Forum Index > Off-topic Talk > Pommel decoration question Reply to topic
J.G. Grubbs
PostPosted: Thu 17 Jul, 2008 5:54 pm    Post subject: Pommel decoration question         Reply with quote
Hi All,
I'm afraid my search-fu is weak tonight! I wondered if anyone had experience with placing a coin or other decorative iten in the pommel recess of a sword? I realize it would best be done during the actual making of the piece, but how would one do this after the fact..say placing a coin or similar object in the recess of aa A&A Durer, for example? All input is much appreciated!
"The reputation of a thousand years may be determined by the conduct of one hour."
Samurai Proverb
James Grubbs
Dan Dickinson
PostPosted: Thu 17 Jul, 2008 6:00 pm    Post subject:         Reply with quote
Here are a few threads that might be helpful.
Dan
http://www.myArmoury.com/talk/viewtopic.php?t...reign+coin
http://www.myArmoury.com/talk/viewtopic.php?t...ommel+coin
J.G. Grubbs
PostPosted: Thu 17 Jul, 2008 6:05 pm    Post subject:         Reply with quote
Dan
Thanks for the links, Dan! I'm planning on ordring up a Durer tomorrow and thought this might be a fun thing to try to do..
Samurai Proverb
James Grubbs
Craig Johnson
Likes: 16 pages
Reading list: 20 books
PostPosted: Thu 17 Jul, 2008 6:07 pm    Post subject: Adding items to pommels         Reply with quote
There are several ways they were added in period. The most common being a physical constraint or glue. There also could be a friction fit, which I guess would be a physical constraint. Many additions to the pommel are painted or enamled in as well. The constaraint type can be jeweler quality type mounts or, much more common, a deformation of the outer ring to hold the item in. The Bayerisch Sword is an excellent example of this with three or four (I do not remember which it was) chisel cuts to hold the item in, this was a common technique.
Today most people go for an adhesive. There are many good ones out there. I recommend something that does not soften in the heat as sitting in the sun can sometimes affect these materials.
Best
Craig
J.G. Grubbs
PostPosted: Thu 17 Jul, 2008 6:27 pm    Post subject: Re: Adding items to pommels         Reply with quote
Best
Craig
Thanks Craig..sent you a pm..
Samurai Proverb
James Grubbs
Bryce Felperin
PostPosted: Thu 17 Jul, 2008 6:42 pm    Post subject: Re: Adding items to pommels         Reply with quote
Best
Craig
Hey Craig, I also added a couple of coins to one of your Durer long swords in this post:
http://www.myArmoury.com/talk/viewtopic.php?t=7677&highlight=
In this project I used JB Weld. It works better than glue for attaching two types of metal together. I since traded the sword, but the new owner likes the coins and they haven't moved an inch during all the period I and him have owned the sword.
Thanks,
Bryce
