Forum Index > Off-topic Talk > Making a Rapier Scabbard Reply to topic
Pascal B
PostPosted: Mon 22 Feb, 2010 10:31 pm    Post subject: Making a Rapier Scabbard         Reply with quote
HI
has anyone any helpful suggestions or knowledge? ive made some for Viking Swords. but not that figurine stuff, which fits a Rapier.
thx.
Craig Johnson
Likes: 16 pages
Reading list: 20 books
PostPosted: Tue 23 Feb, 2010 6:14 am    Post subject: Rapier Scabbards         Reply with quote
Hi Pascal
Period rapier scabbards have a different construction in most cases to earlier medieval types. I am not sure what you mean by "figurine" but they do some times have elaborate chapes. In most cases the do not have throats or lockets. They will have a bulge or swelling under the covering that will allow the hanger to tighten down and not have the scabbard slide. The shape of the interior is usually a box, not the tight fitting shapes of earlier scabbards. They also will often have the front and back of the scabbard extend up the ricasso to the cross. there are no sides on this section.
There is not a lot of literature on these items and few of the average pieces are displayed in museums or pictured in collections. It can be difficult finding info on them.
Hope this helps
Craig
Richard M
PostPosted: Tue 23 Feb, 2010 4:47 pm    Post subject: Re: Making a Rapier Scabbard         Reply with quote
Pascal B wrote:
HI
thx.
Pascal,
I made one a while back. To work within that slender profile takes some patience, but it's not too bad. I used a dremel to hollow out two slats, then glued them together. The mated surface won't be very wide so you'll have to be meticulous about gluing it. When shaping the outside you'll just have to keep in mind the internal dimensions. I suggest starting with a belt sander if you have one, then finishing it with paper.
If yours has a ricasso, fit the mouth to that.
Good Luck Big Grin
I
Pascal B
PostPosted: Sun 28 Feb, 2010 7:58 am    Post subject:         Reply with quote
hi
Thanks for the Ideas und hints.
@ Craig Johnson
with" Figurine" i thaught of those fine patterns and how thin it is
@Richard M
really nice work youve done..What kind of wood did you use? And where did you find this metal cap on the end of the scabbard?
thanks again
Richard M
PostPosted: Mon 01 Mar, 2010 5:08 am    Post subject:         Reply with quote
Pascal B wrote:
hi
thanks again
It's lacewood, with a ferrule made from walnut at the top. Not exactly historic I know. It was fun though.
The chape came from the original Hanwei scabbard that came with the sword. I haven't been able to find a suitable chape for a rapier anywhere on the net.
