Matthew Amt
Posted: Mon 14 Sep, 2009 8:17 am Post subject: |
Wow, great stuff, here! It should be pointed out that there were instances in the American Revolution of the "wiley Americans firing from behind rocks and trees" at the British. Most notably this happened at the start of the war as the British retreated back to Boston after Lexington and Concord. The woods on both sides of the road were swarming with American militiamen, often firing from very close range with their weapons resting on fences or walls. And yet it is estimated that only one out of every 300 bullets actually *hit* a British soldier! Granted, these were very over-excited and inexperienced militia, but THAT's inaccurate shooting! For a while during that action, the British were able to clear the woods out temporarily with a sweep of light infantry, who were all had bayonets and were trained to use them. Remember, any line of skirmishers or even line infantry spread out in open order, with or without cover, are going to be at a huge disadvantage when two ranks of troops in close order with bayonets fixed arrive!
Frederick the Great did some experimenting with musket fire, with smaller or larger volleys. He apparently found that if his troops fired by company or platoon, small volleys in fairly quick succession down the line, he could kill a lot more of the enemy. But if he had whole regiments or brigades fire at once, the psychological impact more than made up for it!
Even with prepared paper cartridges, it can be difficult to load a musket consistently in action. Tear the paper too far, and powder is spilling all over the place. Dump too much in the pan, for starters, and there isn't much left to go down the bore. So your bullets might not have enough force to kill. One officer in the Seven Years War was struck seven times during a battle by spent balls! One gave him a painful bruise inside his elbow. It was also common to fire too high, sending shots over the enemy's head. Pull your muzzle down to counteract that, and you may just be firing into the ground at their feet.
Basically, those tight ranks of men served the same function as a machine gun: put a lot of lead in the air, and even if you don't hit something you might scare it off. How many bullets from a machine gun actually hit a soldier? Darn few! But we don't call it a dumb weapon, by any means.
Valete,
Matthew
Walter Stockwell
Posted: Mon 14 Sep, 2009 8:20 am Post subject: |
The book "On Killing" by David Grossman had an interesting perspective on this. His thesis is that most people don't want to kill. Battles were won by getting the other side to break ranks and run -- this makes it psychologically much easier to kill the enemy running away. He cites some period tests where musket fire at X range should have hit Y% of the opposing line when in fact typical battles only showed hit rates of 1/10th the expected rate. He thinks this came from soldiers firing over the other line, trying to break their morale. Apparently this was also shown to be a factor in WWII, which led to new training methods in the US Army. Very interesting book, well worth a read.
http://www.amazon.com/Killing-Psychological-C...0316330116
Walter
www.stockwellknives.com
Posted: Mon 14 Sep, 2009 12:21 pm Post subject: |
Walter Stockwell wrote: | The book "On Killing" by David Grossman had an interesting perspective on this. His thesis is that most people don't want to kill. Battles were won by getting the other side to break ranks and run -- this makes it psychologically much easier to kill the enemy running away. He cites some period tests where musket fire at X range should have hit Y% of the opposing line when in fact typical battles only showed hit rates of 1/10th the expected rate. He thinks this came from soldiers firing over the other line, trying to break their morale. Apparently this was also shown to be a factor in WWII, which led to new training methods in the US Army. Very interesting book, well worth a read.
http://www.amazon.com/Killing-Psychological-C...0316330116 |
Also why elite special forces who will make most shot count by actually trying to kill someone can have a disproportionate effect to their low numbers in certain battlefield situations.
Or, 100 veteran soldiers who shoot to kill are going to be more effective than 1000 soldiers where maybe less than 10 % will actually do more than just shoot in the general direction of the enemy without really aiming and of which many of the 1000 will actively be aiming over rather than at the enemy.
Skill multiplied by ruthlessness being more effective than numbers divided by not really wanting to kill.
Lin Robinson
Posted: Mon 14 Sep, 2009 7:33 pm Post subject: |
Barry C. Hutchins wrote: |
Flash guards, originally for flintlocks and later for percussion, reduced the danger from the ignition of the firearm next to you.
It is also a bit of a myth to suppose that smooth bore Muskets, Fusils, Fowlers, etc are inherently inaccurate; if the ball/projectile is properly sized to the barrel, ball/projectile weights consistent from ball to mall, consistent powder charges, a smooth bore can often match a rifled muzzleloader for accuracy out to 50 yards and certainly makes the smoothbore capable of lethal accuracy in the 75-100 yard range.
The biggest detriment to accuracy is the fouling of the barrel by the blackpowder resulting in extreme accuracy degradation as subsequent shots were fired. In some cases this meant that smooth bores had an edge over rifles in longer engagements where many shots were exchanged as they were somewhat less susceptible to the fouling. |
Flash guards are a late invention and as far as I know, were not used during the 18th C. They are required by most reenactment units for safety sake. Without them the man standing to your right, especially if he looks to his left ala some of the scenes in The Patriot, will get a face full of powder residue and gas.
