Forum Index > Off-topic Talk > Mounting an MRL Hewing Spear Reply to topic
Thomas Jason
PostPosted: Mon 01 Sep, 2008 12:15 pm    Post subject: Mounting an MRL Hewing Spear         Reply with quote
Has anyone done this? I belive it takes a 1 1/4 inch shaft, But not sure if I should taper it or just slam it on.
Any advice would be appreciated.
View user's profile Send private message AIM Address ICQ Number
Lin Robinson
PostPosted: Mon 01 Sep, 2008 2:07 pm    Post subject: Re: Mounting an MRL Hewing Spear         Reply with quote
I mounted an MRL Viking spear several years ago. You will need to taper the shaft with a four-in-one rasp or draw knife to have a tight fit. Be careful not to remove too much wood because you can't put it back on! It took some time, care and a couple of different tools, but mine turned out pretty well.
Lin Robinson
Jim Adelsen
PostPosted: Mon 01 Sep, 2008 5:37 pm    Post subject:         Reply with quote
I usually add a little Goop glue. It remains rubbery when it dries and hold it on real tight.
www.viking-shield.com
D. Austin
PostPosted: Mon 01 Sep, 2008 6:29 pm    Post subject:         Reply with quote
I haven't used an MRL spear before, but I have learnt one trick for getting a perfect fit, if you're so inclined.
Once you've got the shape of the wood pretty close to that of the inside of the socket, pour some soot into the socket (outdoors of course) and swirl it around , then tip it out. Jam the spear head onto the shaft and then remove it. The soot will leave marks on the high spots which can then be sanded off or shaved off with a very sharp knife. Repeat this process a few times and you'll have a very strong, sturdy fit.
R D Moore
Reading list: 11 books
PostPosted: Mon 01 Sep, 2008 6:49 pm    Post subject:         Reply with quote
Posted: Tue 15 Jan, 2008 6:38 pm Post subject: Socketed lance heads from Native Way
This thread, above, should provide a wealth of information you can use. You can use the search function by typing in "socket and lance" and it should bring it up for you. I found a Stanley Surform at Home Depot for about $7.00, and it saved me a lot of time. Sean Flynt posted a picture of it in the thread.
Good Luck!
PostPosted: Mon 01 Sep, 2008 6:51 pm    Post subject:         Reply with quote
Here is a link to the above topic so others don't have to search for it:
http://www.myArmoury.com/talk/viewtopic.php?t=12124
M. Eversberg II
Reading list: 3 books
PostPosted: Tue 02 Sep, 2008 2:23 am    Post subject:         Reply with quote
Yes that was quite a handy thread; going to be making me a brace or two of those native way spears; maybe I'll put up a few here on the cheap.
M.
This space for rent or lease.
Thomas Jason
PostPosted: Wed 03 Sep, 2008 3:35 pm    Post subject:         Reply with quote
Thanks all for the great tips folks!
Will give it a go!
