Forum Index > Historical Arms Talk > Opposite Fullers Reply to topic
Eric W. Norenberg
PostPosted: Fri 01 Aug, 2008 5:27 pm    Post subject:         Reply with quote
I noticed that a link to Mr. Kelly's essay on blade geometry had been added to my original post, which I had read some time ago, but a re-read made me notice the "opposed fullers" illustration - fullers cut offset into opposite sides of the blade. I don't believe I've ever seen this on a historical example; granted, I usually only get to see whichever side is up in the museum display, but I've never noticed a fuller or grouping that was off-center. What time period is that fuller arrangement common to? It seems like a tricky way to cut fullers into a blade without sacrificing the thickest part, if someone were trying to tune up a blade that can't afford to loose any spine thickness.
I don't suppose anyone has seen something like that on a type XVIII or XVa...?
Thanks again!
Eric
PostPosted: Fri 01 Aug, 2008 6:05 pm    Post subject:         Reply with quote
Opposing fullers are mostly found on very late-period swords dating 18-19th century. You won't find it on an Oakeshott Type XVIII or Type XVa because, then, it wouldn't be of that type any longer.
G Ezell
PostPosted: Fri 01 Aug, 2008 8:02 pm    Post subject:         Reply with quote
http://www.oriental-arms.co.il/item.php?id=2746
I've only seen them one double-edged blades from the Caucasus area, the kindjal and qama are two types that often have them. I'm not sure how far back these designs go, but I've always had a fondness for them.
http://www.oriental-arms.co.il/item.php?id=2726