The inaccuracy of smoothbore firearms is not much of a myth. Take that from someone who has owned and fired them for many years. You include a lot of "ifs" in your comment about accuracy but in battle, using smooth bores, all that takes a back seat to volume of fire, as has already been said here. I will put my money on the rifle or even a "smooth rifle" over a musket any time, although smoothbores can be made to shoot quite accurately, again using the "ifs" you refer to. However the thread is concerned with their use in the military.
Fouling makes it difficult to load smoothbores and difficult loading can certainly affect accuracy. However, the chief problem with smoothbores, as has been mentioned in this thread is the necessarily loose fit of ball to barrel, to facilitate loading with paper cartridges. Bullets for muskets loaded with paper cartridges can be more than .050 inches smaller in diameter than the bore. In that case, the cartridge paper rammed down with the ball provides some grip on the inside of the barrel but not anything like you find with a patched round ball in a rifled firearm.
Lin Robinson
James Holczer
Posted: Tue 15 Sep, 2009 9:46 am Post subject: |
Tom L. wrote: |
We can all agree that despite infantry being forced to fight in lines out of necessity, 18th and 19th century warfare was not as simplistic and stupid as Hollywood shows it. After all, did not phalanxes and pike blocks have exposed flanks? Are such tactics to be called stupid? The Scots got butchered at Falkirk by archers as they held their ground in their circular formations against the English and no one has questioned how the Scots fought. And in WWII, many Allied tankers died because US doctrine stated that tank destroyer units were to take out enemy tanks by means of using fast and lightly armoured tank destroyers while standard tanks were to act as armoured, mobile artillery support for infantry. The end result was that the Western Allies had tanks and tank destroyers that were inferior in terms of armour and fire power when compared to German tanks and it took an average of 6 US Shermans to have any success against a German Tiger tank and the experts were prepared to lose 4 Shermans to every 1 Tiger. That was from modern warfare and that to me sounds pretty insane. |
I believe the reasons for the acceptable loses of 4 Shermans for one tiger were that tiger I or the tiger II variant were actually few and far between on the battle field. Between 1942 and 1944 only about 1300 tiger I variants were produced and they were spread out between North Africa the eastern and western fronts. They were extremely expensive to produce and highly prone to mechanical failure. Due to their size and weight they didn’t cover ground as well as the lighter allied tanks and once broken down were next to impossible to tow or move. They were also too heavy form most rural bridges in Western Europe which further hampered their mobility. Most ultimately ended up as stationary artillery and if left out in the open were easy prey for air cover. With the exception of the few weeks following D-day and the battle of the Bulge the odds of allied armored battalions encountering tigers were small. Allied command took the tact that the Sherman and its endless variants were cheap to produce and plentiful. They were also more than a match for the lesser German battle armor such as the panzer III and IV which were more commonly used in France. The actual effectiveness and reputation of the tiger is partly myth where the actual truly impressive German Battle tank was the Panzer V or panther. In fact it was the Panther that provided the blue print for all subsequent Western armor in the post world war era.
Lin Robinson
Posted: Tue 15 Sep, 2009 10:02 am Post subject: |
James Holczer wrote: |
I believe the reasons for the acceptable loses of 4 Shermans for one tiger were that tiger I or the tiger II variant were actually few and far between on the battle field. Between 1942 and 1944 only about 1300 tiger I variants were produced and they were spread out between North Africa the eastern and western fronts. They were extremely expensive to produce and highly prone to mechanical failure. Due to their size and weight they didn’t cover ground as well as the lighter allied tanks and once broken down were next to impossible to tow or move. They were also too heavy form most rural bridges in Western Europe which further hampered their mobility. Most ultimately ended up as stationary artillery and if left out in the open were easy prey for air cover. With the exception of the few weeks following D-day and the battle of the Bulge the odds of allied armored battalions encountering tigers were small. Allied command took the tact that the Sherman and its endless variants were cheap to produce and plentiful. They were also more than a match for the lesser German battle armor such as the panzer III and IV which were more commonly used in France. The actual effectiveness and reputation of the tiger is partly myth where the actual truly impressive German Battle tank was the Panzer V or panther. In fact it was the Panther that provided the blue print for all subsequent Western armor in the post world war era. |
James...
You hit the nail squarely on the head. In a one on one encounter the Tiger was superior. However, it was not invulnerable, nor was it easily or quickly replaced, as were the "Ronsons" used by the allies.
Lin Robinson
Tom L.
Posted: Tue 15 Sep, 2009 4:21 pm Post subject: |
The reason I brought up the loss rate that the allied command was willing to accept for Shermans as being madness was because they only took material losses into account. Tanks are easy to replace but crew members are not. Things got bad enough for the British that they started to get rid of the AA tank units and redistributed those crew to replace tanker casualties. Allied air superiority made this relatively easy to do.
Sure there were relatively few Tigers or Panthers, but such was the effect of those tanks that any German tank was seen as being a Tiger due to the fear that they inspired. The Tiger's strenghs caused a form of inferiority complex amongst Allied tank crews because they soon found out that their equipment was not on par with that of the Germans. The Tiger therefore made up for its lack of numbers by means of its reputation. Panzer IVs were more numerous and were still more than a match for a Sherman but they did not have the same psycological impact as a Tiger.
