Forum Index > Off-topic Talk > A recalcitrant nut Reply to topic
Dan D'Silva
PostPosted: Fri 11 Sep, 2020 3:47 pm    Post subject: A recalcitrant nut         Reply with quote
My latest project sword is in. I intend to use its blade and scabbard in one project and the hilt in another. But I'm having tremendous difficulty unscrewing the round pommel nut. The seller said it was threaded, mentioned nothing about it being peened, and it doesn't look like it has been. I've tried clenching it in a pair of pliers, both with and without a wide rubber band wound around the nut, and gripping so hard my hand hurts either way, but all that's happening is the pliers are scratching the nut and the top of the pommel (after chewing through the rubber band, when I use one). Is there any other safe method I can try?
Glen A Cleeton
PostPosted: Fri 11 Sep, 2020 6:26 pm    Post subject:         Reply with quote
There are nut busters but what you are dealing with may be too small to use one. Basically a chisel head with a screw behind it in a cut out block. Use a dremel cut off disc and slit the nut wall (even if diagonally). Then a small chisel to spread/split it. Or, just cut it with a very sharp small chisel (make one from a screwdriver bit). Bonus points for unscrewing it with a chisel. Alternately, file two flats (opposite each other) and use a wrench or vice jaws.
GC
Dan D'Silva
PostPosted: Sat 12 Sep, 2020 6:02 am    Post subject:         Reply with quote
Thanks! I think I'll start with the wrench method.
Ian Hutchison
PostPosted: Sun 13 Sep, 2020 6:25 am    Post subject:         Reply with quote
You could also try heating the nut.
Dan D'Silva
PostPosted: Sun 13 Sep, 2020 7:46 am    Post subject:         Reply with quote
I tried the wrench -- it worked! The nut is not looking great now, but since it's a regular old 1/4-20 it'll be no problem to reshape a new one.
Thanks for that. I'll try it next time I'm in a similar situation (which is not unlikely).
