Stanislav Prosek
Posted: Mon 02 Jan, 2006 12:37 pm Post subject: The pavise |
This is pavise by my friend. The pavise is made from wood and covered with leather with of both side.
Best regards Stanislav prosek
www.mac-armour.cz
Attachment: 53.28 KB
Attachment: 79.74 KB
Joe Fults
Posted: Mon 02 Jan, 2006 12:51 pm Post subject: |
Very neat.
What is the size?
Stanislav Prosek
Posted: Mon 02 Jan, 2006 1:14 pm Post subject: |
Joe Fults wrote: | Very neat.
What is the size? |
The size is 108 cm X 86 cm
St.
Russ Ellis
Posted: Mon 02 Jan, 2006 9:52 pm Post subject: |
Very impressive work, (same goes for the landsnecht helmet) I'm still trying to figure out, how did you bend the wood like that?
TRITONWORKS Custom Scabbards
Stanislav Prosek
Posted: Mon 02 Jan, 2006 11:44 pm Post subject: |
Russ Ellis wrote: | Very impressive work, (same goes for the landsnecht helmet) I'm still trying to figure out, how did you bend the wood like that? | The pavise is made form small plywood patch it up
in the presser from wood.
Russ Ellis
Posted: Tue 03 Jan, 2006 8:16 am Post subject: |
Stanislav Prosek wrote: | Russ Ellis wrote: | Very impressive work, (same goes for the landsnecht helmet) I'm still trying to figure out, how did you bend the wood like that? | The pavise is made form small plywood patch it up
in the presser from wood. |
Hmmm not completely understanding you... so it's thin plywood and it was pressed that way? Did you have to steam it or simply wet it? Did you do the artwork yourself as well? What does it say around the edges of the pavise?
Stanislav Prosek
Posted: Tue 03 Jan, 2006 2:36 pm Post subject: |
Russ Ellis wrote: | Stanislav Prosek wrote: | Russ Ellis wrote: | Very impressive work, (same goes for the landsnecht helmet) I'm still trying to figure out, how did you bend the wood like that? | The pavise is made form small plywood patch it up
Hmmm not completely understanding you... so it's thin plywood and it was pressed that way? Did you have to steam it or simply wet it? Did you do the artwork yourself as well? What does it say around the edges of the pavise? |
Hmmmm, I am apologize, my english language is horrible!
Yes, the thin plywood was pressed between the two moulds. The plywood is not steam and is not wet . the plywood are very thin.
My translate notice to english language ( I hope,you understand me
:o) : MOST HOLY BISHOP REJOICE, REJOICE WITH
Russ Ellis
Posted: Tue 03 Jan, 2006 8:40 pm Post subject: |
Not to worry Stanislav despite the fact that some of my ancestors came from your part of the world your English is FAR better then my Czech. I think I understand you now. :) Did you do the artwork on the pavise yourself as well? How did you get into (start doing) this sort of thing?
Bill Grandy
Posted: Tue 03 Jan, 2006 10:20 pm Post subject: |
Stanislav,
Your friend is quite the artist! Beautiful work. I could swear I've seen a similar medieval pavisse before... did he base it off an original piece?
HistoricalHandcrafts.com
Stanislav Prosek
Posted: Tue 03 Jan, 2006 11:12 pm Post subject: |
Bill Grandy wrote: | Stanislav,
Your friend is quite the artist! Beautiful work. I could swear I've seen a similar medieval pavisse before... did he base it off an original piece? |
Here is original pavise.
St.
Attachment: 48.98 KB
Russ Ellis
Posted: Wed 04 Jan, 2006 5:56 am Post subject: |
Nathan Robinson wrote: |
Russ, please note the first sentence in the first post in this topic: "This is pavise by my friend." |
Managed to miss that part. Thanks.
