Ian Hutchison
Posted: Wed 12 Sep, 2018 12:34 pm Post subject: Adding by-knives to a scabbard |
Going to attempt my first scabbard with by-knives. Does one just glue the by-knife sheath on the scabbard core, mark the mouth of the sheath on the scabbard leather, cut a simple slit, and then wrap the core with sheath in place?
Is there any trick in cutting the slit for the sheath mouth? Does it need to have the edges dressed in some way?
Ian Hutchison
Posted: Wed 12 Sep, 2018 5:08 pm Post subject: |
Excellent, thanks. Good idea with the riser, I will try that.
Ian Hutchison
Posted: Thu 13 Sep, 2018 1:46 pm Post subject: |
Sean, did you make the cut a little high (i.e. give a bit extra), to fold it over the riser and tuck it up into the sheath or is it just lying over it?
Ian Hutchison
Posted: Fri 14 Sep, 2018 7:21 am Post subject: |
Thanks Sean, that makes it very clear. Where do you get your chamois by the way? It doesn't appear to be suede as most are, or maybe that is a result of treatment?
Posted: Fri 14 Sep, 2018 7:29 am Post subject: |
I get the largest chamois I can find in the automotive section at Wal-Mart. I think it's about $13. I can typically get a scabbard or two and lots of grips out of it. It is not quite a suede surface on both sides--matte, but not textured. One side is typically a bit smoother. I dye it as-is, glue to scabbard smooth side out, and then wax (hard waterproofing beeswax) and burnish it with a smooth tool (Sharpie pen barrel is good) after it's thoroughly dry. Same for grips. It's as cheap as you can do it, I think.
