Einar Drønnesund
Posted: Wed 09 Oct, 2013 6:49 am Post subject: Got a pattern welded seax blade from Owen Bush |
Thank you Owen and Vicci for great and quick service, and a fantastic blade. This is my first blade from Owen, but I suspect it wont be my last.
Copied from the description on Owen website:
Quote: | This is a 6 bar broken back seax blade.
Constructed from vintage wrought iron, then 3 twisted bars of 15 layer, then wrought iron and finally 700 layers of piled steel at the edge.
Materials: Vintage wrought iron 15N20 nickel steel and EN42.
The blade is 13 inches long, 9mm at broken back and 6mm thick at the tang. |
I'm a real sucker for twisted bar pattern welding, and it really looks great on this blade I think.
This thing is THICK. Viewed from the spine it looks absolutely massive but as soon as you turn it just a little bit, the elegance of the design takes over. It has a triangular crossection from spine to edge, which takes a lot of the weight off. The pattern welding is beautifully done and the wrought iron makes a nice, subtle contrast between the twisted bars and the piled edge steel.
Its also razor sharp, easily shaved the hair off my forearm. Couldnt be smoother if I waxed it.
Going to start making a hilt for it soon. Trying to come up with something that will do it justice.
Einar Drønnesund
Posted: Wed 09 Oct, 2013 7:11 am Post subject: |
And by the way, people, if you order a blade from Owen, rest assured, even the most careless postal worker wont be able to damage your package. This thing had been wrapped in several layers of packing paper, then about a mile of electrical tape, then wrapped in a very sturdy piece of leather, secured by another mile of tape to a piece of wooden plank, protruding well past the tip and the tang, before finally put in a cardboard box. Safest package I've ever recieved.
Robin Smith
Posted: Wed 09 Oct, 2013 8:38 am Post subject: |
Wow... Very nice. Can't wait to see what you come up with for the grip.
William Swiger
Posted: Wed 09 Oct, 2013 9:09 am Post subject: |
Beautiful blade.
Peter Johnsson
Posted: Wed 09 Oct, 2013 10:33 am Post subject: |
Congratulation for that great seax.
A wonderful example of the type and a typical example of the wonderful work of Owen.
Looking forward to seeing it finally mounted and at home in a nice scabbard :-)
G Ezell
Posted: Wed 09 Oct, 2013 3:35 pm Post subject: |
Owen makes a fine seax indeed... lovely.
" I have found that it is very often the case that if you state some absolute rule of history, there will be an example, however extremely unusual, to break it."
Gabriel Lebec
https://www.facebook.com/relicforge
Russ Ellis
Posted: Thu 10 Oct, 2013 11:04 am Post subject: |
Very nice, I'm going to have to pick up one from him myself one of these days I think. I've flirted with the idea before.
TRITONWORKS Custom Scabbards
Jeremy V. Krause
Posted: Thu 10 Oct, 2013 4:04 pm Post subject: |
Wow, that's a beautiful blade!
Harry Marinakis
Posted: Thu 10 Oct, 2013 10:52 pm Post subject: |
Very nice!
The broken-back seax isn't my style but I bought one of Owen's seax blades this spring... It was too fantastic to pass up. I am planning to do something rather special with it - a nice grip and sheath.
Einar Drønnesund
Posted: Fri 11 Oct, 2013 6:37 am Post subject: |
Thanks, everyone
Harry, I hope you'll post pictures here on the forum when you finish your seax. I would love to see it.
Chad Hanson
Posted: Fri 11 Oct, 2013 11:59 am Post subject: |
Einar Drønnesund wrote: | Thanks, everyone
Harry, I hope you'll post pictures here on the forum when you finish your seax. I would love to see it. |
Yes seeing it mounted with a handle would be appreciated.
Very attractive pattern welding.
