Mike Harris
Posted: Wed 14 Nov, 2007 9:44 am Post subject: |
Thanks for giving me the heads-up Jonathan.
It has been, or at least seems like, quite a while since I wrote that review. The bit about the strong of the blade being commonly unsharpened was gleaned from the first Cold Steel video on the saber, with Lynn Thompson and Anthony DeLonghis. I can't recall the exact wording, but it led me to that conclusion. So, historical information it is certainly not. Just my blathering. :eek:
Regarding the durability of this particular sword, it is still just about as sound and tight as when I reviewed it. And the guard is definitely very solid and durable steel, based on some "brass knuckle-like" melee testing of close range punching. But I must confess that it hasn't seen a lot of strenuous use since then. I don't particularly care for its handling, much preferring a saber that's less blade-heavy. Since the review it has only been used for a little bottle cutting, one outing on tatami mats, and some testing on a fresh cow carcass where it startled me with its ability to make deep slicing cuts with practically no effort.
Jonathan Hopkins
Posted: Wed 14 Nov, 2007 9:58 am Post subject: |
Thanks, Mike.
Here is a quote on th e1796's cutting ability as cited in one of the articles I linked in my first post:
Charles Parquin of the French 20th Chasseurs wrote: | If, however, the edge of the blade found its mark only once, it was a terrible blow, and it was not unusual to see an arm cut clean from the body”. |
Jonathan
ADDED:
Matthew,
Here is another article that might be of interest to you as a hussar enthusiast: Cavalry Combat and the Sword
Matthew G.M. Korenkiewicz
![](images/avatars/147341168751ed961447aed.jpg)
Posted: Sun 18 Nov, 2007 12:03 pm Post subject: |
Jonathan Hopkins wrote: | Thanks, Mike.
Jonathan
ADDED:
Matthew,
Here is another article that might be of interest to you as a hussar enthusiast: Cavalry Combat and the Sword |
Thanks, Jonathan, I've seen that article ... here's a pic of a relatively recent replia of a Polish Hussar
Saber that I believe was once owned by Nathan Robinson of myArmoury ...
And another similar design of a Saber I once ALMOST had the oportunity to buy ...
This is the Saber type that I am hoping to have custom made in the near future ... in a way
the Cold Steel Saber is supplying some valuable info as plans are being made.
Jonathan Hopkins
Posted: Sun 18 Nov, 2007 12:14 pm Post subject: |
After completing that custom, then you really must get a Hungarian cavalry estoc. :D
Those are great pics of some very striking swords, Matthew--thanks for posting!
Jonathan
Posted: Sun 18 Nov, 2007 12:29 pm Post subject: |
... or maybe a Palash ??? B-)
Thomas Watt
![](images/avatars/150175579747932dae30251.gif)
Posted: Mon 26 Nov, 2007 3:20 pm Post subject: |
This blade had always been on my "want list" and when it appeared on Ryan's new items list over at KoA I couldn't resist.
Mine has the metal scabbard, and handle made of "something" which could either be a leather wrap over wood (it certainly mimics the original style well) or some other material. Blade is wicked gorgeous. Guard fittings are a little above so-so, but are really fine for the price range. I do notice the pin that was discussed earlier in this thread. And the pommel is finished out with a button that might be threaded or might be peened (I would bet threaded)... although if it loosens and is threaded, I expect that some of that thread lock gunk from the automotive store would cure that permanently.
I have an 1880 Imperial German NCO sword on the way which will make a nice match beside this, since its blade is somewhat between the 1796 and a U.S. cavalry saber.
It's time to get serious about a wall display!
Hanging this stuff by the scabbard from shelving is getting to be iffy.
Have 11 swords, 2 dirks, half a dozen tomahawks and 2 Jeeps - seem to be a magnet for more of all.
Posted: Mon 26 Nov, 2007 7:30 pm Post subject: |
Thomas Watt wrote: | This blade had always been on my "want list" and when it appeared on Ryan's new items list over at KoA I couldn't resist.
Hanging this stuff by the scabbard from shelving is getting to be iffy. |
It is an interestingly nice piece, isn't it ? Congrats on your purchase. B-)
Thomas Watt
Posted: Tue 27 Nov, 2007 2:27 am Post subject: |
After getting all the axle grease off this thing and finished getting everything all cleaned up, I have to note that the handle is after all a leather-wrapped grip. No question about it. I'm not sure what tanning process was used, as it doen't have the "sweet" smell of leather, but instead has a less-agreeable smell.
Feels really great in the hand.
Looking forward to building an X-type wall display (similar to those found in Scottish castles).
The metal scabbard that accompanies this thing is almost a weapon in its own right. Nice and beefy.
And thanks.
Yes, it's a nice "early" Christmas.
Posted: Wed 28 Nov, 2007 7:45 am Post subject: |
I had thought I was getting the metal scabbard too, but the leather w/metal is not at all displeasing.
While it might be made of less-historical bits and pieces, with something added for whatever the
reason ( the plastic insert that you can see looking into the mouth of the scabbard ), I have of late
thought about " scabbard care " along with blade care ... And I've come to the conclusion that the
least amount of metal bits and pieces to clean up the better ... But that's just me. B-)
Tim Harris
Posted: Wed 28 Nov, 2007 5:48 pm Post subject: |
Gentlemen,
Thank you for the excellent information in this thread.
