Last 10 Donors: Bernhard H., Daniel Parry, Anonymous, Daniel Sullivan, Joe Maccarrone, Z Wells, Paul Hansen, Adam Simmonds, Jonathan Hopkins, Walter Stockwell (View All Donors)
Forum Index > Off-topic Talk > Wanted: Fullering Information Reply to topic
Raymond Deancona
PostPosted: Thu 03 May, 2007 1:43 pm    Post subject: Wanted: Fullering Information         Reply with quote
I am looking for any contact information on some one in the US or Canada that can add fullers to an existing sword blade. Any info would be appreciated.
PostPosted: Thu 03 May, 2007 8:39 pm    Post subject: Re: Wanted: Fullering Information         Reply with quote
I would e-mail OlliN they might be willing to do the job or at least give an opinion about how feasible it would be with a specific sword ? With a diamond crossection a central fuller might thin the blade too much and make the blade too wippy ?
Thin narrow fullers leaving the original ridge at it's full thickness might also be a possibility.
With an existing sword there is always a risk that an error in grinding could ruing the original blade and the risk should be accepted by both parties ( after an honest evaluation about the level of risk ).
With a blade made by them any error would be corrected by making a new blade.
http://www.ollinsworddesign.com/
So at least I would e-mail Matthew or P.M. him and get an opinion/price quote if they accept the project.
Hope this helps.
Justin King
Reading list: 20 books
PostPosted: Thu 03 May, 2007 9:11 pm    Post subject:         Reply with quote
I have done some experimental retro-fullering with good results. The set up I used is limited to 1/4" wide fullers for the moment. I did have some warpage to deal with that could probably have been prevented by more careful heat mitigation.
I am planning to work on it some more in the future but have more pressing projects at the moment. Due to the already-mentioned risks of grinding on a heat treated blade and changing its cross section, I am not confident enough to try it on someone else's blade yet. A few more months of experimenting is needed at least.
