Forum Index > Off-topic Talk > Seems like there have been some good discoveries of late! Reply to topic
This is a Spotlight Topic Go to page Previous  1, 2, 3 ... 20, 21, 22
Carl W.
PostPosted: Fri 30 Aug, 2024 9:11 pm    Post subject: said to be Roman ship bronze ram         Reply with quote
I did not search to see if other reports
https://www.finestresullarte.info/en/archaeology/new-bronze-rostrum-recovered-in-the-egadi-sea-discovery-of-historical-treasures-continues
Anthony Clipsom
PostPosted: Sat 08 Feb, 2025 6:41 am    Post subject:         Reply with quote
An find of migration era weaponry in Denmark, which may be of interest
https://www.medievalists.net/2025/02/iron-age-weapon-denmark/
More information here
https://www.vejlemuseerne.dk/udstillinger/digitale-udstillinger/vaabenofringen/the-weapon-sacrifice/
Anthony Clipsom
Ryan McLaurin
PostPosted: Sat 12 Apr, 2025 8:34 pm    Post subject:         Reply with quote
https://tvpworld.com/85908311/3000-year-old-ornate-dagger-found-on-polands-baltic-coast
Craig Johnson
Likes: 16 pages
Reading list: 20 books
PostPosted: Tue 24 Jun, 2025 9:45 am    Post subject: Early Medieval river find with some great detail         Reply with quote
Here is a new one that just came up after conservation. I beautiful sword with some interesting detail in the blade.
Dutch Sword Find
Best
Craig
Len Parker
PostPosted: Thu 10 Jul, 2025 8:42 am    Post subject:         Reply with quote
5th century Roman spatha with pommel: https://www.livescience.com/roman-soldier-buried-with-folded-sword.html
Blaz Berlec
PostPosted: Wed 10 Sep, 2025 9:15 am    Post subject: New sword find in Slovenia         Reply with quote
In pretty bad shape, and without the pommel. By the blade and guard shape and width I'd say early medieval - 9 - 10th century? But the tang is almost 14 cm long, so it seems way too long for that era sword?
Medieval sword discovered in Sempeter in the Savinja Valley during the construction of a roundabout
On Friday, August 29, 2025, workers from the company VOC Celje, and a representative of the contractor Roman Meh s.p. discovered a sword during earthworks and immediately notified the Celje regional unit of the ZVKDS about the find.
On the same day, an operation was launched to verify the circumstances of the discovery, the authenticity of the find and the archaeological potential of the area, which otherwise lies outside protected cultural heritage areas.
The circumstances of the discovery indicate a sporadic archaeological find, as no other archaeological remains were discovered in the wider area where the sword was discovered.
The iron sword, 95 cm long, with a blade 3.5 to 4.8 cm wide, with a 8.5 cm wide guard, preliminarily dated to the Middle Ages, was appropriately protected and handed over for safekeeping to the Celje Regional Museum.
Victor R.
Reading list: 4 books
PostPosted: Wed 10 Sep, 2025 1:29 pm    Post subject: Re: New sword find in Slovenia         Reply with quote
Looks like the peen may have been sheared off and the pommel lost, or maybe never had one and it was an incomplete piece. That length gives plenty of room for a good sized pommel for what seems to be a reasonably hefty blade. If you look at the OAL of the Albion Type X and Type Xa swords (most easily found references with OAL), they fall into this range. Their Type X blank is 37.25", or just under 95cm. If you're assuming part of the tang is missing, then, yes, that's a pretty long tang, but it doesn't appear broken, so I suspect sheared/lost, never affixed, or even removed to be repaired/altered/regripped, to be more likely. Perhaps additional information will come out once greater research has been done.
Blaz Berlec
PostPosted: Thu 11 Sep, 2025 1:27 am    Post subject:         Reply with quote
Yeah, on second thought I don't know why I assumed it would be a two piece Viking age pommel, with tang only passing through a thin lower piece, still leaving longer grio than usual.
Victor R.
PostPosted: Thu 11 Sep, 2025 3:02 pm    Post subject:         Reply with quote
Depending upon the type/size of pommel, I'd only expect 3.5 - 4 inches of grip when starting with about 5.5 inches of tang.
My smallest wheel-type pommel is 1.75 inches, largest that isn't on the extra large "Cluny" based sword, is 2.25 inches. With that guard, I'd expect a pommel style from the Peterson typology group though, and many of those seem to fit that dimension range, with a few being larger (though I'm having problems finding charts or even production sword data that gives measurements). With the typical grip of the era running close to 10cm, or just under 4 inches, that leaves 4cm of tang for the pommel, or 1.6 inches. A 5cm pommel (just under 2 inches) would leave 9cm of grip (3.5 inches). So, again, this tang doesn't look "long" based on those average dimensions.
Iagoba Ferreira
PostPosted: Sun 23 Nov, 2025 4:32 am    Post subject:         Reply with quote
Several Renaissance armour pieces found inside a well in Spain:
https://comunicacion.jcyl.es/web/jcyl/Comunicacion/es/Plantilla100Detalle/1281372051501/NotaPrensa/1285580173159/Comunicacion
More photos on instagram:
https://www.instagram.com/p/DRFBZ03jP38/?img_index=8
J.D. Crawford
PostPosted: Wed 17 Jun, 2026 1:04 pm    Post subject: Boy find Viking Sword on Field Trip         Reply with quote
I never had a field trip like this!
https://people.com/boy-6-goes-on-class-field-trip-finds-1-300-year-old-viking-sword-12000485
Not so sure about that Merovingian dating though.
J.D. Crawford
PostPosted: Sun 28 Jun, 2026 4:08 am    Post subject:         Reply with quote
Waterford Viking site: https://www.irishexaminer.com/news/munster/arid-41867583.html
Page 22 of 22 Reply to topic
Go to page Previous  1, 2, 3 ... 20, 21, 22 All times are GMT - 8 Hours
