Forum Index > Historical Arms Talk > Albion Talhoffer - Tatami cutting - surprising results Reply to topic
Michael Edelson
PostPosted: Mon 29 Jan, 2007 3:01 pm    Post subject: Albion Talhoffer - Tatami cutting - surprising results         Quote
While updating my Earl review, I thought I'd also let people know how the Albion Talhoffer fared against tatami mats.
As with the Earl, I will break the results down into three categories; feel, results, and durability.
Feel
I did not expect the Talhoffer to fare well at all. It is, after all, a type XV with a very narrow profile and a thick edge. The design is always described as a cut/thrust compromise leaning strongly towards the thrust. It is also not particularly sharp.
I was quite hesitant to try cutting a full mat target with it, as I was afraid to damage (bend) the sword after failing the cut. I was therefore extremely surprised at how good this sword felt cutting tatami. It offered less resitance than the Earl (it is thinner and not hollow ground), but I cannot honestly compare the two as my clearest impression of cutting with the Talhoffer was shock at how good it was despite my expectations.
I have no idea why a type XV should cut tatami so well, but it does. It also feels great doing it. This sword has what I would consider the perfect hilt…there is not a part of it that I don’t like…the pommel is perfect and can be gripped a variety of ways, the handle is just long enough and thick enough to control the sword and the shape of the grip allows for precise edge alignment.
Results
Like the Earl, the Talhoffer cut cleanly and without the slightest damage to itself or even scratches in the finish. Also like the Earl, it did not lose edge sharpness to any noticeable or measurable degree. There was also very little flex (post cut video analysis), except on botched cuts (see below).
Durability
I made about 40 cuts in total, about 10 with the Talhoffer, and I botched 1 of those. The botched cut had good edge alignment and a lot of power but insufficient speed to finish the cut (exactly like the botched Earl cuts...my left oberhau needs a lot of work). In video analysis, the botched cut forced the Earl to flex a little more than 30 degrees, and the sword returned completely to true.
There was no damage of any kind to the Talhoffer, despite the one botched cut.
Conclusion
Prior to tatami, I cut a variety of media with the Talhoffer. Stiff plastic bottles (which it hates to cut), milk juks (it liked those), pool noodles (pretty good) and soft wood (liked that too). Overall, I would have said the Talhoffer is not a good cutter, as it was much harder to cut those items with it than any of my Angus Trim swords (which slice through those things like the proverbial hot knife). However, after seeing its performance on tatami, a target much closer to what the sword was designed for, I would have to say that the Talhoffer is in fact a very good cutting sword. Having learned from this experience, I would caution people away from drawing conclusions about swords based on cutting items the swords were not designed to cut.
www.newyorklongsword.com
Byakkokan Dojo
http://newyorkbattodo.com/
Last edited by Michael Edelson on Mon 29 Jan, 2007 4:10 pm; edited 1 time in total
Profile PM Website
PostPosted: Mon 29 Jan, 2007 3:33 pm    Post subject:         Quote
I've very much enjoyed watching the progression of your understanding of these tools as well as the broadening of your views on the subject. I'm sure that it's served as both a learning experience for those of us reading it as well as a reinforcement to things we've also learned in our own experiences. Thank you for sharing this with us.
Regarding the Type XV and its ability as a cutter: I've been speaking of this for years and specifically described my own surprise regarding the Arms & Armor Black Prince sword. That sword was the first to change my entire understanding of the "aggressively tapered pointy swords". They are much sturdier and more powerful than their profile taper would often indicate.
Profile PM E-mail Website
Nicholas Zeman
PostPosted: Mon 29 Jan, 2007 5:40 pm    Post subject:         Quote
I think some of the prejudice against the XV and XVA cutting abilities can be directly related to both the visual profile and the advent of cutting soft targets like pool noodles and plastic water bottles. My Mercenary (Albion type XVa) doesn't cut these soft targets very well, but my Atrim slices them up like nothing. A close glance at the edge will reveal the difference; the Atrim has a much thinner profile (DN1506) and a sharper edge, so it cuts through these soft targets a lot better (I believe the edge is more roughened as well, which helps with the bite in these soft materials). I have yet to try my Merc at harder materials, but I am feeling better after reading this review!
Patrick Kelly
PostPosted: Mon 29 Jan, 2007 9:17 pm    Post subject:         Quote
Very true and sage advice.
I've enjoyed reading your feedback on both the Earl and the Talhoffer. Thanks for taking the time to post your experiences.
