Adrian Thurnwald
Posted: Thu 25 Jul, 2013 11:12 pm Post subject: Getting rust off lamellar |
Howdy,
Does anyone have any tips for getting rust off lamellar armour?
I've started scrubbing with light sandpaper and metal polish, but it doesn't get in easily behind the overlapping plates, and makes the laces very ugly.
Thanks in advance!
'You damn morphodite, I'll kill you!'
Mart Shearer
Posted: Fri 26 Jul, 2013 12:52 am Post subject: |
Step1: Unlace the lames
Step 2:.....
Posted: Fri 26 Jul, 2013 1:19 am Post subject: |
You've just discovered one of the problems with lamellar. It is a major pain to maintain
R Lister
Posted: Fri 26 Jul, 2013 1:26 am Post subject: |
I tried to clean my lamellar with sand paper and stuff. It did not work.
I then unlaced my lamellar.
I cleaned all the bits
I covered the whole bloody lot in iron dwarf battle wax
I then re-laced it. It took fing ages.
I'm still not done.
I've however laced the lamellar into sections, so they are modular, and can be taken apart without destroying the whole armour.
Rich
Herigeas Hundas
hampshirereenactment.com
Stephane Rabier
Posted: Fri 26 Jul, 2013 4:34 am Post subject: |
Hi,
the traditional and historical technique is : call one of your slaves / serfs, give him a piece of rag, promise him to whip him vigorously if it does not shine until tonight or if the laces are soiled...
Simple, isn't it?
Ian Hutchison
Posted: Fri 26 Jul, 2013 6:43 am Post subject: |
Stephane Rabier wrote: | Hi,
Simple, isn't it? |
They were simpler times, better times.
Jeffrey Hildebrandt
Posted: Fri 26 Jul, 2013 7:01 am Post subject: |
This won't help you with cleaning the lamellar, but it might keep you from having to clean it again: Spray a bit of oil on using a salad oil sprayer (they make a finer spray than the gun oiling sprayers - fine enough that it doesn't need to be wiped to improve coverage). Flex the armour so that as much surface gets sprayed as possible, then lightly wipe the exposed surface. The coating is fine enough it should not make your lacing slimy - if the lacing is leather, it will actually keep it supple. This form of maintenance has kept my lamellar from rusting in the oppressively humid Niagara Peninsula.
As for removing rust from hard-to-reach places, sometimes muriatic acid is the ticket, when rinsed and neutralized immediately afterwards. I find myself saving a lot of time using acid for rust removal and de-scaling. You could test a small spot to make sure it didn't damage the lacing. Acid has to be handled with extreme care, of course, and I wouldn't venture near it without a proper organic vapours/acid fumes mask.
I hope this helps
-Hildebrandt
Royal Oak Armoury Website
Royal Oak Armoury Facebook
Gabriele A. Pini
Posted: Fri 26 Jul, 2013 7:21 am Post subject: |
It's possible to use electrolysis for rust removal?
http://www.instructables.com/id/Electrolytic-...aka-Magic/
The biggest problem I see is the contact between the lamellas and if the washing soda negatively affect the laces.
Before trying I will attend the guidance from the Olympus of myArmoury: I have and old maille coif with which I could make an experiment, if it's necessary.
Boris Bedrosov
Posted: Fri 26 Jul, 2013 4:38 pm Post subject: |
Indeed, the rust is major problem in lamellar armours. That's why I blackened every individual plate of mine before lacing (you could see how it looks like in the "Show Us Your Kits and Harnesses" thread).
As you obviously couldn't do so it yours, the only left is to oil it regularly. For this purpose I usually use WD-40 - although blackened, it still gets rust, especially inside and under the overlappings.
I just wonder how this problem would reveal itself in discussed here http://www.myArmoury.com/talk/viewtopic.php?t=27977 "lamellae-riveted-on-leather-band" construction?
Obviously , the inner side would be protected by the leather, while the outer - a bit easier to clean.
Tokugawa Ieyasu
Find my works on Facebook:
Boris Bedrosov's Armoury
Adrian Thurnwald
Posted: Sat 27 Jul, 2013 5:18 am Post subject: |
Thanks guys. The lamellar is blackened but it has some spots showing. I've worn in a few times in the weather, and, well, now here I am starting this topic
The rust is not terrible at the moment. It's at the level where it comes off without heavy sandpapering. I'll try and rub it with a little bit of polish and cloth and then spray it with oil, as mentioned above. If the laces get a bit off-colour... well, they'll be consistently off-colour!
