Philip S
Posted: Sat 16 Jun, 2007 11:46 am Post subject: Regrip: Estoc/Tuck Sword- Suggestions? |
I had been considering purchasing the Windlass Estoc for some time, and after I came across Sean Flynt's workbench article, I decided to go for it. I was a bit dissapointed with the blade because of its relative thinness and flexiblity, but quite satisfied with the overall construction.
I didnt like the Windlass grip, so after reading Flynt's how-to, I decided I would modify mine as well.
In addition to regripping the sword with dark leather and more risers, I would also like to blacken the hardware. i've attached some photos of what I have in mind. Unfortunately I have no idea of what this process entails (blueing? Tarnishing?), and was hoping for some advice!
Attachment: 7.62 KB
Blackened hardware
Andrew Babbini
Posted: Sat 16 Jun, 2007 6:40 pm Post subject: |
Mr Philip,
For blueing/blackening, you can use a cold blue solution which is sold at just about any sporting goods store. It's usually located near the gun cleaning and maintenance materials.
I recommend you rough up the fittings slightly and clean them to get any sort of oils or finishes off of them. If I remember right, Windlass has a nasty habit of putting a sort of lacquer on both their blades and hilt furniture. After you get all that stuff off, just apply a few coats of the bluing solution and buff it with some very fine steel wool.
Respectfully,
Andrew
