R. D. Simpson
Posted: Mon 24 Jul, 2006 12:55 am Post subject: Relative Properties of Maille and Scale Armour? |
I've begun to wonder about the relative advantages and disadvantages of maille and scale armour. I used the search feature, but have exhausted all search criteria that I could think of without finding an answer.
It seems to me that an upward cut or thrust could slide in between scales and (relatively) easily penetrate the fabric backing, but is that an accurate assessment?
Since maille seems to have been much more prevalent into medieval times, my guess would be that it had advantages over scale in weight, protection, or both, but I'm still pretty new to this so I could be completely off base.
So, which offered better protection, scale or maille? Which weighed more? Obviously the weight and protection of maille would depend on ring size and thickness, so for the purposes of this discussion let's assume a thickness roughly equal to between 16 and 14gauge and an inner diameter of around 3/8in.
Gloria Virtutem Sequitur
Chuck Russell
Posted: Mon 24 Jul, 2006 2:56 am Post subject: |
ah but if your going by historical accounts, mail is more like 18 gauge 6mm ID.
romans had both scale and mail. but as time told, mail won out.
R. D. Simpson
Posted: Mon 24 Jul, 2006 3:16 am Post subject: |
Chuck Russell wrote: | ah but if your going by historical accounts, mail is more like 18 gauge 6mm ID.
romans had both scale and mail. but as time told, mail won out. |
Whoops
Okay, so instead of 16-14 gauge and 3/8in inner diameter, assume 18 gauge and 6mm (1/4in) inner diameter.
I was aware that maille won out, but I wondered why this was? Did it have to do with performance in battle, ease of production, or was it some combination thereof?
Posted: Mon 24 Jul, 2006 3:33 am Post subject: |
Scale has no advantages over mail except perhaps that it is a little quicker to manufacture and hence likely to be cheaper. Scale is harder to maintain. It deteriorates more quickly. It is heavier. It offers less protection. It is not as flexible.
R. D. Simpson
Posted: Mon 24 Jul, 2006 3:41 am Post subject: |
Dan Howard wrote: | Scale has no advantages over mail except perhaps that it is a little quicker to manufacture and hence likely to be cheaper. Scale is harder to maintain. It deteriorates more quickly. It is heavier. It offers less protection. It is not as flexible. |
Thanks: that's what I wanted to know. By the way, about how much would a scale coat have weighed, assuming the same measurements as a full hauberk?
