Patrick Bunt
Posted: Sat 21 Oct, 2006 3:30 pm Post subject: Name of glaive-like weapon? |
I've been looking for a name for this weapon, used in an opera (Dracula):
http://www.worldsedge.org/images/polearm.jpg
It's not quite like any glaive I've found images of- it's also not quite like the Asian equivalents (Bisento, Kwan Do).
If you were writing an article that mentioned this weapon, what would you call it?
Thanks all--
Mikko Kuusirati
Posted: Sun 22 Oct, 2006 1:53 am Post subject: |
Glaive or bill, probably. Maybe just a pole-arm. Naming historical weapons is not really an exact science - most of the monikers we use were either not used back then, or meant a variety of different things back then. As a case in point...
http://www.giantitp.com/comics/oots0136.html
Allan Senefelder
Posted: Sun 22 Oct, 2006 5:15 am Post subject: |
Looks like a war scythe or kriegschickle in German. The usual peasent agricultural implemet roots.
Chuck Russell
Posted: Sun 22 Oct, 2006 2:41 pm Post subject: |
ya. glaive, kuss etc are usually the same thing
James Barker
Posted: Mon 23 Oct, 2006 10:16 am Post subject: |
| Sean Flynt wrote: | | Technically, a glaive's socket is centered on the blade while the socket of the couse/kuse or couteau de breche is in line with the back of the blade. |
Not really, there are glaives that are not center socketed.
14th century glaive which is socketed on the back of the blade:
Matthew K. Shea
Posted: Mon 23 Oct, 2006 11:06 am Post subject: |
If you're referring to the weapon to the right of the axe and left of the bill and what looks to be a spear with a roundel, I believe that's called a bardiche (or whatever spelling variation you prefer).
Proud member of the Academy Of European Medieval Martial Arts.
"Those who live by the sword live a good, long time!"
~Minsc, in Baldur's Gate II
James Barker
Posted: Mon 23 Oct, 2006 11:53 am Post subject: |
| Matthew K. Shea wrote: | | I believe that's called a bardiche (or whatever spelling variation you prefer). |
My point exactly, some books call it a specific name and others a glaive, same with what Chuck said about a kuss, they are all forms of glaives or pollarms, not every medieval weapon has a specific name and shapes vary drastically.
Posted: Mon 23 Oct, 2006 11:55 am Post subject: |
Those weapons are, L-R, an axe, a bardiche, an ahlspiess (awl pike) and a bill. The bardiche doesn't have much in common with the glaive in terms of design or construction. It's more directly an axe derivative, while the glaive is more closely related to the bill--a knife on a stick, essentially.
It's true that we often don't know what these weapons were called by their users, but modern scholars have reached consensus on many or most of them, and that's what we have to work with when we discuss polearms. Waldman clearly defines the basic forms in his recent book, the best scholarship to date on the subject.
Posted: Tue 24 Oct, 2006 6:11 am Post subject: |
I'm afraid I'm giving the wrong impression or at least the wrong tone, so please allow me to clarify: While it's certainly true that polearms terminology has pretty much always been chaotic and inconsistent, and while it's true that "glaive" has been used to describe a variety of arms, historically, (and not just polearms), the best, most complete scholarship to date (Waldman) separates the glaive (broad, often curved blade and central socket) from the Vouge/Couteau de Breche/Kuse (narrower, thicker kitchen-knife shape and socket aligned with back of blade). It's more convenient to call all these weapons glaives, but the discussion is better served by the specificity suggested by Waldman. Thinking of it in more common terms, it's the difference between talking about "passenger cars" and talking about "Toyota Camry". If the discussion is about construction, design and use, we need to be at the "Toyota Camry" level, if not even more precise--"1996 V6 5-Speed Toyota Camry". It may seem pedantic, but establishing clear and consistent terminology is the first step toward better understanding this class of weapons.
Russ Ellis
Posted: Tue 24 Oct, 2006 7:11 am Post subject: |
I have to agree with Sean on this one... but then I would I own the Waldeman book as well. Unfortunately there a multitude of sources both modern and ancient that refere to the plethora of polearms with a mulititude of names. I think what we see here is a good arguement for Oakeshott's type typology. It puts everyone at least relatively on the same page.
