Forum Index > Historical Arms Talk > Bronze age dagger reproduction Reply to topic
Jeroen Zuiderwijk
PostPosted: Wed 27 Sep, 2006 1:38 am    Post subject: Bronze age dagger reproduction         Reply with quote
I'd like to show off one of my latest and most favourite reproductions. It's a reproduction of and Irish style bronze age dagger and scabbard. The dagger is from the period where the first daggers started to get sword lengths in Ireland and the UK (similar to this one, but stretched out greater lengths). So in that respect it belongs to the ancestors of swords in this region.
More information and photos can be found at SFI:
http://forums.swordforum.com/showthread.php?s=&threadid=72107
 Attachment: 97.88 KB
Geoff Wood
PostPosted: Wed 27 Sep, 2006 3:09 am    Post subject:         Reply with quote
Very nice! Do you have any pictures of the blade before hilt assembly?
Geoff
Jeroen Zuiderwijk
PostPosted: Wed 27 Sep, 2006 3:32 am    Post subject:         Reply with quote
Not of this one, but here is a photo of a blade from the same mould direct after casting:
http://1500bc.com/bronzeage/bronzes/grooved_d...2006_2.jpg
After casting, the feed, flash are removed and the blade is polished. The cutting edge is hardened by cold-working, and extra decorative lines are hammered in the first groove next to the midrib.
Geoff Wood
PostPosted: Wed 27 Sep, 2006 5:20 am    Post subject:         Reply with quote
Thanks Jeroen
Torsten F.H. Wilke
PostPosted: Wed 27 Sep, 2006 8:38 am    Post subject:         Reply with quote
Nice work, Jeroen. I was curious as to what historical methods would have been used to make such moulds. Was a lost wax type method used, or were both halves just chiseled/worked out to final shape? And also, how would that bronze have been obtained back then?
Patrick Kelly
PostPosted: Wed 27 Sep, 2006 10:41 am    Post subject:         Reply with quote
Thank you for the photo. I'm hugely intrigued by bronze age weapons and yours is a nice one.
Joe Fults
PostPosted: Wed 27 Sep, 2006 2:36 pm    Post subject:         Reply with quote
It certainly looks very interesting. Especially given that we see fewer bronze reproductions.
Steve Grisetti
Likes: 9 pages
Reading list: 28 books
PostPosted: Wed 27 Sep, 2006 4:59 pm    Post subject:         Reply with quote
Beautiful work, Jeroen. Your example inspires me to add another item to my "must do/have" list.
- Sir Toby Belch
Jeroen Zuiderwijk
PostPosted: Thu 28 Sep, 2006 12:24 am    Post subject:         Reply with quote
Torsten F.H. Wilke wrote:
Nice work, Jeroen.
Thanks!Happy
In case of these daggers, the moulds were made from stone such as soapstone. So they made two flat slabs of stone (the most difficult and time consuming part!), and then carved out the shape of the dagger in mould half. The mould of a nearly identical dagger has actually been found as well. Clay mould only survive from the middle bronze age onwards, and were usually two part (sometimes with core for socketed casts), sometimes with an outer wrapping. Lost wax was probably used in the bronze age, but rarely. Instead of wax, lead was used more often for investment casting (mostly during the late bronze age).
From copper and tin ores, which occur in mountainous areas, and were either mined, or dug from the surface. The tin ore is the most difficult to find, and only occurs in a few places in Europe. The smelting process is quite similar to iron smelting, though the main difference is that the metal does melt in the process, and you get a pure metal directly from the furnace. The copper and tin you melt together, and cast into the mould.
Shane Allee
PostPosted: Thu 28 Sep, 2006 6:06 am    Post subject:         Reply with quote
Great job Jeroen....
So what do you have plans for next?
If I hadn't just started a La Tene III kit this would probably have had me digging through the bronze age book section at Notre Dame.
Shane
Jeroen Zuiderwijk
PostPosted: Fri 29 Sep, 2006 2:12 am    Post subject:         Reply with quote
You'll find out if I have success Happy
Fabrice Cognot
PostPosted: Mon 02 Oct, 2006 12:04 am    Post subject:         Reply with quote
Nice work, Jeroen ! I know people here who'd be interested in seeing that Happy Just don't forget to bring it along next year Wink
In general, what are the proportions of the various metals in the alloy you make ?
PhD in medieval archeology.
HEMAC member
De Taille et d'Estoc director
Jeroen Zuiderwijk
PostPosted: Mon 02 Oct, 2006 10:36 am    Post subject:         Reply with quote
That won't be possible, as it was part of a trade for a reproduction of a bronze age costume (on which the dagger is displayed). However, I've got several extra blades, so I can make more daggers, but I'd probably use a different combination of hilt materials.
Generally I aim at 10-12% tin and the rest copper, unless I know the exact composition. But early bronze age pieces are usually mostly copper, and for pieces such as socketed axes I sometimes add a small %age of lead (very rarely, as I value my health!Happy ).
