David Hohl
Posted: Tue 27 Dec, 2011 6:05 pm Post subject: Building ... half a sword |
Hi, I'm working on a somewhat unusual project; a sword prop inspired by a book. The catch is, that I want to take it to some shows, who say about sword-type things: "Not if it is sharp or pointy enough to cut or pierce someone with moderate pressure. Not if it is weighty enough to bludgeon someone with a moderate-force swing". I'm afraid this disallows even a blunt or rebated steel blade, and I've seen rules for other shows which don't even allow props to leave the scabbard. My idea for this is to mount a sword hilt to a piece which is effectively a tang, plus a couple inches of blade or ricasso, just enough to make it stick in a scabbard. I can probably manage the tang and handle, including wrap, but I don't have the tools or materials to make a pommel or crossguard. My book source stipulates bronze for the fittings, though brass would do. Does anyone know of somewhere I can purchase a nice pommel and crossguard set, or have some other ideas? Thanks for your help.
Christopher Treichel
Posted: Wed 28 Dec, 2011 5:34 am Post subject: |
The Japanese have a word for what you need... tsunagi... essentially a fake wood tang/blade to hold the hilt and all the bits and pieces together while the real blade is off in storage.
You can do the same thing for a European sword except that they were not origionally intended to be taken appart...
But in essence you could make a fake blade/tang that holds your hilt parts and scabbard together but in essence is completely non functional.
Sorry but your posts title now has "Eric the Half a Bee" stuck in my head
so returning the favor http://www.youtube.com/watch?v=F_-vxAFcQIU
Ken Speed
Posted: Wed 28 Dec, 2011 6:48 am Post subject: |
So you need a minimally decent appearing non-sword and presumably a sheath to disguise the mostly absent blade, Right? Couldn't you buy a cheap wall hanger, cut off all but three or four inches of the blade and glue it into the sheathe?
David Clark
Posted: Wed 28 Dec, 2011 7:39 am Post subject: |
I agree with Ken. Go to Kultofathena.com or trueswords.com and get one of their wall hangers for about $30 or $40 and just put epoxy all up in the scabbard. I wouldn't actually cut the blade off as that may interfere with the balance of the sword while being worn. Wouldn't want it flipping and spinning around while walking would we?
![](images/avatars/21273079234cb0157a5d18b.gif)
![myArmoury Admin myArmoury Admin](images/myArmoury-logo.gif)
Posted: Wed 28 Dec, 2011 11:30 am Post subject: |
David Clark wrote: | I agree with Ken. Go to Kultofathena.com or trueswords.com and get one of their wall hangers for about $30 or $40 and just put epoxy all up in the scabbard. I wouldn't actually cut the blade off as that may interfere with the balance of the sword while being worn. Wouldn't want it flipping and spinning around while walking would we? |
Hey, that's a real good idea!
Bryan W.
Posted: Wed 28 Dec, 2011 11:36 am Post subject: |
Alternatively you had to cut down the blade and it was glued into the scabbard you could first put weights in the bottom of the scabbard (probably placed inside) to keep it properly weighted down. I bet one of those 8oz pyramid or worm lead sinkers for fishing would do it after dropping epoxy in the bottom so it wouldn't rattle around.
The cool thing about cutting down that blade is that is you can get any kind of wall hanging scabbard to give whatever shape of "blade" you wanted to convey with whatever hilt you purchase.
Ralph Grinly
Posted: Wed 28 Dec, 2011 12:38 pm Post subject: |
If the shows you plan on taking the prop to frown on "anything that can be used to bludgeon..." then a wall hanger glued into it's scabbard could still fall into their no-no list It all depends on how paranoid they are
David Hohl
Posted: Wed 28 Dec, 2011 2:10 pm Post subject: |
Thanks for the wallhanger idea; that could make my life a lot easier. As far as the rest, I know that these shows tend to allow balsa or plastic blades painted up to resemble steel - hardly ideal, but understandable. The main goal is to stop anyone from getting hurt by either walking around in a crowded convention hall, or by being stupid. I think Brian's is a great idea; it'll let me either use a mostly empty scabbard, or build a fake blade, depending on how I feel. Thanks a lot for your advice.
Jason Dingledine
![](images/avatars/135904652845518bfda82db.jpg)
Posted: Wed 28 Dec, 2011 5:14 pm Post subject: |
Another option is to get the proper sword you like, and simply zip-tie the sword to the scabbard to prevent it from being drawn. Standard practice at gun shows.
Jason Dingledine
