Boris Bedrosov
![](images/avatars/1235896578e959855a71.jpg)
Posted: Mon 06 Jan, 2014 2:15 pm Post subject: |
After some time, when about the half of the work was done
And finally - all the flutes were made.
Here the piece appears black, because I normalized it at the end of the work - got some nasty cracks in the area of the original welding seam (well visible on the right of the last image here)
Tokugawa Ieyasu
Find my works on Facebook:
Boris Bedrosov's Armoury
Boris Bedrosov
Posted: Thu 09 Jan, 2014 3:17 pm Post subject: |
And the upper section after some initial sanding with grit #60
I still have some low areas - as I don't want to sand deeper, my intend is to fill them with the MIG/MAG and to re-sand them again.
Tokugawa Ieyasu
Boris Bedrosov
Posted: Thu 09 Jan, 2014 3:57 pm Post subject: |
Meanwhile, while dealing with the fluting, I found some time to make the bottom - cylindrical - part of the helmet. Anyway - it wasn't difficult issue at all.
First, I cut a strip long enough to encircle the upper section, leaving some extra, of course
After that the "eyes" were drawn
and partially cut - to the degree where I was able to operate with the power tools
The rest was filing by hand - there was just no other way.
As seen, in the beginning the slots were more "rectangular" - in such way it was easy for me to operate with a machine in hand. With the file they were made more "round" - as seen on the originals.
Finally - the strip was bent into a cylinder with diameter close to the diameter of the upper section.
Tokugawa Ieyasu
Boris Bedrosov
Posted: Thu 09 Jan, 2014 4:53 pm Post subject: |
Now I was able to connect the two sections of the helmet in one piece. This was made by welding.
* both sections aligned and secured by clamps
From this position I made the first inch of seam - just above the nose; and moving the clamps step by step added another.
** first several inches already welded
*** the horizontal seam almost finished - just a bit of it (in the area of the vertical seam at the back) was un-welded yet
At this point I was already able to trim the strip. Well, I cut it just a bit bigger.....
**** the resulting gap filled with a "filler" - a tiny strip of metal - and everything clamped with locking pliers
***** the vertical seam welded - and this finished the welding from the outside
****** the whole welding repeated from the inside - as this seam would not be visible, it was made strong and wider
Tokugawa Ieyasu
Boris Bedrosov
Posted: Wed 15 Jan, 2014 1:36 pm Post subject: |
And the helmet after the initial sanding with grits #60 and #80 - the aim was to grind flush the welding seams
Tokugawa Ieyasu
Boris Bedrosov
Posted: Thu 03 Jul, 2014 9:56 pm Post subject: |
In an attempt to revive this thread, let me show the finished grip of the khanjar
I had some long-lasting doubts how to decorate the fittings, but at the end I stopped my choice on this relatively simple diamond-shaped patter.
The work was made with engraving tolls entirely by hand.
At the end, all what was left from the silver ring was soldered at the rear fitting, and both were glued with epoxy to the rest of the grip.
I need some additional polishing, but anyway - the dagger is ready. The next step is the scabbard.
Tokugawa Ieyasu
Kai Lawson
![](images/avatars/8641302535076f4b408c3c.jpg)
Posted: Fri 04 Jul, 2014 6:36 am Post subject: |
I miss the updates for this thread. The work is so beautiful, almost entirely made by you personally, and has a lovely flare of form and function. It adds variety and your work is inspiring. Thanks for updating again!
"And they crossed swords."
Jeffrey Hildebrandt
![](images/avatars/2383950395048ac63b2c96.jpg)
Boris Bedrosov
Posted: Sat 05 Jul, 2014 5:03 pm Post subject: |
No, I don't have any progress with the helmet so far, except with the avaintail - it's completed.
I hope I'll be able to obtain several days (or even more) days on leave to the end of this month, and I plan to use them working mainly on the helmet.
Tokugawa Ieyasu
Posted: Sun 06 Jul, 2014 9:18 pm Post subject: |
Boris Bedrosov wrote: | In an attempt to revive this thread, let me show the finished grip of the khanjar
I need some additional polishing, but anyway - the dagger is ready. The next step is the scabbard. |
Impressive engraving work technically, and really wonderfully beautiful in design and aesthetics.
Boris Bedrosov
Posted: Sat 26 Jul, 2014 12:37 pm Post subject: |
Moving forward with this project, next was the scabbard for the khanjar.
The construction of the wooden core is the same as done previously - chiseled halves, glued together and filed and sanded to the final shape.
As I wanted different cover over the core, I abbandoned the leather this time, and used fine velvet instead.
The colour is somewhat brighter than I wanted, but this was the best one I managed to find in the stores.
Tokugawa Ieyasu
Kai Lawson
Posted: Sat 26 Jul, 2014 12:42 pm Post subject: |
Boris--
I think you owe it to the myArmoury community to suit up in full regalia when all this is done.
Dean F. Marino
![](images/avatars/163342214e55ace60d022.jpg)
Posted: Sat 26 Jul, 2014 3:05 pm Post subject: |
Boris Bedrosov wrote: | Moving forward with this project, next was the scabbard for the khanjar.
The colour is somewhat brighter than I wanted, but this was the best one I managed to find in the stores. |
I like it . Being velvet, I suspect that it could be very SLIGHTLY darkened with any of the simple water treatments.... a little neat's-foot, Bees Wax, probably lard .
BRIGHTER is often BETTER, as a first layer... most anything applied to the surface will darken it. I think you choose well. Next step: take some of your SCRAP, and try a couple of things on it . You will know when you have the right surface coating .
Boris Bedrosov
Posted: Sun 27 Jul, 2014 11:49 am Post subject: |
Well, I personally don't intend to darken the cloth artificially.
Instead, I will leave the time to do its job - surely, when ready, I would play with this dagger and scabbard for a couple of hours (almost like a little kid with a new toy ); many of my fellows - re-enactors would gladly take it in their hands to have a glimpse and feel it.
All this deliberate touching with hands away from sterile would gradually darken the velvet into a colour of an old and used cloth, giving more "historical" rather than "artificial" appearance.
Tokugawa Ieyasu
Boris Bedrosov
Posted: Sun 27 Jul, 2014 1:31 pm Post subject: |
The blade of the kilij returned from heat-treatment some time ago, but just recently I started work on it.
* still black, just after stripping-off the oxides with an wire-brush
** and after the passes with grits up to #180 on the belt-grinder
Next is my favourite (hmmmmm) hand-sanding by stones and paper.
Meanwhile the guard was cast in a nearby foundry - the wooden master I've made (on the left) and the bronze result after some initial grinding (on the right)
Tokugawa Ieyasu
Boris Bedrosov
Posted: Sun 27 Jul, 2014 3:17 pm Post subject: |
And the last entry for this weekend is about the helmet.
As it was left for about half-a-year, its surface was covered with rust. This forced me to sand it again - top - up to grit #120, the bottom - up to #80.
The middle section with the flutes would be definitely "pain in the a@#*s" - here I made just one of 20 (and it's still quite un-finished yet) just to work-out the whole step-by-step process.
Tokugawa Ieyasu
Kai Lawson
Posted: Sun 27 Jul, 2014 7:32 pm Post subject: |
That's an interesting yelman, Boris. Do you have any pictures of swords with mini ricassos before the false edge?
Ian Hutchison
![](images/avatars/18827081755221e3a79f9ac.jpg)
Posted: Sun 27 Jul, 2014 7:53 pm Post subject: |
Boris, this thread is incredible. I love watching your progress. Are you still working on the Kilij as well?
Boris Bedrosov
Posted: Mon 28 Jul, 2014 1:57 pm Post subject: |
# Kai
One quick "Google" search with key-word "kilij" will show you numerous swords of this type with such mini-ricassos.
Apart from the kilij of Mehmed II The Conqueror (on which my work is based), in particular interest for me are these several swords (they all are from the early years of the Ottoman Empire - middle-end of the 15. C). Personally for me they all show such feature.
All pictures' URLs are taken from http://www.vikingsword.com/vb/showthread.php?t=4223
# Ian
All work on this project is shown here in "real", or at least "almost real" time.
So, at this moment the kilij is in the condition as it is shown.
Tokugawa Ieyasu
Boris Bedrosov
Posted: Tue 26 Aug, 2014 2:35 pm Post subject: |
The blade of the kilij about the middle of the sanding - finished up to a grit #600
As the Islamic blades usually show very high level and quality of sanding before polishing, my intent is to go on further away - at least up to grit #1500, or even - #2000
Tokugawa Ieyasu
