Forum Index > Historical Arms Talk > Hilting a moat blade - SolingenDIY Project Reply to topic
Julien M
PostPosted: Sat 14 Mar, 2015 10:24 am    Post subject: Hilting a moat blade - Solingen         Quote
Starting a new project!
I've decided to go for a beautiful Spanish sword, from the National Archaeological Museum , Madrid , Spain, 15th century (according to the website).
Sword hilt with gold and copper enamels and cardinas work of interwoven cords . The knob is almost spherical and wearing a red coat with a fleur de lis and the inscription AVE MARIA , which is continuous with GRATIA FULL hawks and ORA PRO NOBIS in Gothic characters , and between cardinas in relief.
I have read that this sword is considered to be a type XII - but it looks like the sword lower end is of diamond section. Since I also have a knight and a squire/prince blade ready to mount, I was hesitant...until I snatched a Solingen.
You will (rightfully) argue that the Solingen is an elongated type XIV - however the blade fits the bill almost perfectly, as you can see on the picture below (at least as far as contours are concerned...I would not presume of the blade geometry). Let me know what you think.
In any case this project interest me because it involves wax carving and bronze cast...something I have been willing to try for a while. A year ago I did a mock up of the guard in balsa, after printing the hilt to size.
Then I made a plaster mold for it - then chopped chunks of that beautiful block of blue wax I had bought 5 years ago (yeah, I plan ahead!) and tried to melt these in a pan. This was taking ages, so 20 min in the microwave did the trick. I poured generously in the open mold - the wax cracked while drying in the middle...so I did it again and this time it worked. I've read that heating wax in such a brutal way will make it bubble, trapping air in the process - it did (as you can see from the pics, the little white dots). If anyone as a better way, I'm all hears. I hope this won't be problematic when trying to have a nice surface finish, or sculpt tiny details...even worse, be detrimental to the casting process.
I've made the tang slot. I like working wax, same as steel, just super fast and easy :)
I've reproduced the slight asymmetry of the guard. For a blade with perfect contours like an Albion, it might have been a mistake. I should have photoshoped/mirrored one half and go from there...We'll see if I manage to attenuate this when removing more material and thinning it down.
To be fair I'm not sure this will lead to anything at this point...will see how it goes. In any case, glad to work wax at last.
J
Kai Lawson
PostPosted: Sat 14 Mar, 2015 11:33 am    Post subject:         Quote
Love it--keep going! I really appreciate your project descriptions and photos. Very motivating!
"And they crossed swords."
Julien M
PostPosted: Sun 15 Mar, 2015 1:08 am    Post subject:         Quote
Refining the shape. All goes well, but as expected I struggle to accept the asymmetry of the quillons - I'll need to add material (solder, on one side to make it better. This could go wrong but I'll give it a go nonetheless.
Lukas MG
PostPosted: Sun 15 Mar, 2015 2:01 am    Post subject:         Quote
Great project. Having never worked with wax or casting, this is very interesting for me.
I would give the quillons a bit more distal taper, btw. Too bad there are no pics of the sword from other perspectives, that would be quite helpful.
Custom sword maker:
http://www.lukasmaestlegoer.com
Profile PM Website
Julien M
PostPosted: Sun 15 Mar, 2015 3:53 am    Post subject:         Quote
Hey lukas, sure yes, i m nowhere near done. I ve partially sorted the symetry issue by melting bits of wax adding material so that i can make both similar. A lot of unecessary work, but i am now starting to get a good feel for the material - all part of the learning curve :) then i will thin it further, then tackle the engraving. I love it, very suited work for an evening after a day in the office.
Rim Andries
PostPosted: Sun 15 Mar, 2015 7:13 am    Post subject:         Quote
Very interesting destination for a Solingen blade. I will follow your progress closely. Thank you for sharing your journey and bon voyage!
Sir Dreamin'
Jack Sutter
PostPosted: Sun 15 Mar, 2015 11:54 am    Post subject:         Quote
Well done sir! It's looking great so far!
I am in point of fact about to embark on a similar project myself, using a number of Albion moat blades which I acquired last year. I was wondering where you got your wax and plaster, and how satisfied you are with them as a material?
"To my mind, all good things come to a point....swords, for instance." -GK Chesterton.
Jack Sutter
PostPosted: Sun 15 Mar, 2015 11:56 am    Post subject:         Quote
Ah, goodness, I already have another question!
What sort of condition was your blade in when you got it? It's very nicely polished in your pictures, did you do this yourself? My blades all have varying levels of rust on them, and I haven't yet determined how best to clean them up.
