Forum Index > Off-topic Talk > Testshooting results please Reply to topic
This is a standard topic Go to page Previous  1, 2, 3  Next
Anders Nilsson
Reading list: 4 books
PostPosted: Thu 17 Jan, 2008 9:13 am    Post subject:         Reply with quote
Judging by the angle he was shoot from the most probably shoot came from a Norwegian fort.
There is an interesting theory that it was a Swedish bullet fired from a Norwegain cannon. The siege had been going on for a while and the Norwegians was running out of grapeshoot. So they gathered Swedish musketballs that had been fired their way and used as grapeshoot.
It makes sence since the King was in a new trench that was to be used for a coming assualt, ie he was fairly close.
Colin F.
Reading list: 10 books
PostPosted: Fri 18 Jan, 2008 8:55 am    Post subject:         Reply with quote
http://www.cotasdemalla.com/test2.htm
Would this be of interest to you?
Melchett - "In short, a German spy is giving away every one of our battle plans."
Cpt. Darling - "You look surprised, Blackadder."
Edmund - "I cerainly am, sir. I didn't realise we had any battle plans."
Peter G.
PostPosted: Fri 18 Jan, 2008 11:03 am    Post subject:         Reply with quote
We discussed this topic ad lenght prior christmas.
A musket is cheaper, the ammunition can be made in field and the hitting power is greater.
A bow is far more accurate, has a far higher firerate and a higher effective range.
The musket replaced the bow not because it was the superior weapon but because you can train every numbnut to stand in line and fire a musket in about 3-4weeks.
To train a bowman it takes years and years of training.
As late as the napoleonic wars the forming of a bowmen-regiment was proposed-it never happend due the lack of skilled soldiers-but considering the effective range and the firerate i would allways bet on the bowmen.
PostPosted: Fri 18 Jan, 2008 12:08 pm    Post subject:         Reply with quote
Napoleonic generals considered a longbow regiment because the English were still deluded about the mythical superiority of the longbow (many still are today). By the time of the English civil war firearms are superior to the longbow in every way that counts on the battlefield.
Peter G.
PostPosted: Fri 18 Jan, 2008 1:22 pm    Post subject:         Reply with quote
They considered it because of the far superior firerate and the far superior effective range-nothing mythical about that.
As discussed in the other thread-the firearms were NOT superior "to the longbow in every way that counts on the battlefield"-they were just far cheaper to make and far faster to manage to a usefull degree.
Nick B.
PostPosted: Fri 18 Jan, 2008 1:38 pm    Post subject:         Reply with quote
Unless the battle is taking place in the rain. Ever hear the old saying "keep your powder dry".
Peter G.
PostPosted: Fri 18 Jan, 2008 1:40 pm    Post subject:         Reply with quote
Rain isn´t good for bows either -they still fire but with much less power :-)
Werner Stiegler
PostPosted: Fri 18 Jan, 2008 1:55 pm    Post subject: Re: Testshooting results please         Reply with quote
Anders Nilsson wrote:
There is a discussion about the old bow vs musket going on and I get just tired. Many thinkt that the bow is superior. I will onces and for all prove for them that the musket is superior to the bow.
Test shooting results of the Steiermärkische Landeszeughaus Graz from 1988 were something like this:
50:50 chances to hit a man-sized target on 100m with a musket, result vary even more widely with rifled blackpowder weapons. The three tested rifled guns performed worse (test was halted because the weapon endangered the onlookers), much better (83% chance to hit) and about as good as the smoothbore guns(52.5%). The two pistols tested on 30m were found to have 83% and 99% chance on hitting the target.
You can look it up in "Weapons&Warfare in Renaissance Europe" by Bert S. Hall.
Nick B.
PostPosted: Fri 18 Jan, 2008 2:04 pm    Post subject:         Reply with quote
Less power is better than no power. A musket makes a very poor spear if it won't fire.
Peter G.
