Jonathan Hodge
Posted: Tue 02 Jan, 2018 2:29 pm Post subject: Reenactor/Living History Poll |
I’ve recently been told by a trusted vendor in the reenactment and living history community that an overwhelming number of Viking-13th century reenactors often wear flat ring riveted mail - even though round ring riveted is more historically appropriate for that era. In my estimation, this is most likely to save weight for extended amounts of time being in harness. Many pictures I can find of trusted events are not high enough res or close enough resolution to study the mail on folks portraying this time period.
Those who are in reenactment/living history - do you find this to be the case?
Posted: Tue 02 Jan, 2018 3:13 pm Post subject: |
I don't think it has anything to do with weight. It is more likely because flat ring is generally cheaper and more readily available from vendors. People have this absurd notion that if they get riveted mail - any kind of riveted mail - then their kit will be "authentic". IMO a well-constructed butted mail shirt looks closer to historical mail than many kinds of riveted mail coming out of India.
Mark Moore
Posted: Tue 02 Jan, 2018 3:23 pm Post subject: |
I can tell you, from my personal experience, that there's not a whole lot of significant difference in the weight of round-vs-flat ring. I think round riveted would be more 'historically correct' for that time period and culture, but I'm no expert by far. My mail is round riveted/solid flat mix, I like it, and it looks GOOD on ME... ...at least my wife thinks so. .....McM
Jonathan Hodge
Posted: Tue 02 Jan, 2018 4:15 pm Post subject: |
Looks like it saves about 30% of weight on average. That’s a saving of 9 lbs for an equivalent round ring hauberk at 30lbs. Not sure how significant that is with the way weight is spread/carried.
Matthew Amt
Posted: Tue 02 Jan, 2018 4:54 pm Post subject: |
Aren't they just using the same wire gauge and flattening the rings? That would be the identical weight.
Also, there is potential confusion in terminology: to me, "round riveted" means the RIVETS are round, rather than wedges. "Round wire" rings are clearly not "flat rings" or "flat links".
Matthew
Jonathan Hodge
Posted: Tue 02 Jan, 2018 5:54 pm Post subject: |
You’d think it would be the same, but the seller is telling me it’s 30% less. And I’m referring to round links mixed with solid flat rings - dome riveted. Hope that helps clarify.
Posted: Tue 02 Jan, 2018 11:38 pm Post subject: |
If there was a weight saving of 30%, the flat links would be so thin that you could tear the mail apart with your hands.
Arne G.
Posted: Tue 02 Jan, 2018 11:53 pm Post subject: |
I suspect many just don't understand that flat ring is wrong for the period. Most don't realize the nuances of mail construction, beyond the fact that "riveted is right". These are subtle details that most wouldn't know unless they really study the subject; to my knowledge there is no single book on armour that details the specifics of mail construction. One has to dive through dozens of obscure papers on the subject to tease this out. Doesn't help that the non-flat ring coming out of India is really not all that historically correct, as Dan Howard has pointed out in other threads. He is also correct that butted looks better from a distance. At this point if you want period correct mail, you either need Erik Schmid to make it for you, or do the research, make the tools, and make it yourself.
Mark Moore
Posted: Wed 03 Jan, 2018 2:01 am Post subject: |
Jonathan---I think that the big question here is---what do YOU intend TO DO with it? ........McM
Jonathan Hodge
Posted: Wed 03 Jan, 2018 4:16 am Post subject: |
| Dan Howard wrote: | | If there was a weight saving of 30%, the flat links would be so thin that you could tear the mail apart with your hands. |
I suspect this is all too correct. And as Matthew noted, I was surprised by this statement due to the face that I have done the searches for obscure articles and forum posts by experts on a handful of sites - including this one! The hauberk I’m most interested in is heavy - 37lbs at my measurements. This scales fairly closely with some originals I’ve seen, but it seems awfully heavy to wear for an extended period of time.
Posted: Wed 03 Jan, 2018 2:17 pm Post subject: |
There is a good chance that you will be able to knock at least 5 pounds off the weight if you tailored it to fit properly after it arrived. You would need some spare links and a peening tool. 37 pounds isn't all that heavy. I have a leather coat and pair of boots that weigh 30 pounds between them. An elaborate wedding gown can weigh more than 37 pounds.
Jonathan Hodge
Posted: Wed 03 Jan, 2018 3:13 pm Post subject: |
| Dan Howard wrote: | | There is a good chance that you will be able to knock at least 5 pounds off the weight if you tailored it to fit properly after it arrived. You would need some spare links and a peening tool. 37 pounds isn't all that heavy. I have a leather coat and pair of boots that weigh 30 pounds between them. An elaborate wedding gown can weigh more than 37 pounds. |
I’m feeling better about it after this. I've been wondering all along if it’s not as bad as it sounds. I’ve also considered seeing if arms could be done in 18 and torso in 16. I’ve seen some early-mid 14th century examples that showed variable gauge construction. I’m hoping this may be an older tradition though I have no direct evidence for it.
