Forum Index > Historical Arms Talk > What is a novice to do? Reply to topic
Bill Bowers
PostPosted: Fri 23 Feb, 2007 6:41 pm    Post subject: What is a novice to do?         Reply with quote
How do I find out informtion about a sword I own?
I have what seems to be a ceremonial sword that was found inside of a wall of a boarding house in the 1930s in Eastern Kentucky.
It sort of looks like what I have seen as a Knights of Columbus sword but it doesn't have KOC written on it.
I've got pictures if anybody might help me...I'll send them.
Thanks.
Bill
George Hill
PostPosted: Fri 23 Feb, 2007 7:03 pm    Post subject: Re: What is a novice to do?         Reply with quote
Post the pictures in thread. Look for add attachment under the message window.
William C Champlin
PostPosted: Fri 23 Feb, 2007 9:09 pm    Post subject:         Reply with quote
Hey Bill. There's a site, arms2armor.com that has a pretty good collection of pictures of american society swords. I'd look at that or do a search for one of the lesser known societies that you know to have ceremonial swords. Knights of Pythias or Patriarchs Militant for example. Putting up a picture however would let all of us weigh in with our experience and opinions and that is usually fun.W.
tweetchris
Glen A Cleeton
PostPosted: Sat 24 Feb, 2007 6:29 am    Post subject:         Reply with quote
Here's the link referenced above. It is not all inclusive but does show some of the old militia swords as well. These were the root of most fraternal patterns.
http://arms2armor.com/Swords/usswords.htm
Another helpful page
http://www.ruble-enterprises.com/society.htm
Yet another
http://hometown.aol.com/machood/frat.html
from there
"If it doesn't have the eagle or a bust of Columbus, it is not a KOC sword"
Worth noting though that the full figural eagle pommel is used on other hilts, both for military and other fraternities. There are a couple of different eagles as well.
If the sword is entirely unmarked, there is a good chance of other than KOC association. A great many swords get attributed to them but the bust of Columbus and eagle are pretty conclusive. One may also see the rather common militia swords billed as fraternal and vice versa A dealer I often roll my eyes at has a clearly (to me) marked Masonic variant billed as a military sword.
Pictures of the sword in question would narrow it down pretty quickly. If you are unable to attach them, you could also try uploading them to a hosting site like www.imageshack.com or www.photobucket.com then sharing the gallery or links.
GC
Bill Bowers
PostPosted: Sun 25 Feb, 2007 6:40 pm    Post subject: 3 pics of the sword         Reply with quote
OK, here is a pic of the sword.
Thank you very much for the info you've provided so far. I'll check out all links.
 Attachment: 71.19 KB
Bill
Glen A Cleeton
PostPosted: Mon 26 Feb, 2007 7:44 am    Post subject:         Reply with quote
Hi Bill,
It is a Knight's Templar sword. The monogram is of the owner's initials and the name is likely etched on the blade as well. These can be closely dated by the owner's name. One can often narrow down the scope of the search with some genealogic study. In this case, finding out when the wall was built and by whom would be a good start. The sword probably didn't travel far from the original owner, so local history may come well into play. A local lodge may have a record of the fellow.
Here are two more very good references for these swords.
Phoenix Masonry Site
Templar History Site
There is likely some indication on the base of the blade as to who the maker/supplier was. Do you have a picture of the other side?
GC
Bill Bowers
PostPosted: Tue 13 Mar, 2007 8:17 pm    Post subject: Thanks         Reply with quote
Thanks a lot for the info and resources.
Bill
Bill Bowers
PostPosted: Sat 17 Mar, 2007 7:43 pm    Post subject: One more question: Knights Tamplar         Reply with quote
One more question. If I wanted to sell my Knights Templar sword, should I try to spin shin it and get it as clean as possible? Or does that lower the value?
Thanks.
Bill
Lin Robinson
PostPosted: Sun 18 Mar, 2007 4:45 am    Post subject: Re: One more question: Knights Tamplar         Reply with quote
Thanks.
If it is dirty, then light cleaning would be fine, just enough to remove the dirt. Do not do any heavy polishing or use steel wool or other abrasives, which will remove any patina that has formed.
Actually these swords are quite common so do not expect to sell it for a large sum.
Lin Robinson