In the other thread i posted the results of various testshootings from 1800-1830
check in this thread
http://www.myArmoury.com/talk/viewtopic.php?t...highlight=
After testing rifles/"brown bess"muskets Col George Hanger-expert marksman stated in 1814 :
"A soldiers musket, ... will strike the figure of a man at 80y, it MAY even at 100, but a soldier must be very unfortunate indeed who shall be wounded by a common musket at 150y, provided his antagonist aims at him. And as to firing at a man at 200y you may as well fire at the moon and have the same hope of hitting your target. I do maintain and will prove..that NO man was ever killed at 200y by a common musket by the the person who aimed at him"
In 1841 the British army tested the brown bess: the range was between 100 and 700y(acc to elevation)-at EVERY elevation there was between 100 and 300y variance.
Shootingtest at a target representing a LINE of cavalry(slightly taller then a single human):
100y : 53%hits(trained men) 40%(ordinary soldiers)
200y. 30% """ 18% """
300y : 23% """ 15% """
we a talking of a target about 3y high and 75-100y wide under best conditions--no fog of war, no ennemies shooting at you, no haste in reloading...
quote after "weapons and equipement of the napoleonic wars" by Philip Haythornthwaite
[/quote][/url]
PostPosted: Fri 18 Jan, 2008 2:08 pm    Post subject: Re: Testshooting results please         Reply with quote
The performance with a rifled barrel would depend on many things like using the right size of ball projectile or conical projectile and the rate of rifling matching the projectile chosen. Also, optimizing the powder charges and consistent loading.
I assume this test was with period weapons and not reproductions and that these would be sensitive to the state of the bore and rifling ? Also, the calibre if not matched to the ideal size off projectile would produce erratic results.
The quality of the sighting on the barrels would also make a difference: No sights or just a front sight on a smooth bore would limit accuracy potential no matter how good the inherent accuracy of the musket might be.
Museum curators doing such a test would have to have good expertise shooting blackpowder weapon, otherwise the results would be inconclusive no matter how otherwise qualified they might be as scholars !
Nick B.
PostPosted: Fri 18 Jan, 2008 2:26 pm    Post subject:         Reply with quote
Another disadvantage to the musket is, if you're shooting from cover the smoke will give away your location.
Elling Polden
PostPosted: Fri 18 Jan, 2008 3:05 pm    Post subject:         Reply with quote
The practical range for a musket was assumed to be about 75 yards. At 40-50 you could be quite certain to hit a man sized target. If your sights are on.
It is a established fact that the practical accuracy of a weapon is determined to a large degree by the velocity of the projectile.
A faster projectile has a flatter trajectory, which means that you will not need to adjust elevation as much.
Essentially, a modern rifle has a "grassing" range of several hundred meters.
If you aim straight at someones chest at 200 meters, you will still hit him, without having to worry about elevation.
Once fired, the bullet threatens everything in its path out to 300+ meters, for a 7,62x51
A longbow, however, will need to be elevated to near45 degrees to reach 200 meters at all.
And when the arrow comes down, it threatens a space of maybe 15 cm, since its trajectory is so steep.
Is kind of trying to hit a single man with a cold mortar shell.
In short, you have to aim in three dimensions instead of just one, with a weapon without sights, at a trajectory so high that you can't even see the target when shooting. Add flight time, and a extreme susceptibility to wind.
Then add the stress of combat, and the tendency of combat troops to just fire in the general direction of the enemy.
In sufficiently large numbers, longbows might actually hit something at long range. However, so would muskets, and especially, cannon.
Also, disciplined infantry will advance into machinegun fire if ordered to do so, as amply illustrated in WW I.
Thus, longbows would not be able to break or rout foes on their own.
At close range, musket accuracy is a matter of point and click. Even if the balls scatter 10+ cm at 50 meters, you still hit.
ROF is lower, but since the regiment is marching in ranks anyhow, you can still keep up the fire.
And, musketmen, in the knowledge that their accuracy only improves as they close, will walk right up to enemy formations.
To my knowledge, noone has ever fielded archers as line infantry. Quite possibly because archers need a stable firing position, and will rout if enemy infantry come into charge range.
