostPosted: Tue 26 Feb, 2019 8:38 am    Post subject:         Quote
Do you mean blended, or fairly obvious? I mean, it seems clear that peen blocks were not used (at least not commonly).
The photos of brazil nut swords I have seem to show a smooth profile, but we aren't typically shown the peen. My guess is that blended would be most usual, but that's just based on examination of photos that do not show a proud peen.
Hopefully, someone fortunate enough to have inspected some in person can confirm or deny that.
Maciej K.
PostPosted: Wed 27 Feb, 2019 1:42 am    Post subject:         Quote
Mostly, on brasil nut pommels, we will find flattened and small ends, almost leveled with the surface of the pommel`s top.
However it will also depends on the smith`s style and the pommel shape.
We can say these types are peened flat, for the most of the cases and comparing with later pommels.
You can find many pictures showing this detail in web, incl. St Maurice from Turin sword.
Medieval Swords - www.artofswordmaking.com
Profile PM Website
Jeremy V. Krause
PostPosted: Wed 27 Feb, 2019 5:00 am    Post subject:         Quote
Hi Maciej
So you are saying we would not normally see a small “button” of the pommel end. It would have been blended into the surface of the pommel?
Maciej K.
PostPosted: Wed 27 Feb, 2019 9:14 am    Post subject:         Quote
It is not a rule, but for the most of them we will not see it.
check attachment please. that one is from MAAS, Australia, ca. 1050.
... and they mostly look like this.
 Attachment: 135.35 KB
Profile PM Website
Kai Lawson
PostPosted: Wed 27 Feb, 2019 8:09 pm    Post subject:         Quote
That’s a lovely pommel! Thank you for sharing that.
"And they crossed swords."
Andrew Gill
PostPosted: Thu 28 Feb, 2019 2:50 am    Post subject:         Quote
The historical examples which I've seen in person (in the Kelvingrove in Scotland, mostly) and the photos I've seen all had the peen "blended" - hammered or filed down to the point where it was nearly indistinguishable from the curve of the pommel (usually only distinguishable at all because of corrosion, in fact). There may be counter-examples that I'm not aware of, of course.
Jeremy V. Krause
PostPosted: Thu 28 Feb, 2019 1:21 pm    Post subject:         Quote
Thanks everyone,
It sounds like the consensus is that the peen was finished in such a way to make it largely indistinguishable from the rest of the pommel's surface.
This is good to know and may show that some manufacturers may be incorrectly finishing this detail.
Craig Peters
PostPosted: Thu 28 Feb, 2019 11:13 pm    Post subject:         Quote
Jeremy,
Here's a photo I took of a sword kept in the Germanisches Nationalmuseum in Nürnberg. You can see that the peen is not entirely flush, and the seam is visible.
 Attachment: 917.01 KB
Jeremy V. Krause
PostPosted: Fri 01 Mar, 2019 7:18 am    Post subject:         Quote
Thanks Craig,
So on the photo we see an example with a more visible seem so the finishing to the point of near invisibility must not be the hard and fast rule.
Thanks!
J.D. Crawford
PostPosted: Fri 01 Mar, 2019 1:28 pm    Post subject:         Quote
As discussed off-line with Jeremy, I also prefer the blended look whenever possible. But its hard to get craftsmen and artists to follow rules. I doubt that has changed since the first cave drawing.
Profile PM Website
Michael Harley
PostPosted: Sat 02 Mar, 2019 3:55 pm    Post subject:         Quote
Just to clarify, currently housed in the Museum of Applied Arts and Sciences in Australia, object number H6923, found in England.
Information is not knowledge, Knowledge is not wisdom, Wisdom is not truth - Frank Zappa
Profile PM Website
Craig Peters
PostPosted: Sat 02 Mar, 2019 9:11 pm    Post subject:         Quote
On some Brazil nut pommels, we see the tang protruding through the top of the pommel. Is this merely a result of age and degredation, with the pommel slipping down the tang? Or are there some instances of proto-peen block?
Daniel Parry
Reading list: 39 books
PostPosted: Sat 23 Mar, 2019 4:58 pm    Post subject:         Quote
The example I have. The peening is almost invisible but if you angle the light right, you can see a slight difference in the centre of the pommel that may be the peening end,
 Attachment: 78.33 KB
 Attachment: 63.99 KB
 Attachment: 78.04 KB
Craig Peters
PostPosted: Thu 30 May, 2019 9:10 pm    Post subject:         Quote
Here's another example of a sword that does not have a peen flush with the pommel, but instead slightly protrudes. You'll have to look closely to see it.
 Attachment: 9.4 KB