Years ago I did a review of A&As Black Prince and, like Nathan, I found it to be a very different sword than I had expected. A few years ago I had the opportunity to cut some goza with Albions prototype Brescia Spadona. That experience opened my eyes to the capabilities of these sword types even more. They're far better cutting instruments than most believe. While not as easy or quite as decisive as the earlier cutting dedicated designs, against an unarmored target any difference would be irrelevant.
Thanks again.
Profile PM AIM
Ed Toton
PostPosted: Tue 30 Jan, 2007 6:52 am    Post subject:         Quote
This probably isn't the best place to ask it, but is there a good source of tatami mats that you could recommend. I recently acquired my Albion Talhoffer, and am looking forward to attempting some similar cuts with it. I've done very little cutting with my sharps so far, and was curious about how the Talhoffer might perform. Thanks very much for the write-up!
-Ed T. Toton III
My armor photos on facebook
Profile PM Website
PostPosted: Tue 30 Jan, 2007 7:07 am    Post subject:         Quote
No it's not the best place. :) If you're looking for advice on tatami suppliers, please post about it in the OT forum so people can respond in that thread, not here.
Jean Henri Chandler
PostPosted: Tue 30 Jan, 2007 8:18 am    Post subject: Re: Albion Talhoffer - Tatami cutting - surprising results         Quote
I have an Albion Constable and it cut's amazingly well, I've cut cardboard tubes, water bottles, 2 liter soda bottles, wooden poles, and a two by four. It cut everything with ease. I have a lot of this on video, on youtube. I'm not a very experienced cutter either, my friends even less so.
I've also cut with the Brescia Spadona and it cut extraordinarily well. In fact the reason I bought my Constable was because of an experience I had cutting with the Constable and the Brescia at a cutting party.
I want to get some tatami mats and cut those. I have the stand / holder already.
I think there is something about the XV / XVa blade shape which makes it cut well.
J
Angus Trim
PostPosted: Tue 30 Jan, 2007 2:16 pm    Post subject: Re: Albion Talhoffer - Tatami cutting - surprising results         Quote
[quote="Jean Henri Chandler"]
J
In a word, rigidity.........
swords are fun
Paul Watson
PostPosted: Tue 30 Jan, 2007 4:10 pm    Post subject: Re: Albion Talhoffer - Tatami cutting - surprising results         Quote
Did you completely cut through a 2x4 timber with this sword?
Michael Edelson
PostPosted: Wed 31 Jan, 2007 3:51 pm    Post subject:         Quote
Thanks for all the positive responses, guys. When a sword I really like performs well, it's a good feeling, and I like to be able to pass that feeling along to others.
Byakkokan Dojo
Profile PM Website
Allen W
PostPosted: Wed 31 Jan, 2007 6:32 pm    Post subject:         Quote
How sensitive was the Talhofer (or Earl for that matter) to point of impact along its length? How were tip cuts?
Michael Edelson
PostPosted: Wed 31 Jan, 2007 6:55 pm    Post subject:         Quote
I didn't notice much difference (except as noted below) when varying the point of impact when cutting with either sword, but then I wasn't paying particular attention. I suppose that had there been a lot of difference, I would have noticed it whether I was paying attention or not. I only know that the point of impact varied by about a foot because of the trail of tatami "gunk" on the blade.
I didn't try tip cuts with either sword, though I did cut close to the tip a few times. Such cuts did feel different than the rest...more vibration was felt when the sword struck the mat, and the cut did not feel as clean.
Byakkokan Dojo
Profile PM Website
S. Clare
Likes: 3 pages
PostPosted: Thu 01 Feb, 2007 12:29 am    Post subject:         Quote
I wonder how the Albion Agincourt might compare with the Talhofer in these cutting exercises, given that the blade is the same type. Anyone have any experience with that one in cutting tatami mats? I am also interested in the Crecy's performance on mats - I suspect it would be a better cutter, but I would like to hear of the experience of others in that regard.
S. Clare
Jean Henri Chandler
PostPosted: Thu 01 Feb, 2007 5:05 am    Post subject: Re: Albion Talhoffer - Tatami cutting - surprising results         Quote
Yes, though it was rather old probably a little dried out. It had fallen off of my neighbors back-yard shed.
We also cut through a thawed-out frozen chicken.
J
PostPosted: Thu 01 Feb, 2007 6:17 am    Post subject:         Quote
They're not just the same blade type, they are the same blade. :) Albion makes two different Type XVa blades: a short one shared by the Mercenary, Castellan, Constable; and a longer one shared by the Agincourt, Talhoffer, and the others.
Peter Johnsson
PostPosted: Thu 01 Feb, 2007 6:42 am    Post subject:         Quote
The Agincourt and Talhoffer are close siblings.