Gregory J. Liebau
Posted: Wed 03 Jan, 2018 6:53 pm Post subject: |
37 pounds for a hauberk? Even the extra large size 6mm alternating dome riveted flat and solid flat ring hauberk produced by Lord of Battles (available on Kult of Athena) is only listed at 33.1 pounds. The rings are 18 gauge, which is pretty standard for either round or flat. I see some companies using 17 gauge for round rings, but the difference is miniscule - 0.005 inches, with 17 gauge wire being 0.045 inches and 18 gauge being 0.040 inches. Only about 12% of the ring diameter, and that's only for half of the rings and excludes the rivets. Certainly not close to 30% of the total weight!
I think you're dealing with something screwy or the vendor is comparing apples to oranges and not telling you the whole story.
Jonathan Hodge
Posted: Thu 04 Jan, 2018 11:49 am Post subject: |
| Gregory J. Liebau wrote: | 37 pounds for a hauberk? Even the extra large size 6mm alternating dome riveted flat and solid flat ring hauberk produced by Lord of Battles (available on Kult of Athena) is only listed at 33.1 pounds. The rings are 18 gauge, which is pretty standard for either round or flat. I see some companies using 17 gauge for round rings, but the difference is miniscule - 0.005 inches, with 17 gauge wire being 0.045 inches and 18 gauge being 0.040 inches. Only about 12% of the ring diameter, and that's only for half of the rings and excludes the rivets. Certainly not close to 30% of the total weight!
I think you're dealing with something screwy or the vendor is comparing apples to oranges and not telling you the whole story. |
My measurements in 18 gauge are around 25 lbs. I had them quote it at 16. Both gauges seem to fall in the bell curve for equivalent wire thickness in extant examples. I like the look of 16 better, but may end up going with 18.
Posted: Thu 04 Jan, 2018 1:23 pm Post subject: |
Keep in mind that museum catalogues and archaeological reports give the OUTSIDE diameter of the links. Indian mail manufacturers give the INSIDE diameter. If they claim that their links are 6 mm diameter, they are really closer to 10 mm. Personally I think that if you want something that resembles 12-13th century European mail, that you will not get anything even remotely in the ball-park from these manufacturers. The best you can hope for is something that is a decent fit and doesn't shed links when you try to put it on.
Jonathan Hodge
Posted: Thu 04 Jan, 2018 3:13 pm Post subject: |
| Dan Howard wrote: | | Keep in mind that museum catalogues and archaeological reports give the OUTSIDE diameter of the links. Indian mail manufacturers give the INSIDE diameter. If they claim that their links are 6 mm diameter, they are really closer to 10 mm. Personally I think that if you want something that resembles 12-13th century European mail, that you will not get anything even remotely in the ball-park from these manufacturers. The best you can hope for is something that is a decent fit and doesn't shed links when you try to put it on. |
This is pretty true. This mail is the best Indian offering I’ve seen. I don’t think Erik is making hauberks, and if he were I couldn’t afford it anyway lol. Another forum member shared a nice chart of mail finds from the Viking age Birka Garrison in Sweden, and the mail I’m looking at ordering falls within the bell curve for diameter and circumference, so at least that part could be reasonably appropriate.
http://members.ozemail.com.au/~chrisandpeter/mail/birka_mail.htm
Arne G.
Posted: Thu 04 Jan, 2018 10:58 pm Post subject: |
It should be noted that the 13th century Tofta coif has rings that are fairly large. One that was analyzed was elliptical in shape, ranging from 11.2 to 11.8 mm O.D., and an I.D. of 8.5 to 9.4mm. Also, the Sinigaglia hauberk had rings of over 1/2" O.D., while the Rudolph IV mail from the Hearst Collection also had rings about 1/2" O.D. For this reason the Indian made rings are fine from the perspective of their diameters, though they are often too thin and overflattened, among other problems.
James Arlen Gillaspie
Posted: Wed 10 Jan, 2018 9:23 am Post subject: |
37 lbs (16.8 kg) is unusually heavy for a SURVIVING mail shirt. The heaviest shirt the Wallace has, for example, is 9.01 kg, and the heaviest the RA has online is only 25 lbs 10 oz. The heaviest and, I think, the oldest shirt I have ever handled weighed 37 lbs, and the torso rings were running 15 mm OD 11 mm ID, round wire links and punched rings that were also quite round in cross section, possibly due to it being one of the most worn pieces of mail I have ever seen; the usual rectangle you would see on the underside of the riveted links (bottoms of the wedge rivets) was invisible. Only the broken links allowed one to tell they were made with narrow pie slice shaped rivets. It made me think of Anna Comnena's description of the mail of the Franks.
jamesarlen.com
Chris Friede
Posted: Wed 10 Jan, 2018 12:15 pm Post subject: |
As a reenactor who wears mail, most of our Viking warband has butted mail. Those hauberks tend to be a bit heavier than the flat riveted mail worn by our later period actors. (Sherwood Forest Faire in Texas) (shameless plug)
