Does anyone have any historical information about covering a shield (mainly heater) with leather? What type of leather was used and how thick would it have been? Were designs just painted right over the leather or was another process used? I know historical info is spotty, so any good recommendation to the above questions would help also.
Thanks.
Stephen.
The majority of artifacts studied in Jan Kholmorgan's work on High to Late Medieval knightly shields are constructed with rawhide glued to softwood boards, covered in gesso, paint and varnish to stiffen the surface. Late Medieval & Renaissance pavises are similarly constructed but sometimes use coarse canvas-like textile instead of or combined with rawhide. None of them seem to be tanned leather.
Thanks for the info, Kel! It's a great help to me. Rawhide, eh? I would have amused that they used soft leather. That will be my next project.
Greetings!
As I recall, someone wrote about the different layers of materials on the shield of the Black Prince, Edward of Woodstock. This was made for his burial, so I don't know if it uses the same materials as a ,,normal" shield does. You can read more about it in the link below. I made my one based on these... Whit inauthentic chrome tanned leather, and doubled fabric, due to the lack of parchment. :)
If you consider the gesso too brittle, you could add some sugar into it. I have red this in a book about calligraphy, although I don't know how common was the "sugar" in the present form of it in the medieval times.
I hope I was able to help!
John
The link:
http://www.myArmoury.com/feature_mow_bp.html
John
The link:
| Kel Rekuta wrote: |
| The majority of artifacts studied in Jan Kholmorgan's work on High to Late Medieval knightly shields are constructed with rawhide glued to softwood boards, covered in gesso, paint and varnish to stiffen the surface. Late Medieval & Renaissance pavises are similarly constructed but sometimes use coarse canvas-like textile instead of or combined with rawhide. None of them seem to be tanned leather. |
Based on the fragments from the Isle of Mann early medieval shields had paint applied directly to the leather (and given that rawhide and leather are archaeologically indistinguishable in most cases it's a generic term and probably rawhide).
Quoting this (http://forums.armourarchive.org/phpBB2/viewto...highlight= post on armourarchive
| Quote: |
| The shield was found at Trondheim bygrund in 1975 in a context dated to the
11th and 12th centuries. It was found in what was then a backyard in a refusal heap with other discarded objects, it had obviously been thrown away as worn-out and useless. It is made up by two layers of boards, the upper layer skewed 90º against the lower. The boards in each layer are approximately 5 – 6 mm thick. One must keep in mind though that the shield parts were waterlogged by the time of the recovery, it could thereby be estimated that the shield probably had a total thickness of close to/less than 10mm. A series of holes along what is left of the rim implicates that it initially was covered and/or had the rim reinforced, possibly by rawhide that deteriorate quite fast in the ground. |
And there is a cut down kite (into a heater) known widely as the Seedorf shield, that has blue (presumably painted) leather on the face.
HTH
N.
Thanks again guys for the info! You have all been helpful.
So should I apply gesso to the rawhide and paint on that or just paint directly onto the surface? I don't know too much about gesso. It is brittle and will chip off easy? I would love to test out the different methods for myself, but my cash flow isn't so great.
Stephen.
Stephen.
Stephen,
Gesso is basically glue with chalk or plaster. A couple layers solidify the material beneath and provide a smooth ground for painting. There is no necessity to go beyond a couple coats or for that matter add plaster unless you need a smoothly primed surface. Painters' canvas bonded to wood with carpenter's glue then coated with thinned glue is enough. Seal that with paint and varnish as you wish. There is no need to be particular about the materials unless you are making period reconstructions. Shields are consumable items in training. Better ones last longer but they all die eventually.
Hope that helps!
Hope that helps!