You will exprience difference between them mainly from ergonomical reasons, since the pommels are shaped differently (they share the same grip core). Some prefer scent stopper pommels, others feel that wheel pommels are an active help in achieving edge alignement durign cut. Personally I find the wheel pommel to be useful rather than a hindrance.
The balance and heft is very similar.
The Crecy will be more effortless in cutting mats: it is a more cut oriented sword.
None of these types cut strongly with the point (even though the Crecy will cut a bit farther out towards the point than the Talhoffer typically will). One should not expect narrow awlshaped thrusting swords to cut with the point: it is not according to their type. They *can* cut exposed flesh with the point, but you will obviously not do amputating cuts this way. Look at swords with broader blades and spatualte points for this (like Tritonia, Duke, Count, Steward and possibly Baron).
If you look at the profile, the silhouette, of a sword you can tell: a pointy sword need to have a pretty thick point or be vulnerable. A broad point need to be pretty thin, or the sword will be cumbersome. This will affect the cutting function of the swords. Obviously the broad thin point will cut with effortless efficiency and the narrow thick thrusting point less so.
As most will focus on the cutting perfomance of swords in their practice (or even base their understanding of swords just from the prespective of cutting performance), the potential and function of a sturdy, sharp, agile and precise point is less appreciated. Looking at sword types through history you will see that the point was indeed appreciated and often favoured. Among contemporary afficionadoes, a sword is mostly appreciate after how large or difficult targets it will sever.
With this attitude many important aspects of the sword will escape notice.
Test cutting then becomes a situation where the performance of the sword is judged, not a test of the skill or ability of the swordsman.
Note that I am not saying that cutting perfrmance is not important. Of course it is: just that there are other aspects that are equally important. Placing the cut at the right place at the right time, is perhaps more important than how deep you will cut as long as the cut is deep enogh. I think one need to look at these XVa swords from this perspective to be able to fully appreciate them.
-And yet they do cut, as has been testified several times in this thread.
I am glad that Michael has shared these observations on the Talhoffer on the forum. It is nice to see how practical use of a sword can help shift the understanding of a whole class of swords.
Thanks for sharing and taking the trouble to write a thorough report, Michael!
(..and sorry about all my bad spelling!)
Last edited by Peter Johnsson on Thu 01 Feb, 2007 7:30 am; edited 2 times in total
Profile PM Website
Randal Graham
PostPosted: Thu 01 Feb, 2007 7:13 am    Post subject:         Quote
Well said Peter... and now I feel no desire to reply, as it would be redundant...
:0)
R.H.Graham
Swordsmith
Profile PM Website
Michael Edelson
PostPosted: Thu 01 Feb, 2007 9:16 am    Post subject:         Quote
Thanks Peter,
I'm as guilty of cutting bias as anyone, though I do peform thrusting tests with my swords, particularly the XV and XVIIIs. I've been fortunate enough to have gotten my hands on some of the best mail available for these tests and some of these tests are described above.
Of course, when it comes time to take photographs and post them, I only put up the tatami cutting. So yes, guilty as charged, but I'll try to do better. :)
Despite my love of cutting, however, I am in love with slender swords with awl like points...XVs and the more slender XVIIIs appeal to me more than any other sword types. There's something about them...
Byakkokan Dojo
Profile PM Website
Travis Canaday
PostPosted: Thu 01 Feb, 2007 10:42 am    Post subject:         Quote
Exactly!
It seems the cut is regularly over-emphasized with the thrust under-emphasized when it comes to longswords and the Liechtenaur system. I think it's in the Danzig manuscript where it refers to the point of the sword as the nexus of offense.
The main targets for swords like these in an unarmoured situation would be the head, face, neck, wrists, and hands. Other than that, my impression is that the object of most cutting actions is to chamber a thrust. Trying to unterhau through a gambeson with one of these probably wouldn't do much.
Of course cutting exercises are still very important for learning necessary skills. But for the most part these kind of large sweeping cuts aren't really a big part longsword fencing. Cutting exercises like this make perfect sense for JSA, because these kind of cutting motions are the primary method of attack.
Thank you Michael for posting this. I love this stuff.
Travis
Travis Canaday
PostPosted: Thu 01 Feb, 2007 11:18 am    Post subject:         Quote
Not Danzig, but Dobringer...
From Christian Tolber's "Fighting":
"...the Oberhau and the Unterhau from both sides. These are the main strokes and the foundation of all other strokes, which in their cause and fundamentals come from the point of the sword, which is the kernel and center of all techniques."
Travis
