Forum Index > Off-topic Talk > AT1562 Leather Grip Coming Off Reply to topic
Ryan A. C.
PostPosted: Sat 16 Apr, 2005 8:03 pm    Post subject: AT1562 Leather Grip Coming Off         Reply with quote
This is really horrible. Last time I took a look at the Lady Carmen I noticed the leather was peeling off from both ends of the handle. How should I fix this? My first thought was sending it back for the work, as it is now dull anyway, but I haven't been able to get in contact with them. So how can I fix this?
Thanks so much
PostPosted: Sat 16 Apr, 2005 8:05 pm    Post subject:         Reply with quote
Ryan,
I've edited your topic's title. Please do not post in all caps; it's considered shouting and generally rude in 'Net circles.
Thanks!
Ryan A. C.
PostPosted: Sat 16 Apr, 2005 8:06 pm    Post subject:         Reply with quote
sorry
Thomas Hoogendam
Reading list: 8 books
PostPosted: Sun 17 Apr, 2005 1:58 am    Post subject:         Reply with quote
Hey Ryan.
Did you buy the Lady Carmen via AllSaint Blades?? If so, it's very understandable that you can't contact anyone via that site, since it's no longer in use. James Byrnes, who runs AllSaints, has kinda gone of the radar.
If you need to get in touch with Angus Trim, you should try this site: http://www.atrimasa.com/index.html
As for the leather coming off: leather needs care just like the blade. You say the blade needs to be resharpened. I'm guessing you've used it quite a lot. A bit of wear and tear on the leather will happen too. It would be heplfull if you could post a picture of the grip.
Greyson Brown
Reading list: 15 books
PostPosted: Sun 17 Apr, 2005 2:28 am    Post subject:         Reply with quote
Wood glue works well for attaching leather to wood or cord. You might want to wrap something around the outside of the grip while the leather dries or put some glue on both the grip core and the leather and let them set a little bit before sticking them together. The main reason I say this is because wood glue can take a while to dry, and I get tired of holding things together with my hands.
-Grey
Patrick Kelly
PostPosted: Sun 17 Apr, 2005 8:46 am    Post subject:         Reply with quote
Leather glue works well on leather too. Big Grin
It dries much faster as well, but make sure what you're gluing is where you want it to be, because it's really on there once it dries.
Angus Trim
PostPosted: Sun 17 Apr, 2005 11:11 am    Post subject:         Reply with quote
Hi Ryan
You can get a hold of me directly by PM'ing me either on SFI or here. I try and check in here at least once a day. At least half a dozen times on SFI.......
Your sword can be touched up easily enough, wrap and edge.......
Trying to get a hold of AllSaints isn't likely to be very successful, as AllSaints is out of business........
swords are fun
Ryan A. C.
PostPosted: Mon 18 Apr, 2005 12:38 pm    Post subject:         Reply with quote
thanks for all the replies