Julien M
PostPosted: Mon 16 Mar, 2015 8:58 am    Post subject:         Quote
Hi Jack -
The blue wax I bought in a shop in London - but you can find some pretty much anywhere, starting on Amazon. Have a quick search for Blue Carving Wax and it won't be long before you find what you need. this for instance:
http://www.amazon.co.uk/Blue-Carving-Wax-Bloc...arving+Wax
Plaster I also got from amazon - it's Gedeo Resin Plaster.
Regarding the cleaning of the blade, the answer for your question is here:
http://www.myArmoury.com/talk/viewtopic.php?t...p;start=40
I would suggest using sandpaper (120 grit) in my case, on a piece of wood you can press down your blade with both hands. Place your blade on a raised piece of wood (I use a fence post (1"x1" thick), clamped with the blade on a table. Work with long strokes, use oil too. It's not long to clean up a blade with this technique, even a badly rusted one (talking surface rust here, not excavated type of rust :) )
hope this helps.
J
Jonathan Hopkins
PostPosted: Mon 16 Mar, 2015 9:49 am    Post subject:         Quote
Brilliant choice for a replica. I will watch this thread with great anticipation!
Justin H. Núñez
PostPosted: Mon 16 Mar, 2015 12:02 pm    Post subject:         Quote
That will be gorgeous!
Jack Sutter
PostPosted: Mon 16 Mar, 2015 8:43 pm    Post subject:         Quote
Hi Jack -
hope this helps.
J
Thank you sir! That's very helpful!
Leo Todeschini
PostPosted: Tue 17 Mar, 2015 12:15 am    Post subject:         Quote
Interesting project Julien and good work so far.
I look forward to this one.
www.todsworkshop.com
www.todcutler.com
Profile PM Website
J.D. Crawford
PostPosted: Tue 17 Mar, 2015 9:46 am    Post subject:         Quote
Julien, nice pick - I don't think I've every seen this sword before. Based on your past work you'll do it fine justice!
Looks like XVI to me and those other swords are borderline XII/XIV for what its worth. This blade interests me because it looks a lot like Solingen, and the similar English sword, and the XVI that I just had replicated by A&A: myArmoury.com/talk/viewtopic.php?t=30378
Could these blades have all been made in the same shop? The other 3 have W pommels but this one is obviously fancied up for a noble.
Do we have a firm date for this blade?
What is the length of the original blade?
What is the pattern on it? Is that cleaned corrosion or was something done to decorate it?
-JD
Profile PM Website
Julien M
PostPosted: Tue 17 Mar, 2015 11:47 am    Post subject:         Quote
Hi JD,
I have some documentation on this sword, in a book about Spanish arms and Armor on pdf...somewhere.
I agree it looks more like a type XVI to me. I will show the guard on my prince/squire blade too, as well as on the knight before I make a final decision on which blade I will mount the hilt on.
in the meantime, for basic stats, a screenshot of the museum site.
J
PostPosted: Wed 18 Mar, 2015 2:54 am    Post subject:         Quote
I can't really decide if this spanish sword has flat fuller or not. If it has, than its blade is really similar to yours XVI J.D.
Kai Lawson
PostPosted: Wed 18 Mar, 2015 2:27 pm    Post subject:         Quote
I definitely think that the distal end of the blade is a diamond cross section, and it almost looks as though the blade either had some flaring near the shoulders, or a short ricasso--the section of blade just past the cross looks somewhat duller, I think, when seen up close. My guess is that the shoulders flared a bit and over the working life of the sword, the portion of the blade nearest the guard was not sharpened as frequently as the rest of the blade.
I'll also throw in my 2 cents and say that I am going to vote for a rounded or mostly rounded fuller, based on the shadow sizes and the lettering on the blade
Jonathan Hodge
PostPosted: Mon 07 Dec, 2015 11:00 am    Post subject:         Quote
I'm resurrecting a bit here, but I'm just curious to see if you've achieved any more progress on this blade Julien. Thanks!
Julien M
PostPosted: Mon 07 Dec, 2015 2:16 pm    Post subject:         Quote
Hi Jonathan,
None at all unfortunately...I have not touched a sword for month, spending my free time on alcoves cabinets, wardrobes, laying floorboards and other DIY jobs around the house. I am planning to reward myself by making a bit of work on this one or another very soon :)
For this specific project, I'm not sure to continue with this blade (I've got a prince blade that may be a better choice) nor commit to lost wax but switch to 3D modeling/printing for the hilt. I have to train myself with blender, but I feel it's worth it, given what I've seen done in that department lately.
J
Jonathan Hodge
PostPosted: Tue 08 Dec, 2015 7:26 am    Post subject:         Quote
I understand the DIY house stuff - been busy there myself lately! I too have seen some pretty impressive 3D printed stuff as of late, and I've had my eye on some stuff from the Printed Armoury - https://printedarmoury.wordpress.com. Thanks for the update!
