Forum Index > Historical Arms Talk > The heaviest battle axes Reply to topic
Guilherme Dias Ferreira S
PostPosted: Fri 26 Jan, 2007 7:13 pm    Post subject: The heaviest battle axes         Reply with quote
How much was the weight of the heaviest battle axes used in the medieval times? And who used it (would be the Huscarls?)?
Benjamin H. Abbott
PostPosted: Fri 26 Jan, 2007 7:23 pm    Post subject:         Reply with quote
Waldman's book lists a gigantic Russian axe that weighs around eight and a half pounds.
I suspect few axes meant for combat were heavier than that.
Richard Fay
Reading list: 256 books
PostPosted: Fri 26 Jan, 2007 7:42 pm    Post subject: Re: The heaviest battle axes         Reply with quote
The "Danish" two-handed axe used by the Anglo-Saxon house-carls was relatively light as compared to later medieval pole-axes used by armoured warriors in foot combat. I listed the weights for two later medieval pole axes on this this recent thread:
http://www.myArmoury.com/talk/viewtopic.php?t=9040
I hope this helps!
Stay safe!
Prince Andrew of Armar
View user's profile
PostPosted: Sun 28 Jan, 2007 5:29 pm    Post subject:         Reply with quote
Benjamin, I think that you are talking about the famous bardiches.
By the way, the weight of the halberd used by the middle east soldiers in medieval times had some difference of the 4 to 6 pounds of the european ones? And if anyone could show some pictures of this I will be very thankful.
[/quote]
Reading list: 7 books
PostPosted: Sun 28 Jan, 2007 8:19 pm    Post subject:         Reply with quote
Check this thread:
http://www.myArmoury.com/talk/viewtopic.php?t...ish+museum
And no, they didn't seem to have differed substantially in weight from the European examples.
PostPosted: Tue 30 Jan, 2007 12:05 pm    Post subject:         Reply with quote
I'm not a weapon specialist, but I can see clearly that these halberds differ significantly from the european counterparts in the way of use in battle. I think that these weapons were more likely to be used as big pole axes like bardiches or voulges. What do you think?