The idea of saying that the war could be won with a loss ratio of 4 Shermans to every 1 Tiger is madness to me because it doesn't even touch on the effect of crew lost rate. The Sherman was famous for "brewing up" easily after being hit. Admittedly, this was probably due to the crews stuffing the tanks full of ammo in whatever space was available. Tanks in the British Guards seem to not have suffered as much brew ups from hits due to their being more disciplined and storing ammo in the alotted bins only. Research back then showed that whenever a Sherman got hit, it was the ammo that burnt first and then the fuel. Sherman crews saw death around them everyday and also knew that their tanks were not up to the job. Things got so bad that crews were liable to abandon their tanks when hit; even if the hit was not serious. The loss rate was starting to wear down on the men and that was something that high command seemed to ignore.
Of course, things were made worse when the British upgunned some of their Shermans with the 17 pounder which proved to be capable of taking out Tiger tanks. The gun was offered to the US but was rejected for some reason. Why reject the 17 pounder but not the Rolls Royce Merlin engine? After all, it was the Merlin that powered the legendary P-51 Mustang. The Americans went with the long barreled 76 mm as a replacement for the short barrelled 75 mm but for the longest time, did not offer tank crews the high performance armour piercing round that the tank destroyer units had.
So for me, in regards to the Sherman, policies were made that appeared to willingly put human lives at risk due to badly thought out doctrines and cold hearted methematics that did not factor in the human cost.
But enough on tanks: bring on the muskets and bayonets, waistcoats, gaiters, powdered hair, tricorns, shakoes, neck stocks and crooked colonels buying cheap shoes just so they can pocket the remainder of their govenrment allowances.
I have a cunning plan Mr. B.
Bryce Felperin
Posted: Tue 15 Sep, 2009 6:10 pm Post subject: |
I was a bit mystified at the turn this subject took...but the last entry has brought it back. Basically the adherence to doctrine, even if it is obsolete, causes more casualties and loss of morale in the long run than it gains in the short run. In this case the use of Tank Destroyers as the means to kill German tanks in WWII when it was long proved obsolete and the use of massed infantry formations even after rifled muskets made those formations death traps can be connected.
Usually the side that gives up the outdated doctrines of the past first (like the Germans did versus Poland early in WWII) prosper better in war.
Jason Daub
Posted: Tue 15 Sep, 2009 6:55 pm Post subject: |
Rifled muskets may have made those formations death traps, but what was the alternative? For nearly the entire existence of cavalry the guiding rule was that infantry in open formation was meat to the horseman. The true death knell for horse cavalry was the birth of the machine gun and quick firing artillery, and muzzle loading small arms simply lacked the rate of fire necessary.
Up until that point cavalry was still a viable arm, "von Bredow's Death Ride" convinced an entire generation of military theorists that cavalry could still be useful. "After all the Prussian cavalry at Mars-la-Tours faced the latest rapid fire weapons, among the the Chassepot (ROF 10-12 rounds per minute), the Reffye mitrailleuse (125RPM), and the Reffye 85mm cannon and still triumphed albeit at a very high cost but they were unsupported", seemed to be the thinking. I cannot think of a single battle between the Western European powers where infantry stood off cavalry without being in a "close order" formation of some type or well defended by field fortifications.
This is a few centuries out of my main area of interest, so if I am wrong, please clarify it for me.
'I saw young Harry, -with his bevor on,
His cuisses on his thighs, gallantly arm'd,-
Rise from the ground like feather'd Mercury,
And vaulted with such ease into his seat,
As if an angel dropp'd down from the clouds,
To turn and wind a fiery Pegasus,
And witch the world with noble horsemanship.'
Robin Palmer
Posted: Wed 16 Sep, 2009 1:35 pm Post subject: |
Hi all one of the post mentioned that fredrich the great used firing by companys which was also used by the british army in the napolionic war possibly earlier. Its biggest asset was it allowed the enemy to be subject to a continuious hail of fire which made keeping order and line difficult both key. Its moral factor has been mentioned. One point not raised is the fact that even under ideal conditions the average musket could be expected to missfire 1in5 shots. The more shots fired the higher the odds by keeping the number down closing fire one or two then charging the odds were good of all the guns firing.
Posted: Wed 16 Sep, 2009 3:35 pm Post subject: |
Robin Palmer wrote: | Hi all one of the post mentioned that fredrich the great used firing by companys which was also used by the british army in the napolionic war possibly earlier. Its biggest asset was it allowed the enemy to be subject to a continuious hail of fire which made keeping order and line difficult both key. Its moral factor has been mentioned. One point not raised is the fact that even under ideal conditions the average musket could be expected to missfire 1in5 shots. The more shots fired the higher the odds by keeping the number down closing fire one or two then charging the odds were good of all the guns firing. |
Firing by company probably helped in keeping the smoke from completely obscuring the enemy line if firing was for an extended amount of time ? A windy day also being useful in clearing the air ?