TRITONWORKS Custom Scabbards
James Barker
Posted: Tue 24 Oct, 2006 8:11 am Post subject: |
Thanks for clarifying what you mean Sean; I see where you are going. We modern folks feel the need to have a specific label for everything though I am not sure medieval folks did, for instance a bill can be a million things medieval wise, even a small hand held hooked blade used to garden with.
Geoff Wood
Posted: Tue 24 Oct, 2006 8:39 am Post subject: |
| Russ Ellis wrote: | | I have to agree with Sean on this one... but then I would I own the Waldeman book as well. Unfortunately there a multitude of sources both modern and ancient that refere to the plethora of polearms with a mulititude of names. I think what we see here is a good arguement for Oakeshott's type typology. It puts everyone at least relatively on the same page. |
If what is required is a common understanding in modern discussion, wouldn't the classificatory terminology (of Waldeman or anyone else) have been better if it had been 'Oakeshott' style (i.e. alphanumeric, without the use of any period terms). This is rather like the rapier discussion a while back. It seems wrong, to me, to hijack and then restrict the use of period terms. That isn't an act of scholarship, it's dogma.
Geoff
Russ Ellis
Posted: Tue 24 Oct, 2006 9:49 am Post subject: |
| Geoff Wood wrote: |
Geoff |
Perhaps... it would certainly look more academic. As long as everyone agrees on some set of definitions it would probably be all right. However at the moment obviously they do not.
Patrick Bunt
Posted: Tue 24 Oct, 2006 10:19 am Post subject: |
A little more info from the libretto:
--This is set in 19th century Algeria
--The notes refer to it as a "paulo"- Anyone know anything about this term?
So, if you wanted to be as specific as possible without being incorrect, would you just call it a "polearm"? The author I'm working with wants to call it a "halberd", but I know that's just silly.
Posted: Tue 24 Oct, 2006 10:36 am Post subject: |
Polearms study today seems to be where sword study was just before the Oakeshott revolution. As valuable as Waldman's work is, it really just gets us to the point of having a comprehensive primer. We don't yet have our Oakeshott, and it won't be Waldman. IIRC, he's in his 70s, so the current book is likely to be his major contribution to the field.
I favor an alphanumeric system for polearms, as it seems to work pretty well for swords. I think one key to success is to be comfortable with exceptions and open to ongoing reconsideration, as Oakeshott certainly was. To avoid confusion with Oakeshott's sword typology, I'd suggest using Arabic numbers, but otherwise I think his arrangement (number/letter) makes good sense.
1a, 1b, 1c, 1d, etc.
Waldman's categories seem pretty sound to me (the "Morgenstern Group" is a particularly elegant construction). I'd favor using his categories as the starting point for a typology, adjusting as needed.
So....who wants to take on this project? All you need is ten years, 500,000 frequent flyer miles, a library to die for and a particularly bad case of Obsessive Compulsive Disorder.
Anyone?
(cricket)
Posted: Tue 24 Oct, 2006 11:24 am Post subject: |
The price of the Waldman book is prohibitive to many people and the printing run seems rather small. As such, I think it's needed that somebody tackle the job of condensing the information relating to terminology and, perhaps, the beginnings of typology that are presented in the work. This would encourage people to seek the book to read more and learn of the details and other points discussed. I should perhaps take this as a sign that the readers of myArmoury.com would be well served with such a general overview of polearms.
Geoff Wood
Posted: Tue 24 Oct, 2006 12:05 pm Post subject: |
| Sean Flynt wrote: |
Anyone?
(cricket) |
Thanks for the post, and I loved the ending.
Geoff
Posted: Tue 24 Oct, 2006 12:14 pm Post subject: |
| Patrick Bunt wrote: | A little more info from the libretto:
So, if you wanted to be as specific as possible without being incorrect, would you just call it a "polearm"? The author I'm working with wants to call it a "halberd", but I know that's just silly. |
I think "polearm" is perfectly adequate in this or any other case in which the form isn't readily described.
