Forum Index > Off-topic Talk > Antiquing Stainless...? Reply to topic
Josh MacNeil
PostPosted: Wed 01 Oct, 2008 12:24 pm    Post subject: Antiquing Stainless...?         Reply with quote
Hi all. I've been experimanting with antiquing a few pieces from my collection after reading Sean Flynt's article on the subject. Aside from surface treaments like cold bluing, I was wondering if anybody knew of some ways to antique stainless steel. Thanks.
-JM
Jerry Knox
PostPosted: Wed 01 Oct, 2008 12:36 pm    Post subject:         Reply with quote
Getting it very hot (i.e. in a charcoal fire, or with a blowtorch) can discolor the surface into the blue/black range, usually with some mottling. It is fairly superficial, but could be the basis for further treatments.
PostPosted: Wed 01 Oct, 2008 12:51 pm    Post subject:         Reply with quote
I have moved this topic to the Off-topic Talk forum.
Please note the description for this forum:
"Discussions of general history and other miscellaneous topics relating to arms and armour that do not specifically fit our other forums"
Thank you.
Nathan Keysor
Reading list: 9 books
PostPosted: Thu 02 Oct, 2008 9:57 am    Post subject:         Reply with quote
I've set pieces on an electric stove burner and let the heat discolor it. A propane torch works too. Just be careful.
"Democracy is two wolves and a lamb voting on what to have for dinner.
Liberty is a well-armed lamb contesting the vote!"
Bruno Giordan
PostPosted: Thu 02 Oct, 2008 11:31 am    Post subject:         Reply with quote
You would also be damaging the heat treatment effects, losing the temper of the blade.
You could obtain this effect by placing it in an oven at a given temperature (any color chart for heat treatment will tell the right temp in fahreneit)
I obtained a deep blue simply by carburizing in into steel the classical way, i.e. several hours in a bed of fine charcoal powder, at least 24 in my case.
It is in an annealed state now though, it will need a complete heat treatment cycle to get into a springy state..
