Posted: Fri 14 Apr, 2006 7:07 pm Post subject: Albion Regent distal taper |
Looking over the review of the Regent, one piece of information I would like is how thick is the blade near the guard and near the point. What is the distal taper of the blade ? I realize that the distal taper may not be linear and has subtle changes in rate over the length of the blade but as it looks like a thick blade near the guard I can't help being curious.
I think the distal taper, in detail, is part of the trade secrets i.e. expensive research done by Albion and I don't expect or need that level of detail about measurements.
Started that looking at the pictures of it " sideway " that is usually the first sign that I'm considering another bit of damage to my bank account.
Any general opinions on the Regent expanding on the already informative review in the review section would be appreciated. Talk me out of it .......... or talk me deeper into it. :p :lol:
Jeremy G
Posted: Fri 14 Apr, 2006 7:32 pm Post subject: |
Hi Jean
The Regent is really quite thick at the blade base...seems over 1/4". Distal tapers alot to the point, which is still nice and sturdy, though needle-like. Don't know how to describe the point...it looks thicker than the Baron side-on (don't know if you've seen the baron side-on). The Baron seems almost like a filet knife, while the Regent seems more like an awl. I've used my Regent quite extensively for forms...goes great with German longsword techniques. I've put the point in the dirt, in the ceiling (twice!), across some small branches and into my wall early on when I was first learning...(well one of the ceilings was last week :blush: ), and it's survived for now. I really like this sword, and I don't think I could in my right mind try to talk you out of it ! :D
Posted: Fri 14 Apr, 2006 7:59 pm Post subject: |
I believe the Regent is ground from stock that is 3/8" (~.375"). The blade is .345" at its base on mine. I'd have to take it out of my display case to get any other measurements and I'm too lazy tonight. :)
It's an amazing sword. The thick spine is no detriment to cutting is sessions I've done. It handles quite nicely and looks great. It's a little later than many swords I like, but it is so unique in the production market and so well-done that I couldn't pass it up.
As for Jeremy's comments, it is thicker than the Baron which is around .24 inches thick at its base.
Posted: Fri 14 Apr, 2006 8:08 pm Post subject: |
Jeremy G wrote: | Hi Jean
The Regent is really quite thick at the blade base...seems over 1/4". Distal tapers alot to the point, which is still nice and sturdy, though needle-like. Don't know how to describe the point...it looks thicker than the Baron side-on (don't know if you've seen the baron side-on). The Baron seems almost like a filet knife, while the Regent seems more like an awl. I've used my Regent quite extensively for forms...goes great with German longsword techniques. I've put the point in the dirt, in the ceiling (twice!), across some small branches and into my wall early on when I was first learning...(well one of the ceilings was last week :blush: ), and it's survived for now. I really like this sword, and I don't think I could in my right mind try to talk you out of it ! :D |
Thanks for the reply, sounds sturdy enough :p or more. I do have the Tritonia so I think I know what you mean as I think it's similar in type to the Baron " Filet knife " tip .
Sorry hearing about the ceiling though :p I guess the sword survived better ! So how deep is the gouge. :p
I really love the lines of the pommel of the regent as well as the hollow ground blade. I'm not quite ready to buy another sword yet but I am looking. AT swords look appealing for all sorts of reasons not to mention affordability.
The Viceroy is also a possibility: Both maybe eventually, the last time I was deciding about the Tritonia or the Viceroy.
Will wait a while to see if another sword attracts my attention more while I wait for a tax refund: Using tax money for sword purchases as a certain sarcastic appeal. :p :lol:
Posted: Fri 14 Apr, 2006 8:12 pm Post subject: |
Chad Arnow wrote: | I believe the Regent is ground from stock that is 3/8" (~.375"). The blade is .345" at its base on mine. I'd have to take it out of my display case to get any other measurements and I'm too lazy tonight. :)
Thanks Chad: Hmmmmmmm ..... sounds even better thicker at the guard. I can feel my sales resistance weakening ...... Oh, so so weak. :lol:
It' s turning into WHEN rather than IF I'm afraid.
Joe Fults
Posted: Sun 16 Apr, 2006 1:54 pm Post subject: |
Jean Thibodeau wrote: | Chad Arnow wrote: | I believe the Regent is ground from stock that is 3/8" (~.375"). The blade is .345" at its base on mine. I'd have to take it out of my display case to get any other measurements and I'm too lazy tonight. :)
It' s turning into WHEN rather than IF I'm afraid. |
Jean,
It already should have been when, not if.
I believe I have the first Regent out the door, and for a time before more people got Regents of their own in the area, it was an absolute attention stealer. In fact I seem to remember people calling it the precious at several round tables.
For now I'm hoping the get the Earl into production (I may end up with the first one of those too). I'm not sure if it will have the same visual impact, especially since the Regent has been out and about for a while, but I suspect it will be a magnificent tool since the pommel variation was something Albion almost immediated recieved requests for.
Posted: Sun 16 Apr, 2006 7:52 pm Post subject: |
Joe Fults wrote: | Jean,
For now I'm hoping the get the Earl into production (I may end up with the first one of those too). I'm not sure if it will have the same visual impact, especially since the Regent has been out and about for a while, but I suspect it will be a magnificent tool since the pommel variation was something Albion almost immediated recieved requests for. |
Hmmmmmm............. Definitely a good endorsement: I sort of want to " savour " the decision rather than jumping in too fast, that what happens when you first go nuts when collecting is all new and you buy stuff at a blistering pace, after a while you TRY to pace yourself and be more selective. Well, if you win a lottery maybe you can afford to go nuts.
Bottom line is that the Regent is at the top of the list: Just on looks in a Pict, but with the input from other happy owners. ;) :lol:
Let's see how long I can last. :p I do have a tax refund due soon. :D In any case I am now convinced that it is a good choice.
Thanks, I guess ? Firming up my resolve to spend. :p :lol:
