Forum Index > Makers and Manufacturers Talk > Yushman Project Reply to topic
This is a standard topic Go to page Previous  1, 2, 3 ... 12, 13, 14 ... 24, 25, 26  Next
Jeffrey Faulk
PostPosted: Mon 14 Nov, 2011 3:09 pm    Post subject:         Reply with quote
Quick question, Boris...
The patterns on your greaves, how do you draw those and get them so symmetrical? I can't imagine that you do them all by free-hand!
Perhaps in one of your next posts you could show the whole armour together to give us some idea of your progress with this project thus far? I'm certain it would be very impressive.
Hope things keep going well for you!
PostPosted: Mon 14 Nov, 2011 6:42 pm    Post subject:         Reply with quote
Boris Petrov Bedrosov wrote:
I have never made such estimate, but I think it's not less than 1200-1300 working hours so far; in this is not included the time for research and initial planning.
I have no trouble believing that you put in at least 1300 hours of work on this project, and the results are very much to be admired. Big Grin Cool
Boris Bedrosov
PostPosted: Sat 19 Nov, 2011 2:38 pm    Post subject:         Reply with quote
Answering Jeffrey, I really draw my patterns by free-hand often, or at least free-hand drawing is an essential part of pattern-making process.
I will try to explain what I do on this sketch:
1. First, I draw 3D sketch of the intended armour part (here is shown the central plate of the infantry greave). Unfortunately, I'm not quite good 3D artist, and although I have absolutely clear idea in my mind of what I want to achieve, usually the 3D picture is almost childish. But regardless, it helps me in clarifying the ideas.
When I have enough pictures of the artifact (better from different angles), I usually skip this step.
2. After that I draw by hand the contours of the future pattern on paper, but when the pattern is symmetrical (like in this case) usually I use ruler. What I want to achieve here are smooth lines and gentle curves.
3. After cutting the pattern I fold it alongside the central line and check the both left and right contours for matching. Where is needed, I correct the lines using the lesser half as a guide.
Sometimes, it's necessary to repeat steps 2. and 3.
4. After transferring the pattern on clear sheet of paper the work is done
Tokugawa Ieyasu
Find my works on Facebook:
Boris Bedrosov's Armoury
Boris Bedrosov
PostPosted: Sat 26 Nov, 2011 10:36 am    Post subject: The Greaves - Continue         Reply with quote
Now, some work with the cavalry greaves.
The tar is applied everywhere and the excess tar on the central plates is removed:
The plates reversed in a manner, in which the inscriptions could be read - as you know, in Arabic this is done from right to left
The inscription on the upper one (which will be the left greave) is The Takbir - or Arabic term for the phrase Allahu Akbar - "The God is great";
On the right greave (bottom one) is The Basmala (or Bismillah) - a collective name for the whole Islamic phrase B-ismi-llahi r-rahmani r-rahimi, usually translated as "In the name of God, Most Gracious, Most Merciful" or "In the name of God; The most kindly merciful".
Tokugawa Ieyasu
Randall Moffett
PostPosted: Sat 26 Nov, 2011 4:55 pm    Post subject:         Reply with quote
I have to say your project is amazing. I'd love to have one even without all the details you have added but they sure add something to the look of the entire harness. What an amazing piece of armour art.
Jonathan Ouellet
PostPosted: Sun 11 Dec, 2011 9:58 pm    Post subject: Gauge         Reply with quote
What gauge did you use for the chain mail?
Boris Bedrosov
PostPosted: Mon 12 Dec, 2011 8:28 am    Post subject:         Reply with quote
I used pre-fabricated maille. The wire is 1.4 mm with 8 mm inner diameter of the rings.
Tokugawa Ieyasu
Jonathan Ouellet
PostPosted: Mon 12 Dec, 2011 8:38 am    Post subject: Gauge         Reply with quote
Did you make the mail rings yourself or were they bought somewhere?
Boris Bedrosov
PostPosted: Tue 13 Dec, 2011 2:43 pm    Post subject:         Reply with quote
I didn't make it, but bought it from here
http://www.battlemerchant.com/
I think it's "Made In India", but regardless the quality is still good enough.
Tokugawa Ieyasu
Jonathan Ouellet
PostPosted: Tue 13 Dec, 2011 5:01 pm    Post subject:         Reply with quote
Thanks.
This is really impressive what you have done.
Do you think the design would be very similar if it was 13th century armour?
Boris Bedrosov
PostPosted: Sat 17 Dec, 2011 12:31 pm    Post subject:         Reply with quote
I don't think this design will be appropriate for 13th C. Ottoman armour or elsewhere in the Islamic world - it's quite well developed.
But it's possible some similar designs have been existed at that time. And if I could speculate a little bit more on this question, it's likely they all had been further development of the armour on this well known graffito of Parthian cataphract
in Dura Europus from 2nd C.
And it's recreation by late Angus McBride
taken from Osprey series (Man-at-arms #175 - Rome's Enemies (3) Parthians & Sassanid Persians by Peter Wilcox)
There are some more simple yushman designs, which protect only the abdomen but not the chest, and the oldest of them known to me is dated around the end of the 14th C. They look like this one
and regardless of the fact that this particular armour is dated to the end of the 15th C (around 1470-1480) the design is common for all of them.
