His position in a nutshell;
That plate armor, while protective also has severe weaknesses, particularly against direct thrusts from swords, and Longbows. On swords, he cites seeing numerous techniques whereby the swordsman pierces the plate either on a direct thrust standing up, or thrusts through the breastplate after getting the opponent on his back.. As for longbows, his argument is that a decent hit from a longbow will essentially punch straight through plate armor unless it's essentially the "very, very best" that's available. To support this, he cites having used 60lb draw longbows to penetrate through both sides of a steel can, and through an inch of pinch with training tips. As well, specific citations from the siege of Abergavenny whereby the welsh longbow penetrates the four inch thick oak doors of the castle.
When it comes to longbows and crossbows, his argument is that a longbow is 'generally' a better weapon than a crossbow. These superior traits lay in superior force, firing rate, and range. As for force, while he admits the crossbow has a superior draw weight, he also states that the longbow is more efficient at transferring force from into the arrow by virtue of the longbow having a longer draw. Due to this, a longbow with a draw strength of 60 pounds will be more powerful than a crossbow with a draw strength of 200 pounds. short; a longbow is a better weapon for fighting armored opponents than a crossbow is, and the primary advantage, which why it was much more popular in Continental armies than a longbow, lays in the fact that you can easily train a person to use the crossbow, despite it being an inferior weapon. The length of time it takes to become a proficient archer is also what he cites as the trait that prevented it from creating something of a proto "Gunpowder revolution".
My position in a nutshell;
That plate armor is incredibly protective, and 'nigh invulnerable' to certain things. For instance, no sword is going to adequately pierce straight through adequately made plate armor, so you have to strike "where he is not proof". As in, at the visor, joints, or in particular the armpit. For sword techniques, I cite numerous techniques from the Fechtbuchen, and modern interpretations of those techniques. In short, the crossbow is a better anti-armor weapon, with the Longbow being sufficient to semi-reliably penetrate earlier plate forms with direct fire, and perhaps Maille based armor defense. Likewise, most of the great victories of the English can be attributed to periods when the primary form of defense was either a plate supplemented suit of maille, or early plated armor which was not as 'sophisticated' as later styles of plate armor (As in, hardening and tempering), and despite this the majority of the arrows would not have penetrated these defenses. Later on, I maintain that the Longbow actually became obsolete, with armor technology surpassing it'd ability to achieve sufficient penetration by the 1420s-1430s. This is also near the time when the tide of the Hundred Years War started to turn against the English.
Frankly, what we're looking for in particular is a verification of certain points above, and a general assessment of the values of the longbow and the crossbow, as well as their combat efficacy (In particular, armor penetration). As well, a verification on the ability to reliably penetrate plate armor on a thrust from a sword(Either one or two handed, any contemporary sword form will do).
A further explanation of his points in his words;
| Quote: |
| From the articles and historical accounts I have read, plate armour seems to have had a broad range of effectiveness. I have read accounts of men being killed, either in battles, or in single combat, when someone put a sword or an arrow through their chest. I have also seen references to plate armour capable of soaking a hit from an early firearm, though most such references deride said armour as impractically heavy, and the entire idea seems to have been scrapped relatively quickly.
According to the battle accounts I have read from the hundred years war, English archers could stop a cavalry charge with about six volleys by killing the horses at long range, and the men if they were dumb enough to keep coming closer. To my mind then the question is how thick did armour have to be to be impervious to non-mechanically augmented weapons (swords, bows, and simple crossbows) and just how common was this kind of armour on the battlefield. Most everything I have heard has indicated "thick" and "not below the upper crust of the nobility." It has been several years, however, since I have had time for intensive reading on the subject, so I am definitely interested in any new information which may have surfaced. |