As someone who's made a few 1796s, I only wish that I'd seen it a while ago.
Mine were done as blunts, which adds to the weight a bit, from specs from an original blade with what is probably a lighter variant hilt, if not a later replacement. The technical challenges in forging blades like this were considerable, given the radical distal taper (nearly Icnm accross the back of the blade at the hilt) and the deep concavity of the fuller.
It was an anxious wait for the blades to come back from the heat-treater, as architecture like this leaves plenty of scope for things to go wrong in my experience. Fortunately, there was no warping.
The last one required a scabbard, and I easily spent more hands-on time on that than I did on the sword itself. I am definitely not a scabbard-maker. What surprised me about the pictures posted here is that the scabbards appear a lot less narrow than the ones I've seen - mainly in auction catalogues. I was left wondering how something that looked so slimline accomodated the curvature of the blade and the splayed tip.
I will organise some pics as soon as I can. (Rod Walker, if you see this - I haven't forgotten you!)
Tim
Nonnumquam proctalgia
Jonathan Hopkins
Posted: Wed 28 Nov, 2007 6:15 pm Post subject: |
Tim,
I will try to get some measurements for the scabbard to my 1796 LC officer's sword. In the meantime, here are some basic measurements for the sword itself:
Blade: 32 ½”
Overall: 37 ¼”
Weight: 1 lb. 12 oz.
Jonathan
Posted: Wed 28 Nov, 2007 8:25 pm Post subject: |
I'd love to see pics of your work, Tim ... and frankly, as I've searched and searched
online for info about sabers I've often felt stumped by the fact that this particular sword
isn't discussed more often ( mind you, I don't traverse dozens of forums regularily, so
I AM kinda' generalizing ). Usually, or maybe it just seems this way to me, one forum
or another will focus on Japanese Style Swords, or European-style Broadswords.
Mind you, this is NOT a negative. Its just that -- unless I'm totally mistaken -- the saber,
as I've looked at so many things online, appears to have a pretty interesting pedigree,
a variety of blade profiles, cross-sections, and a genealogy that shoots all over Europe,
the middle-east, and crosses one ocean or maybe both to the USA ...
Thomas Watt
Posted: Thu 29 Nov, 2007 2:25 pm Post subject: |
Joe is just up the road from me (across the border in NH), and has a nice listing of things...
but I'm not always too sure about his identification, for instance, he identifies a Civil War era Musician's Sword as an NCO Sword, which it clearly is not.
Just a FWIW
Jonathan Hopkins
Posted: Thu 29 Nov, 2007 4:23 pm Post subject: |
Here are some more measurements as promised:
Sword:
Blade: 32 ½”
Overall: 37 ¼”
POB: ~6 1/4"
I do not have equipment to measure distal taper accurately, but it is quite drastic as the blade starts out at 3/8" thick at the shoulder and tapers to what is probably 1/16" or less. It is hard to discern the COP.
Scabbard:
Length: 33 3/4"
Width: 2"
Thickness: 5/8"
Weight: 2 lb. 14 oz.
Tim Harris
Posted: Tue 04 Dec, 2007 2:38 pm Post subject: |
Right... here at last are a couple of pics of my most recent 1796.
As it now lives in Singapore, I'm afraid I can't provide any more detailed shots, and the only others I have show the scabbard, which I am not entirely happy with - it was a compromise at best.
The tip isn't quite as splayed as some examples, but not as trimmed back as others.
Blade stats are close to original, apart from the blunted edge. The only other interestibg variable is the weight, which I'll have to dig out from scattered notes.
Tim
____________________
Attachment: 90.19 KB
Attachment: 104.68 KB
Posted: Wed 05 Dec, 2007 9:25 am Post subject: |
Thanks for the pics, Tim ... Interesting to say the least ! B-)
Shahril Dzulkifli
![](images/avatars/202306156555e486d1ebc67.jpg)
Posted: Thu 27 Dec, 2007 8:35 am Post subject: Cold Steel 1796 Cavalry Sabre |
Matthew, a couple of minutes ago I watched a promo video on the sword you bought being demonstrated by Mike Harris. An awesome sword indeed.
Posted: Fri 28 Dec, 2007 8:41 am Post subject: Re: Cold Steel 1796 Cavalry Sabre |
Shahril Dzulkifli wrote: | Matthew, a couple of minutes ago I watched a promo video on the sword you bought being demonstrated by Mike Harris. An awesome sword indeed. |
Thanks !
For all that it did not cost an arm and a leg, Shahril, this sword IS quite nice. It also calls to
my mind anyway, the idea that the historical sword it tries to replicate appears to be -- and I
might be over-stating my idea, since I'm far from a historical expert -- " mass produced " for
the time period in which it served. That is, as I look at this model in various places there is
a generic design, if you follow me.
Shahril Dzulkifli
Posted: Sun 30 Dec, 2007 10:04 am Post subject: Cold Steel 1796 Cavalry Sabre |
Now Matthew, did you test your new sword? I would like to know that.
