Forum Index > Historical Arms Talk > Attaching a Spring Catch or Pin to Helmet Reply to topic
Chris Mann
PostPosted: Wed 03 Aug, 2011 10:18 pm    Post subject: Attaching a Spring Catch or Pin to Helmet         Reply with quote
Hey guys, I have GDFB Sallet and I was concerned about the inability to either keep the visor raised or kept in the down position. I was thinking of solutions and the only thing that I could think of was to add either a spring pin or catch to the helmet but I was wondering if any of you out there have either done this yourself or know of someone who has with success? It would be much appreciated. Thank you
Michael B.
PostPosted: Wed 03 Aug, 2011 11:42 pm    Post subject:         Reply with quote
This is the latch on my sallet. The latch is beveled to the visor can slip down, there's a this piece of steel that connects to the "button" to release the latch. It works great and can actually undo it myself when wearing all my steel. I could drum of some more photos tomorrow night if you'd like.
www.bearmountainforge.com
Michael Bergstrom
Chris Mann
PostPosted: Thu 04 Aug, 2011 12:14 am    Post subject:         Reply with quote
ya, I would really appreciate more pics. I'm gonna be doing it myself most likely and that way seems to be the most common. I really appreciate it
PostPosted: Thu 04 Aug, 2011 3:42 am    Post subject:         Reply with quote
i made one for my own gdfb project: http://www.myArmoury.com/talk/viewtopic.php?t...light=gdfb
Colt Reeves
PostPosted: Thu 04 Aug, 2011 6:22 am    Post subject:         Reply with quote
I think I know what is being done, but could someone post a picture of the catch inside the helmet so I know how it works for sure?
"Tears are for the craven, prayers are for the clown.
Halters for the silly neck that cannot keep a crown.
As my loss is grievous, so my hope is small.
For Iron, Cold Iron, must be master of men all..."
-Cold Iron, Rudyard Kipling
PostPosted: Thu 04 Aug, 2011 6:43 am    Post subject:         Reply with quote
Flat spring. Rivet at the back end, button in the middle, pin at the front end.
 Attachment: 50.42 KB
 Attachment: 199.37 KB
 Attachment: 159.82 KB
 Attachment: 181.23 KB
 Attachment: 139.93 KB
 Attachment: 173.26 KB
 Attachment: 73.12 KB
 Attachment: 54.24 KB
Michael B.
PostPosted: Thu 04 Aug, 2011 11:58 am    Post subject:         Reply with quote
The system in my helm:
Michael Bergstrom
Chris Mann
PostPosted: Thu 04 Aug, 2011 1:48 pm    Post subject:         Reply with quote
Wow, that really helps. Thank you. It looks like some nice work on your part, how long did it take you to complete, if I might ask?
Colt Reeves
PostPosted: Thu 04 Aug, 2011 8:00 pm    Post subject:         Reply with quote
Thanks guys. That's pretty much how I thought it was put together, but wanted to know for sure.
PostPosted: Fri 05 Aug, 2011 9:10 am    Post subject:         Reply with quote
I happened to have a sallet spring for my project. If you don't have one and don't want to make one from scratch you might experiment with a narrow saw blade. Seems like one should be able to just cut to length, grind the teeth flat and drill for the rivets/pins. No heat treatment needed.
PostPosted: Fri 05 Aug, 2011 8:50 pm    Post subject:         Reply with quote
Good idea since a mild steel one may have enough spring but can deform easily if overstressed and don't have much strength for a positive lockup.
I guessing you are thinking of a hacksaw blade cut to length.
Should be easy to shape using a dremel cut off wheel.
One could use a section and do a destructive test on it to see if it's too brittle or not ? If a bit too hard and brittle I would polish it bright and then put it on the electric element on my stove and heat it up until it turned blue: This should soften a hardened steel from 60 R.C. + down to the 45/50 R.C. of a spring temper.
Not very expensive to cut up a saw blade and experiment until one has the right amount of springiness versus hardness.
PostPosted: Sat 06 Aug, 2011 12:39 pm    Post subject:         Reply with quote
Appalachian folks made knives the same way, breaking blades out of worn or broken saw blades.
PostPosted: Sat 06 Aug, 2011 9:18 pm    Post subject:         Reply with quote
Used a file to make a long spear point a long time ago but since I didn't lower it's harness a bit, it broke on a wood stump when I tested it with a light tap. Cry The next one I put in the kitchen oven set at around 600 degrees F. for a while and let it cool slowly ! Anyway, a little trick to soften too hard steel without doing a full re-heat treat.
This was a long long time ago so I don't remember the exact technical details and I think I " chickened out " and didn't test that second spear point on the log. Wink Laughing Out Loud
I did do a full eat treat once in Shop Class too many decades ago to mention and we where shown how to control the hardness using the colour changes of the steel: A straw colour for very very hard ( 60/62 R.C. ) and deep blue for ( 52/55 R.C. )
The stove top trick or oven trick is to soften a too hard blade by heating it a bit higher than it was when originally tempered as a very hard file. Depending on the steel this might work well or cause stresses to the steel ? More knowledgeable people would have to give us their opinion on this and how successful or not it might be. Wink Big Grin Cool