Basically, if using longbows on the battlefield was such a great idea, it would have been done.
Ian Hutchison
PostPosted: Fri 18 Jan, 2008 5:22 pm    Post subject:         Reply with quote
The following was done by Pete Plunkett of Middlesex Village Trading Company. He used a Charleville 1777 and fired 5 shots from 50 yards. Not bad, if I do say so myself. Keep in mind, most military muskets had no sights, at least no rear sights.
Results:
 Attachment: 67.02 KB
Peter G.
PostPosted: Sat 19 Jan, 2008 1:49 am    Post subject:         Reply with quote
With a longbow you can start ballistic fire at about 400m-like in crecy.
If you assume that an average longbowman can fire about 8-10arrows/min a 1000men-regiment can fire 8000-10.000arrows/min at a regimentsize target-no need to fire at individual soldiers-you´ll hit anything anyway.
At 200m range the best marksmen switch to aimed fire, the lesser bowmen at about 150m
A regiment in line needs some time to march the 350m to the 50m range which was considered a good range for musket-fire.
In all this time, they receive 1000arrows/5-8sec without the possibility of counterfire-and opposed to muskets an arrow after ballistic flight still has enough hitting power to kill an anarmoured ennemy.
I doubt that the attaking regiment would force the march-and if i doubt that more then 400 would reach the 50m range-then they still would be outshoot by the arrows-maybe not in hitting-power, but in firespeed-thats whats counts.
As said in the older threat-the musket replaced the bow because
-it was cheaper
-it was far far easier to handle(2 days of training against years and years)
-unlimited supply of recruits (NO skill needed)
-logistics far easier
Ammonition for muskets is easily made in field, needs easy to get compounds and doesn´t weight a lot.
Arrows are slow to make, needs specialists to produce, needs good wood and good feathers and is heavy.
At waterloo several millions of bullets were fired-this wouldn´t have been possible with arrows due to lack of supply.
Reading list: 7 books
PostPosted: Sat 19 Jan, 2008 2:21 am    Post subject:         Reply with quote
And soldiers of the Gunpowder Age have a whole bag o f tricks for keeping their powder dry and their match lit in all but the heaviest sorts of rain...
An arrow is a lot bigger than even the largest musket ball, and it will give away your location too--any warrior with half a brain would be able to figure out where it came from once they had seen its general flight path!
The English longbowmen? They were line infantry in the sense that they did engage in hand-to-hand combat against the formidable French men-at-arms. Of course, this ability to join the hand-to-hand fighting was precisely the thing that differentiated them from other archers, and probably their success depended on their ability to employ both archery and hand-to-hand fighting skills rather than just one of the two.
Playing the devil's advocate is fun ;P
PostPosted: Sat 19 Jan, 2008 12:21 pm    Post subject:         Reply with quote
Longbows are useful only in a defensive position if the men have a chance to prepare the ground. As soon as you dislodge an archer from his position he becomes a poorly armed skirmisher. In a Napoleonic battle where manoeuvre is key they would be an unmitigated disaster. Massed longbows could be very effective at slowing or halting a cavalry charge (the whole reason why they were introduced in the first place) but only if they lucked out and guessed the direction of the attack beforehand. The so called rate of fire advantage would be worthless after they ran out of arrows in the first five minutes and artillery outranged longbows by a considerable margin.
Stephen Hand
PostPosted: Sat 19 Jan, 2008 2:31 pm    Post subject:         Reply with quote
What will it take to finally kill this bizarre fantasy that the collective states of Europe nearly bankrupted themselves replacing bows with weapons that were inferior. They did not. Muskets are more effective than bows. They have the same effective range (show me one scrap of evidence that this is not true) and a far greater maximum range (bows habitually shooting at 400m range??? This is over 100m longer than the longest recorded bowshot that Hardy could find when writing his book on the longbow). Muskets have many, many times the stopping power. Muskets cost far more (English records from 1596 show the government paying between 12s and 30s for arquebuses and muskets compared to 6s8d for longbows) yet replaced bows anyway. Muskets are far, far more accurate than bows. I have seen a lot of musketry and a lot of archery and I have always been surprised by how much more accurate any sort of firearm is to a bow at any range, even when comparing people who barely shoot muskets vs archers who train all the time. The advent of the musket led to more training, not less. The myth of the poorly trained conscript musketeer is just that, a myth.
