I have a series of Landsknecht pieces to make for a single client and thought it may be interesting to post it up as I go.
The pieces that will form part of thread will be a 'misericord', a simple bronze handled dagger that is classically Landsknecht. An eating set and scabbard. A Katzbalger with scabbard and a super fancy dagger with a sculptural handle and a silver scabbard.
These pieces are naturally going to take a while to put together so patience will be required.
The client wants a Katzbalger with a blade about 68-70cm long and a fancy fishtail pommel that is quite long, so it leaves very little grip between the guard and the pommel. There will be a scabbard to follow and this will be fitted with a suitable chape and will be harnessed in a typical Landsknecht method of being horizontally worn and lashed in place.
The blade is 69cm long, 5 cm wide and is just under 5mm thick at the guard and is of lenticular section. The black pen marking on the blade is to see if the client would like the side fullers taking further down.
I have made a master fabricated from 6 pieces and will have it moulded and cast in EN9 (modified) which is about .7% carbon, the brass parts will be steel on the finished item. I decided to keep it straight and curve it afterwards for production reasons.
I have started to carve the pommel and will post up pictures in a day or two.
I hope you enjoy watching the progress.
![kat pommel small 2].jpg](files/kat_pommel_small_2__666.jpg)
