Ben Anbeek
Posted: Fri 14 Jan, 2011 11:13 am Post subject: DIY Sword scabbard and fittings |
Hi.
i'm new to the Industry Professionals.
and i want to show you some things i make.
so here is my first DIY project
ben
Attachment: 48.05 KB
drawings for the fittings
Attachment: 62.3 KB
sword beside the plained core
Attachment: 70.94 KB
last fitting before the plaining of the scabbard
Attachment: 76.44 KB
the bone glue
Attachment: 70.31 KB
glued the scabard core
Attachment: 63.79 KB
test fitting the sword
Attachment: 51.65 KB
chiseled out the core
Attachment: 59.97 KB
Medieval Goods
http://www.theupperclass.nl
www.facebook.com/TheUpperClass.nl
Isaac H.
Posted: Fri 14 Jan, 2011 7:39 pm Post subject: |
Very informative photos.I am also working on a scabbard right now,so it was fun to compare techniques.I'm using poplar for mine,what wood are you working with in the photos?I am also fascinated by your steel I-beam workbench.That's a cool idea,did you make it yourself?Your website was nice .Do you just make scabbards,or do you make other stuff as well ? (for "the upper class",of course )
Wounds of flesh a surgeons skill may heal...
But wounded honor is only cured with steel.
We who are strong ought to bear with the failings of the weak and not to please ourselves.
Each of us should please his neighbor for his good ,to build him up.
Romans 15:1-2
Ben Anbeek
Posted: Sat 15 Jan, 2011 1:12 am Post subject: |
Hi Isaac
The core is also poplar.
I made the I-beam bench it's one of my favorite tools.
It wont shift while plaining large poles.
i also make poleaxes and lucernhamers and planning on daggers and swords.
ben
Medieval Goods
Ben Anbeek
Posted: Sun 16 Jan, 2011 8:56 am Post subject: |
just finished the sewing of the scabbard.
it's sewed with a saddler's stitch starting about 5 cm from the point sewing it up to the throat.
then sew back the last 5cm to the point.
then cut down the seam just above the sewing line.
and iron it down with a hot ironing tool.
then burned my mark in it.
ben
Attachment: 65.88 KB
sewing the leather with a saddler's stitch
Attachment: 49.69 KB
Attachment: 63.91 KB
sewed the core
Attachment: 53.41 KB
trimed down the leather
Attachment: 74.46 KB
the seam needs to be trimed down even lower
Attachment: 47.84 KB
ironed the seam down and added the burnmark
Medieval Goods
Randy W
Posted: Sun 16 Jan, 2011 9:59 am Post subject: |
very nice work on your site ... simple and crisp
Randy Westgate
Dan R
Posted: Sun 16 Jan, 2011 5:13 pm Post subject: |
Hi Ben, I am fairly new to making scabbards but I haven't seen documentation for that sewing method on a sword scabbard before (I know it is used on knife sheaths). I was wondering if you had any docuementation as it its use on scabbards?
Thanks,
Dan
Ben Anbeek
Posted: Sun 16 Jan, 2011 9:55 pm Post subject: |
This is how all the medieval scabbards are sown up I have seen en have read about in the netherlands.
I have never seen one with a cross stitch on the back.
So this is how I make them.
Medieval Goods
Ben Anbeek
Posted: Sat 22 Jan, 2011 4:50 am Post subject: |
Brazing of the upper chape
I think the pictures are self explaining.
If you have questions pleas feel free to ask.
Attachment: 43.42 KB
brass sheet
Attachment: 65.07 KB
forming the brass
Attachment: 66.59 KB
formed
Attachment: 75.34 KB
brazed
Attachment: 55.4 KB
filled down
Attachment: 78.05 KB
Attachment: 90.39 KB
Attachment: 99.12 KB
Medieval Goods
Ben Anbeek
Ben Anbeek
Posted: Tue 01 Feb, 2011 1:11 pm Post subject: |
Hi made some procress today and here are the pictures of making the point.
Attachment: 61.89 KB
0.8mm brass sheat
Attachment: 73.94 KB
metal die for the point
Attachment: 71.21 KB
Attachment: 74.03 KB
forming the brass over the die
Attachment: 72.64 KB
cutting the brass on one side
Attachment: 71.2 KB
folding over the other side
Attachment: 71.16 KB
cutting the back with a 1mm cuttingdisc
Attachment: 70.06 KB
brazed and filed down
Medieval Goods
Ben Anbeek
Leo Todeschini
Ben Anbeek
Posted: Fri 04 Feb, 2011 12:19 pm Post subject: |
made the scallop for the point
it still needs some filing and polishing
Attachment: 70.05 KB
Attachment: 58.66 KB
Attachment: 62.81 KB
marked the scallop with black marker to have a better view at the lines i'm working on
Attachment: 76.16 KB
brazing
Attachment: 58.78 KB
still needs more filing and polishing
Medieval Goods
Julien M
Posted: Tue 18 Mar, 2014 9:23 am Post subject: |
How the hell did I miss that post. It's great work, and thanks for sharing such a detailed work in progress on making scabbard metal bits.
J
Ben Anbeek
Robin Smith
Posted: Tue 18 Mar, 2014 11:03 am Post subject: |
Oh this is great! I love how it starts out very humble, but the finished piece is magnificent. Very cool... I especially like the chape.
Jean-Carle Hudon
Posted: Wed 19 Mar, 2014 6:55 am Post subject: Nice work |
Thank you for that Mr Arbeek. Seeing the whole process like this helps to remind us to keep the final result in view as we go through all the preliminary steps. When you first posted the beginning of the work on the chapes, I must admit that I would not have predicted the final result, but you obviously knew where you were going all along. Nice work.
Bon coeur et bon bras
Posted: Wed 19 Mar, 2014 9:17 am Post subject: |
Very nice work and look forward to seeing some other of your other work like the poleaxes and lucerne hammers.
An in progress series of pics like this is very instructive and educational and one of the types of Topics I like best.
Ben Anbeek
Charles Neeley
Posted: Wed 11 Jun, 2014 7:00 pm Post subject: |
Perfect timing,
I'm about to start a new sheath for a long knife, this pictorial is giving me great suggestions, well done!
