Forum Index > Off-topic Talk > Medieval Scandanavian History Reply to topic
Craig Peters
PostPosted: Mon 06 Nov, 2006 1:33 pm    Post subject: Medieval Scandanavian History         Quote
Lately I have been collecting books about medieval history specific to various regions throughout Europe. However, I'm having a difficult time locating books about general Scandanavian history. Not surprisingly, there's a plethora of information out there on the Viking era, and one can fairly easily obtain books that cover up to the 11th century, but I have found very little in my (admittedly limited) search for books covering the next few centuries. Any book suggestions will be welcome, though ideally I'd like a book covering general Scandanavian history from the 11th through 14th centuries.
Ville Vinje
PostPosted: Mon 06 Nov, 2006 3:21 pm    Post subject:         Quote
Check out this site.
http://www.historiska.se/histvarld/forum/
These guys can most likely answer most of your questions. Most of the swedish reenactment elite use this forum. It is in swedish but they have a section called "English forum" where you can ask your questions.
Profile PM Website
Richard Fay
Reading list: 256 books
PostPosted: Mon 06 Nov, 2006 3:36 pm    Post subject:         Quote
Hello all!
Craig,
I'm not sure about general history books, but what about some military history books about Scandinavia?
Have you tried the two Osprey volumes that cover Scandinavia? There are two Men-at-Arms volumes, Medieval Scandinavian Armies (1) 1100-1300 and Medieval Scandinavian Armies (2) 1300-1500, both by David Lindholm and David Nicolle, with colour plates by Angus McBride. They seem to have some decent information, and a few good photos. I especially liked the photos of a Visby coat-of-plates with protection for only the front of the body (different from the standard Visby coat-of-plates depicted in almost every arms and armour book), some interesting Scandinavian swords, three different Visby gauntlets, and two views of an interesting Danish effigy of the 14th century (all in Medieval Scandinavian Armies (2) 1300-1500.
If you already have these two Osprey books, you might want to try David Nicolle's Medieval Warfare Source Book Volume 1: Warfare in Western Christendom. This covers all regions of western Europe, and each chapter has sections regarding Scandinavia. Nicolle's Arms and Armour of the Crusading Era 1050-1350 Western Europe and the Crusader States has a chapter about Scandinavia. The text is short, but informative about the general military history trends. This book also contains a plethora of line drawings by the author, based on period art and existing examples of arms and armour.
Even if these books aren't quite what you're looking for, they might give you an idea where to look. I know both Osprey books contain a "Further Reading" list. The lists do contain some general histories as well as military histories, but some of the books may be old, out-of-print, and hard to find (or in languages other than English).
I hoped this helped a bit, even if it wasn't exactly what you were looking for! The Osprey books could be good "primers" that might steer you in the right direction.
Stay safe!
Prince Andrew of Armar
Profile
Daniel Staberg
PostPosted: Mon 06 Nov, 2006 11:14 pm    Post subject:         Quote
Nicolles books on 'Scandinavian' armies are filled with flaws and errors that make them poor as historical sources. Unfortunately Osprey and Nicolle ignored most of David Lindholm's attempts to correct existing errors and add new & correct information lacking in the books. I recomend staying away from them unless one knows enough of the subject to separated the actual facts from the many misconceptions and errnous information.
The same goes for Nicolles sections in the other mentioned books which are good examples of what happens when you write history with out being able to read the proper sources due to the language barrier.
Richard Fay
PostPosted: Tue 07 Nov, 2006 10:37 am    Post subject:         Quote
Hello all!
Daniel,
Thanks for the word of warning about the Osprey books. I wasn't aware of the problems with these works. It is unfortunate that Nicolle didn't listen to Lindholm, but that's what happens when you have an "established expert" as your collaborator. I personally worked in science long enough to know about "expert egos" and the narrow-mindedness certain persons with Ph.D.s. may display. Still, the photos are nice. I only really get most Osprey books for the pictures anyway. (Being an artist, I even appreciate the colour plates.)
Do you know specifically what mistakes and flaws the Osprey books contain, so others who have them can determine what's right and what's wrong? I'm asking in part for myself, so I can read them with a more critical eye. Again, some of us don't have access to sources in other languages (I took two years of French in high school, but my daughter knows more French than I do), so it's hard knowing the subject well enough to discriminate fact from garbage. Any help correcting the errors in these books would be greatly appreciated. (After all, isn't sharing information one of the purposes of this forum?)
So, are you aware of any decent English-language resources regarding Scandinavian history? Or, are we back to the same quandary we were in with regard to the landesknecht?
Thanks again for any help you can give correcting the errors!
Stay safe!
Profile
Max von Bargen
Reading list: 10 books
PostPosted: Tue 07 Nov, 2006 6:38 pm    Post subject:         Quote
I'd like to second Richard's request. I'm operating with somewhat limited sources, and one of Nicolle's books is my only source for some information, so it'd be helpful to know exactly where he falls short.
Max
Elling Polden
PostPosted: Thu 09 Nov, 2006 4:36 am    Post subject:         Quote
Since I'm a native, I dont have much info on english literature on the subject. they SHOULD be around, however...
I'll have a look at the Scandinavian Armies book, and see what I know to be wrong...
Profile PM Website MSN
Richard Fay
PostPosted: Thu 09 Nov, 2006 8:52 am    Post subject:         Quote
Hello all!
Thanks, Elling!
Any correct information you can come up with would be greatly appreciated!
Never stop learning!
Stay safe!
Profile
Craig Peters
PostPosted: Tue 14 Nov, 2006 8:48 am    Post subject:         Quote
Any other suggestions for book sources? I am interested in military history, but I am looking primarily for general history to fill out my book collection.
Risto Rautiainen
PostPosted: Thu 16 Nov, 2006 1:24 am    Post subject:         Quote
Though it's not 14th century, one of the best period accounts about the northern people is made by Olaus Magnus in the 16th century. You should find his works translated to english. Sorry I can't help you with any other english titles as I usually read them in finnish.
