Forum Index > Historical Arms Talk > Sword ricasso: reasons? pro vs. cons? Reply to topic
Spenser T.
Likes: 11 pages
PostPosted: Thu 26 Nov, 2015 12:28 pm    Post subject: Sword ricasso: reasons? pro vs. cons?         Quote
I find I'm thinking a lot about why a sword (single-handed) would have a ricasso, and I'm hoping to get some ideas and input from the knowledgeable folks here...
I've heard they were used to wrap a finger around to access a different type of grip. This makes sense, but I also notice that a lot of basket-hilted swords have a ricasso on them, and one wouldn't be able to access this type of grip with a full basket.. so I'm wondering if there were some other less obvious reasons for having them.. or were they something that was fashionable? (I don't see how a ricasso would detract from the cutting ability / other offensive uses of a blade.. please correct me if I'm wrong about this)
Thanks for your input
Roger Hooper
PostPosted: Thu 26 Nov, 2015 12:59 pm    Post subject:         Quote
There are forumites who can answer this better than me, but I'll give it a shot..
Correct me if I'm wrong, (as I am about so many things) but ricassos first became common on Type XIX blades around the beginning of the XVth century. Certainly a primary reason was to allow one to finger the cross without cutting that finger.
I've also heard that the ricasso can make sharpening the blade easier. Certainly, with a complex hilt that extends out over the beginning of the blade, sharpening in that area could be difficult.
I think a ricasso can also play an important part in creating various types of blade geometry. If one starts with a thick ricasso, then it may make it easier to play with various kinds of distal taper to achieve the sort of blade balance one seeks.
A ricasso also enables one to put interesting designs on the blade, as are found on many XIX's!
 Attachment: 98.81 KB
Albion Condottiere
Ben Coomer
PostPosted: Thu 26 Nov, 2015 8:35 pm    Post subject:         Quote
I wonder if part of it is strengthening the forte for defense, keeping it thicker for taking strikes.
It probably also had to do with bringing the center of balance closer to the hand as thrusting became more important.
Could also be stylistic.
Ronald M
PostPosted: Thu 26 Nov, 2015 10:56 pm    Post subject:         Quote
wouldnt it help to sit in a sheath a bit better?
smiley face 123? no? lol yeah well im here cause i like...swords and weapons and stuff obv
Profile PM E-mail
Stephen Curtin
Likes: 110 pages
Reading list: 18 books
PostPosted: Fri 27 Nov, 2015 3:03 pm    Post subject:         Quote
I suspect that the reason that you find ricassoes on blades matched with baskethilts is that large numbers of bare blades were produced in places like Passau and Solingen and exported to be hilted locally. Having a ricasso on these blades would keep the option open for hilting them on swords that you intended to finger the guard. I really can't think of any con to having a ricasso on a sword blade.
Éirinn go Brách
Profile PM E-mail
Timo Nieminen
PostPosted: Fri 27 Nov, 2015 6:42 pm    Post subject:         Quote
In particular, it will help avoid deep nicks in the edge at the base of the blade that can give nice starting points for cracks that will result in you losing your whole blade.
Possibly. This would depend on thickness, fullering, etc. Along the lines of thrusting, it can also make for a stiffer base of the blade.
Sometimes, for sure.
It would help. In particular, it can help achieve a tight fit at the scabbard mouth while having a looser fit within the rest of the scabbard.
Compare with the Japanese habaki and Chinese tunkou (sometimes, on Chinese blades, there isn't a separate tunkou, but a ricasso instead, decorated to look like a tunkou).
Can make it easier to grab the blade. If a plain cross, it makes it safer to grab the guard from the blade side.
Profile PM Website
Matthew P. Adams
Likes: 8 pages
PostPosted: Sat 28 Nov, 2015 2:50 pm    Post subject:         Quote
It also makes the base of the blade stiffer which pushes the vibrational node on the blade out further towards the tip.
Spenser T.
Likes: 11 pages
PostPosted: Sun 29 Nov, 2015 9:52 pm    Post subject:         Quote
Just want to thank you guys for your input, as usual, these are all things I wouldn't have thought of!
Dara Mag Uiginn
Reading list: 3 books
PostPosted: Mon 30 Nov, 2015 7:17 pm    Post subject:         Quote
Just to add something from my amateur research: A long, recessed ricasso, as seen on the Oakeshott type XVIIIe, could be used as an efficient place to grab the blade, effectively turning it into a short pole arm. All ricassos (ricassi, ricassen?) enable this action, of course, but the XVIIIe's is designed to facilitate this, allowing the weapon to be wielded as a short pole arm. The things are beautiful, and exotic in appearance. The Danish used them quite a bit in the later part of the 1400s. Another note: The XVIIIe was robustly built, and Albion says that it may have been used as a lance on occasion (and they do their homework!) Hope I helped!
"It is perfectly true, as the philosophers say, that life must be understood backwards. But they forget the other proposition, that it must be lived forwards."
-Søren Kierkegaard
James Arlen Gillaspie
PostPosted: Mon 07 Dec, 2015 4:41 pm    Post subject:         Quote
An article by Marc Gener I was reading recently was about the metallography of two broken rapier blades (broken in the middle, roughly) and both of them were heat treated in a way that left the tang and ricasso soft. A chunkier ricasso would help greatly to stiffen the blade in that area.
jamesarlen.com
Profile PM Website
Timo Nieminen
PostPosted: Mon 07 Dec, 2015 11:39 pm    Post subject:         Quote
Stiffness doesn't depend on heat treatment (Young's modulus for iron and steel is almost independent of heat treatment and alloy). Since, even if the base of the blade was spring tempered, you don't want too much flex there, leaving the base of the blade soft shouldn't make any difference.
But yes, a stiffer base, e.g., due to a ricasso, will help stop the blade from taking a set there. But I don't think a well designed blade should be flexing too much there anyway, so I don't think this is a reason for using a ricasso. That is, if it needs a ricasso to be stiff enough when heat-treated soft, you'd still want that ricasso there if it was spring tempered.
Profile PM Website
