Greyson Brown
Posted: Mon 12 Jun, 2006 6:43 am Post subject: Typology of Albion Count/Steward |
I am curious why the Albion Count and Steward swords get classified as Type XIIIa. To my thinking, they fit the type just as easily or better than the sub-type. I do not have my copy of The Sword in the Age of Chivalry handy, and the feature article here does not give a blade length, but I think the 34 inch blade of these two swords falls near the length Oakeshott intended (I am almost certain that he mentions an average blade length of 33 inches in SAC, but I can't prove it). Also, the 5 1/8 grip on the Count/Steward, seems more fitting for the Type XIII than the Type XIIIa (Oakeshott givves an average length of 6 inches).
I will conceede that the Count and Steward have somewhat narrow blades, and they lack the distinct widening below the hilt. Is it for this readon that they are called Type XIIIa's, or is it something else? Maybe the way they handle? Any thoughts are appreciated.
-Grey
Posted: Mon 12 Jun, 2006 7:29 am Post subject: |
That grip length may be incorrect. I don't remember the Count I saw to be that short (the review lists it as 5 1/8 inches) in the grip. The Crecy, admittedly a different beast though it shares pommel/guard with the Steward has a grip of 6 5/8 inches. The Mercenary has a 6 1/2 inch grip and its pommel can be gripped, too.
If you look at the pics in the review, Patrick's second hand could pretty easily fit on the grip. Unless his hands are really small, I'm betting that measurement is a typo. Patrick lists the Ritter's grip as 4 1/4 inches. I have a hard time believing the Count and Steward have not quite an inch more grip:
The grip length I remember the Count having would slide it pretty much in the lower end of the Type XIIIa family.
Roger Hooper
Posted: Mon 12 Jun, 2006 7:58 am Post subject: |
I agree that that 5.125 grip length must be a typo. The Count's overall length is 43.75, the blade length is34.87. If the grip length is 5.125, that would mean the pommel is 3.75 inches long. Most pommels are around 2 inches long. If that was so in this case, the grip would be a more believable 6.88 inches long.
I think that if you wanted to classify these two swords as type XIII instead of XIIIa, you could make a good arguement. I believe they are sitting around the border line between the two types
Angus Trim
Posted: Mon 12 Jun, 2006 8:24 am Post subject: |
There are six XIIIa's in Oakeshott's "Records of the Medieval Sword" that range between 33 inch blade and 34 inch blade lengths.......... handle lengths are not given.......
There is only one XIII in the same bood that has a 33 inch blade lenght. The others are a bit shorter.......
With the XIII and XIIIa the most important difference is blade length...... and 33 inch seems to be the place that Ewart chose to split them...........
swords are fun
Posted: Mon 12 Jun, 2006 9:31 am Post subject: |
According to Mike at Albion, the bare grip cores measure 6.25”. I guess we need to change that.
Jeremiah Swanger
Posted: Mon 12 Jun, 2006 10:47 am Post subject: Re: Typology of Albion Count/Steward |
| Greyson Brown wrote: | I will conceede that the Count and Steward have somewhat narrow blades, and they lack the distinct widening below the hilt. Is it for this readon that they are called Type XIIIa's, or is it something else? Maybe the way they handle? Any thoughts are appreciated.
Hi Grey,
I haven't handled any of the originals, so feel free to take my word with a shaker of salt.
The way I view the Type XIII is to take a sub-type XIIIb, make it broader and beefier, then lengthen the grip a bit to counter-balance the added heft.
Albion's Tritonia would make an excellent blade for the type XIII, it would just need a 6" or so grip.
I see the blade of the Count/Steward to be as, proportionally, a little too slim for a Type XIII, hence its classification as a XIIIa.
"Rhaegar fought nobly.
Rhaegar fought valiantly.
Rhaegar fought honorably.
And Rhaegar died."
Greyson Brown
Posted: Mon 12 Jun, 2006 11:02 am Post subject: |
I guess I should have done some math before I went and made a fool of myself. :p Thanks for pointing out that typo, Chad.
Thanks, Angus, for the info on blade lengths. I was working from memory as my books are in transit at the moment. That info, combined with the revised grip length, makes the the Count and Steward fairly cut and dried (if slightly diminuitive) examples of the Type XIIIa sub-type.
Thanks for helping me solve my little quandry, but that means I now have to come to grips with the fact that I don't own a Type XIII. I guess I have to go shopping. :cool:
-Grey
J. Guerin
Posted: Tue 13 Jun, 2006 4:14 am Post subject: |
Hi,
Aren't the 'a' subcatagories usually just longer gripped versions? So the Steward\Count's
6+ inch grip would make it a Type 13a.
Greyson Brown
Posted: Tue 13 Jun, 2006 5:52 am Post subject: |
| J. Guerin wrote: | Hi,
6+ inch grip would make it a Type 13a. |
That is somewhat true. Most of the subcatagories are longer blades and grips, but there are exceptions. The Type XIII's are one place where we see it. The Type XIII has a moderate blade length with a slightly longer than usual grip (Oakeshott gives an average length of 6 inches in SAC). The Type XIIIa has both a longer blade and grip, but the XIIIb has a blade that is the same as the Type XIII (though it can be narrower), and a true single hand grip in the 4 inch range (I don't think Oakeshott gives a measurement). We see a similar variety with the Type XVIII swords.
The 6 1/4 grip is actually one of the stronger arguements for putting the Count/Steward in the Type XIII category. The narrow and slightly longer blade is, I suspect, why Albion chose to label it as a Type XIIIa. To my mind, it really is one of those swords that straddles types, and that is okay. I bought my Steward because I liked the sword, not because I was trying to get a specific type. Of course, if I become convinced that the Steward is definately a Type XIIIa, then I can use the absence of a Type XIII in my collection in order to justify buying another sword, too. :lol:
-Grey
J. Guerin
Posted: Tue 13 Jun, 2006 7:05 am Post subject: |
I like your reasoning there.
Peter Johnsson
Posted: Tue 13 Jun, 2006 3:00 pm Post subject: |
Type XIII swords could perhaps be described as headsmans swords built for war.
The character of the type is broad in the blade, not too long and a grip with room for two hands.
The Steward and Count are too slim and nimble to really come close to type XIII swords in character. Therefore they can be classified as XIIIa´s at the slighter end of the spectrum.
You´d want to widen the blade by 30%-50% and shoten it by some 5 cm or more. Then you´d have to add a pommel that is wider and heavier. That would fit the bill for a type XIII.
If you are skillful mind readers, then you´ll know just what might be added to the line at a later date... ;)
Kenton Spaulding
Posted: Tue 13 Jun, 2006 3:14 pm Post subject: |
Very sneaky, Peter. I like the sound of this.
Greyson Brown
Posted: Wed 14 Jun, 2006 6:20 am Post subject: |
Thanks, Peter; that makes sense.
-Grey
