Forum Index > Makers and Manufacturers Talk > An Attempt on Baselard: From an Old File to the Dagger Reply to topic
Boris Bedrosov
PostPosted: Mon 23 Dec, 2013 2:27 pm    Post subject: An Attempt on Baselard: From an Old File to the Dagger         Reply with quote
As I already have almost completely finished Rondel-dagger, it's quite normal to want to make the other four of the basic dagger types.
First the baselard was started. As there are several different styles exist, I stopped my attention on this one
Well, I like also the double-T design but now I was restrained by the piece of steel I had.
Let me tell some words about the steel. As the name of the thread implies, I'll use an old file for this project. This gives me some clue about its type - this should be U9, U10 or (unlikely, but plausible) - U12. All these are good tool steels, where U (from Russian word uglerod - Carbon) stands (quite obviously) for Carbon, while 9, 10 and 12 are the Carbon content in the steel (0,9%, 1,0% and 1,2% respectively).
And the work began......
The file with ground teeth and "sharpened" tip (actually, this was done some time ago)
First I wanted to lengthen the forward part of the future blade
Heating
and forging
and again, and again..... until I reached the length I wanted.
After that I lengthened the tang - the one I had was really very short. After some time I already had almost twice longer one
and had nothing more to do but to forge the cutting edges of the blade. Well, this tool steel is not the easiest one to work on, but I think I've done it.
Tokugawa Ieyasu
Find my works on Facebook:
Boris Bedrosov's Armoury
P Ullrich
PostPosted: Mon 23 Dec, 2013 2:43 pm    Post subject:         Reply with quote
Well done! Looks like a fun project
Boris Bedrosov
PostPosted: Fri 27 Dec, 2013 1:53 pm    Post subject:         Reply with quote
Today I made some good progress on both blades.
After some normalization the blade was stripped off from the black oxides; this was done by hand-drill and steel wire-brush
Also all excessive metal was removed by some minor cutting and grinding; and the shape and edges were made symetrical. I call all this proccess "calibration".
The rest of the work was simple grinding using a belt-grinder.
The blade after the first, initial pass with grit #40 - I have really A LOT black spots, dents and imperfections
On the belt-grinder again. This is the third pass with grit #40 - after it the blade was looking quite better.
And finally - the blade after the pass with grit #60
I still have some black spots, but far fewer. Actually, the only one that boders me is the spot in the area of the shoulders of the tang at the bottom - I think I won't be able to sand it completely without damiging the edge or altering the cross-section. Anyway - it will be a good hallmark of the hand-forging.
Tokugawa Ieyasu
Ian Hutchison
PostPosted: Fri 27 Dec, 2013 4:22 pm    Post subject:         Reply with quote
Very nice, Boris. I will be interested to see this one finished. I'm always surprised that you have multiple projects at the same time, all at a high standard, and I can barely manage one at a time!
Bjorn Hagstrom
Reading list: 8 books
PostPosted: Sat 28 Dec, 2013 6:17 am    Post subject:         Reply with quote
I love your posts, Boris! Please keep them coming Happy
And my all time favorite dagger is the baselard, so looking forward to see this one progress!
Richard Rohlin
PostPosted: Thu 02 Jan, 2014 12:31 pm    Post subject:         Reply with quote
Boris,
Once again, I am watching your posts with a mixture of jealousy and intense interest. Can't wait to see what you do with this one!
Radovan Geist
Likes: 5 pages
PostPosted: Tue 07 Jan, 2014 4:53 am    Post subject:         Reply with quote
a very promising beginning:)
I wouldn´t be too worried about those black spots, unless they are too deep. You can still polish them with iron brush, and little irregularity could even give the blade a feel of "authenticity" (but of course, that´s a matter of a personal preference).
I´m looking forward to updates.
Boris Bedrosov
PostPosted: Tue 07 Jan, 2014 5:16 am    Post subject:         Reply with quote
Well, actually I'm not quite worried by them - almost all will disappear when sanded.
And "yes" - the deepest could really give some touch of authenticity, something I really love.
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Tue 04 Feb, 2014 1:28 pm    Post subject:         Reply with quote
I haven't written any post for a long time - I'd got some other problems to deal with recently; and the work with both daggers was in a short-time hiatus, but I hope now I'm back again.
Well, the progress so far includes heat-treatment, sanding and polishing of the blade
* after the heat-treatment - the blade was stripped-off from black oxides
** results from the sanding - after grits #120, #220 and some stones and sanding paper up to #600 respectively
*** and the final result after polishing
Although quite lesser, my nemesis with this project - the great black spot/depresion near the shoulders of the tang, still remains. But as already discussed - it will be the hallmark, showing the hand-work.