Eyewitness accounts that I put up here just before christmas talk about armoured men walking unscathed through English arrow storms, while similar formations were not just defeated, but obliterated by musketry. The difference in effectiveness between archery and musketry against almost identical targets under perfect firing conditions at the battles of Flodden (1513) and Bicocca (1522) is so stark that I can not believe that any rational person could discount it. The introduction of guns resulted in a massive increase in battlefield casualties. Between 1550 and 1650 average battlefield casualties in Europe went from 7% to 17%.
The idea that every state in Europe suddenly started spending over 75% of their GNP to obtain new weapons because they wanted their armies to be less effective is one of the most pernicious fantasies in the study of military history. No matter how many times it is proved false, and not just false, utterly ludicrous, it manages to rear its ugly head, again and again.
Muskets might not be as pretty or as romantic as bows, but they are undisputably more effective. Get over it!
Stephen Hand
Editor, Spada, Spada II
Stoccata School of Defence
PostPosted: Sat 19 Jan, 2008 11:14 pm    Post subject:         Reply with quote
Steven;
Real World, real history and factoring in all the variables including artillery cancelling out any theoretical advantage the bow might have ( rate of fire mostly assuming a huge supply of arrows ) I completely agree.
And this type of comparing of " theoretical " weapon systems is something I find fun finding the pros and cons and relative advantages or disadvantage of these weapons systems if we could set up a simulated battle between them.
Were this can go wrong is in taking it too seriously or trying to prove that real history got it wrong. Wink Laughing Out Loud
Without repeating much to much information that one can just read in the other thread, my conclusions were that there was a rock, paper, scissors relationship between the way archery and musketry would very " theoretically " interact:
1) Against armoured troops the musket is much more effective, to the point that armour becomes useless and is no longer used.
2) Against armoured troops archery's effectiveness is much reduced but still better than nothing before a better weapon came along. ( firearms ).
3) In an 18th century context the use of armour is not a factor so the bow could have been effective in " theory " but only for one or two battles as effective counters would have been easy to find. ( Read at the end of my post ).
Artillery's range would cancel out any possible archery advantages except in very limited tactical scenarios. ( Ambushes, irregular warfare: Think Zulus against the British and replace archery with spears and closing to hand to hand fighting ).
As to the feasibility of creating an archery regiment in the 18th century, all the reasons that it wouldn't have worked in practice have been stated already. ( Or not cost effective even if possible ).
My original " Thought Experiment " was about a simulated battle were unarmoured late 18th century troop using muskets would fare against the best of the 14th or 15th century archers supported by armoured foot soldiers and men-at arms. The psychological factors involved in a real life version of this simulation being factored out.
( Need a time machine or a computer simulated gaming version of this to make it work. Wink )
So, again, as a " Thought Experiment " either one finds this amusing or one is appalled if people try to apply the idea to real history. ( Stephen I guess that this is your reaction to the whole discussion !? ).
COUNTERS to the archers that could/would be used after the first initial battle.
1) Range issue: Practical musket range shorter than the bows where the bow's accuracy and rate of fire factor in, but the maximum range is much greater with the musket, so I would use long range musket fire supported by artillery out of range of the archers and avoid closing until the archery formations are decimated.
2) There is NO #2 as number one sort of takes care of the problem.
Glennan Carnie
PostPosted: Sun 20 Jan, 2008 2:43 am    Post subject:         Reply with quote
I spend a large proportion of my time studying and shooting heavy draw-weight medieval English war bows. I'm lucky to count among my friends some of the finest warbow archers in the world. So one might assume my position is somewhat biased.
That said, I agree completely with Stephen's statement and sentiment.
Military technology exists to aid projecting political power. There is no place for romanticism in politics.
Page 2 of 3 Reply to topic