Tokugawa Ieyasu
Jonathan Ouellet
PostPosted: Sat 17 Dec, 2011 4:36 pm    Post subject:         Reply with quote
Very interesting still.
Have you seen how well this armour stands up in combat? (SCA or other)
Boris Bedrosov
PostPosted: Sun 18 Dec, 2011 11:56 am    Post subject:         Reply with quote
We don't do SCA in Bulgaria.
Instead, we prefer to work in close contact during our re-enactment events. And this of course, demands high standards in both safety regulations and armours.
So my current Ottoman armour (you can see it in the very first post in this thread) is battle-tested in more than half-a-dozen occasions, where it proved robust and reliable, although it lacks flexibility of the new project.
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Sun 18 Dec, 2011 1:49 pm    Post subject: The Greaves - Continue         Reply with quote
These days I made a test-fit of the infantry greaves.
Because it was just a test, I didn't make the whole maille sections. From this test I figured out that they should be just a little broader, but generally - they are OK and I'm on a right way. I expect the greaves will fit almost like a glove Big Grin when the sections are once completed.
Here is a short series of picture, showing the left greave on. To check the fit better, I was in one of my boots.
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Thu 22 Dec, 2011 12:11 pm    Post subject: The Greaves - Continue         Reply with quote
The maille sections of the infantry greaves were refined and broadened by adding of an extra strip
The empty triangle will be filled with another extra strip. Now, its sharp tip is limited by three temporary rings, while the opposite base - with a strip. all these will be removed after the test-fit which followed.
The greave looks like this:
Yet another series of pictures of the second test-fit.
Tokugawa Ieyasu
Ruel A. Macaraeg
PostPosted: Thu 22 Dec, 2011 4:36 pm    Post subject:         Reply with quote
Boris,
Beautiful work. When you finish this Turkish armor and I finish my Tatar armor, I'd be honored to ride beside you for the glory of the Ottoman Empire. Wink
http://www.forensicfashion.com/1571CrimeanGuard.html
http://ForensicFashion.com/CostumeStudies.html
Sam Gordon Campbell
PostPosted: Thu 22 Dec, 2011 6:24 pm    Post subject:         Reply with quote
Ruel A. Macaraeg wrote:
... Beautiful work. When you finish this Turkish armor and I finish my Tatar armor, I'd be honored to ride beside you for the glory of the Ottoman Empire. Wink
Okay, so we have a Tatar, and a Turk. Now all we need is an Indian and a Mongol.
Also, I call dibs on being an Iberian Moor! Big Grin
Host of Crash Course HEMA.
Ruel A. Macaraeg
PostPosted: Thu 22 Dec, 2011 9:46 pm    Post subject:         Reply with quote
Hey Sam,
My historical loyalties are fickle -- even as I finish my Tatar kit, I'm working on several anti-Ottoman costumes too. I even recently did a Venetian-Dalmatian stradiot, that sworn enemy of the Turk in the Balkans. I go where the girls go! Surprised
And oddly enough too, while you're doing your Moor, I'm working on my Iberian cruzado knight ca. 1212. I'm a member of the Texas Medieval Association and next year's program focuses on the 800th anniversary of the Battle of Las Navas de Tolosa. There are several Spanish medievalists in that group and although I'm not one of them, I intend to be the center of attention! So far I only have the Arms and Armor Iberian Mace (from myArmoury's own Chad Arnow), but the rest should be easy to assemble.
http://www.forensicfashion.com/1590StradiotCa...1SFRF.html
http://www.forensicfashion.com/1212IberianCrusader.html
Boris Bedrosov
PostPosted: Fri 23 Dec, 2011 12:29 am    Post subject:         Reply with quote
Yes, why not! Big Grin
I think, it's always good to learn something more about the other cultures and civilizations, and particularly, like in the case of the wonderful myArmoury.com - about their arms and armours.
Really, I will be very glad, if someone shows here an Indian, or a Mongol, a Moor, a Japanese and ....... and so, and so. There are so many different warriors, who are relatively unknown.
Cheers! Happy Happy Happy
Tokugawa Ieyasu
Ruel A. Macaraeg
PostPosted: Fri 23 Dec, 2011 9:44 am    Post subject:         Reply with quote
For my part I've done Indian and Japanese kits before. I have many Indian and bellydancer friends, which are opportunities to wear the Indian costumes, while I occasionally wear my samurai and ninja costumes to seasonal Japanese events.
Of course Boris, my samurai armor is inferior to yours -- mine is the "Oda Nobunaga" suit formerly sold by Hanwei. I enjoy it though, and it always gets a very positive response from the crowd.
http://www.forensicfashion.com/1858RajputPrin...YHY10.html
http://www.forensicfashion.com/1568JapaneseSa...tival.html
http://www.forensicfashion.com/1581JapaneseNinja.html
Page 13 of 26 Reply to topic
Go to page Previous  1, 2, 3 ... 12, 13, 14 ... 24, 25, 26  Next All times are GMT - 8 Hours