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Tue 04 Feb, 2014 2:34 pm    Post subject:         Reply with quote
As I already have the blade finished, it's time to do some work on the hilt.
First, I cut two pieces of steel - 5 mm thick for the guard and 3 mm thick for the pommel; and cut the slots in them
After some bending and shaping I got the guard and pommel almost ready
And both plates after some initial sanding up to grit #120
Some test-fit - almost there, I just need the final, precise fitting of the guard
For the grip of this project I chose somewhat more ordinary wood - namely walnut. In this case it's exremely well dried - the tree has been cut down almost 20 years ago in 1996.
As the block was quite thick (6 cm) I needed to cut it alongside
in order to get a piece just one-third of this - 2 cm
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Sat 15 Feb, 2014 4:10 pm    Post subject:         Reply with quote
* this is the way I imagine the grip of the baselard
** and some time later, when it was cut
*** as I was not fully satisfied by the shape of the guard, it was re-worked with adding of two trapezoid pieces on both ends
**** the grip in place after it was drilled alongside and matching slot for the tang was cut in
Now I must fit well the grip to both guard and pommel before peening all details in one assembly.
Tokugawa Ieyasu
Kai Lawson
PostPosted: Sat 15 Feb, 2014 7:58 pm    Post subject:         Reply with quote
I love your WIP threads Mr. Bedrosov. They really inspire me to make more of my own stuff. The nice thing is, I can take similar materials and I have pictorial evidence of "what it can look like (if you do it right)"
"And they crossed swords."
Daniel Wallace
PostPosted: Sun 16 Feb, 2014 10:35 am    Post subject:         Reply with quote
can't wait to see this one finished
Boris Bedrosov
PostPosted: Sat 22 Feb, 2014 4:28 pm    Post subject:         Reply with quote
The fitting of this grip turned out to be an interesting adventure - regardless what I've done I always got some air between the wood and metal. Finally, with help of some really thin strips of brass (0.25 mm) and even more thinner black paper, I managed to fill these spaces and to assemble the grip
The presence of the wood seriously altered my work - I had no other choice but to peen the tang cold.
Although the tang was annealed well, it started to show some cracks when the work progressed. So, the last couple of milimeters were hot-peened. This was quite challenging job - quick, but powerful heating to bright red, followed by even quicker peening. The walnut was saved, only the epoxy between the wood and pommel showed some strong signs of burning.
The rivet block is again modified nut.
Finally, I added four pins - a couple on each side. These were made from ordinary nails, cut in two - the longer pieces with the nail-heads were placed near the middle, while the shorter ones are near the ends.
Tokugawa Ieyasu
Radovan Geist
Likes: 5 pages
PostPosted: Sun 23 Feb, 2014 10:39 pm    Post subject:         Reply with quote
Re: gaps between the wood and steel parts - don´t tell me about that: I was going through that nightmare this weekend, trying to fit handle on my Swiss short sword:) But you did much better! Nicely done, really.
Boris Bedrosov
PostPosted: Sun 02 Mar, 2014 3:38 pm    Post subject:         Reply with quote
Recently, the baselard had some close encounter with the belt-grinder Laughing Out Loud
My aim here was to straighten the wood from the guard to pommel, in order to prepare it for shaping of the handle. All the curves were filed to their final shape and all excessive wood - removed.
Additionally, a couple of small but nasty cracks in the walnut I've got, were filled with epoxy.
Tokugawa Ieyasu
Kai Lawson
PostPosted: Sun 02 Mar, 2014 5:26 pm    Post subject:         Reply with quote
What's your secret sir--long years of experience? Did you just eat your vegetables? Do you have powers? All your projects look great, and I know I learn loads just following them. You must be learning every day!
Radovan Geist
Likes: 5 pages
PostPosted: Mon 03 Mar, 2014 6:44 am    Post subject:         Reply with quote
that´s really neat:)
i cant wait for the final result
Boris Bedrosov
PostPosted: Tue 04 Mar, 2014 5:54 pm    Post subject:         Reply with quote
I don't think, there are some special secrets or powers - just work.
And actually, I don't consider myself some master - in my eyes, my works look somewhat childish, compared with the trully masterpieces, created by such people as Peter Johnsson, Leo Todeshini, Michael Pikula, Owen Bush ..... (just stopping, I don't want to miss someone I'm really learning from).
And, please, don't call me "Sir" or "Mr." anymore - OK? Wink
Just "Boris" is really absolutelly enough.
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Wed 05 Mar, 2014 1:18 pm    Post subject:         Reply with quote
I rounded the corners of the grip and made another pass on the belt-grinder with #120. After that I handled this dagger as a real weapon for the very first time
Honestly, I'm not quite sure if this should be the correct cross-section of the grip - I shaped it in a way I felt it best for my personal taste.
Tokugawa Ieyasu
