Forum Index > Off-topic Talk > Albion's On-Line Articles Reply to topic
Aaron Schneiker
Reading list: 4 books
PostPosted: Thu 22 Dec, 2005 10:05 am    Post subject: Albion's On-Line Articles         Reply with quote
Hello everyone,
I was wondering if anyone knows if/when Albion's remaining on-line articles will be added to the site. Even though I've read through the others multiple times, I continue to find myself checking them out again. I would really like to see the information about heat treating and design and edge geometry that they can provide.
In reading through their articles I noted that they use a salt bath to heat treat their swords. Is there anyone who has experience with this that could tell me what it involves? I am looking for an alternitive to a coal or propane forge (I'd like something I could use in the house, WI winters aren't very conducive to working outdoors Worried ). Are the materials readily available, is it cost effective, would it be safe to use this process indoors? Any insight would be appreciated.
Thanks,
-Aaron
Aaron Schnatterly
Reading list: 67 books
PostPosted: Thu 22 Dec, 2005 10:22 am    Post subject: Re: Albion's On-Line Articles         Reply with quote
I've seen the process used - it's 2 salt baths, one high temp heated by burners, the other lower (still in the 400's F) heated by PLC-controlled heaters. I'm sure you could build such an arrangement, but for small items or single blades, this would be gross overkill. You might get away with something like this in the garage or an outside shop, but not in the spare bedroom for sure. How costly/cost-effective is this? Beats me... haven't looked that far into it... yet. Wink
Jesse Frank
PostPosted: Thu 22 Dec, 2005 11:18 am    Post subject:         Reply with quote
Also, most home use salt pots are propane fired, unless you want to use an electric kiln, which costs a whole lot to run.
If you are worried about safety considerations with building a gas forge, stay away from salt. And please, please, please DO NOT use them in an outdoor shop. Any moisture that comes in to contact with the molten salt will make an explosion, sending 1500f salt spraying in all directions. These are EXTREMELY dangerous tools. Think volcano. Most guys that use them will take a torch to the blade to burn off any moisture on it. That's how sensitive t is. It doesn't take much to have that volcano spraying 12 feet in the air.
Also, one of the ingredients in the low temp salt is potassium nitrate. Like they make bombs out of. Rapid oxidizer. Read :bOOm:
There are plenty of people working with these things, but you really have to be safety minded in the extreme to use them. Happy They are NOT for the beginner.
Danger, Will Robinson!
http://jfmetalsmith.com/
Jesse Frank
PostPosted: Thu 22 Dec, 2005 11:21 am    Post subject:         Reply with quote
Thinking further, if I were in your situation, I would make the blade and send it off the be heat treated. Solves lots of problems, and there might be someone near you that would be willing to help out Happy
Aaron Schneiker
PostPosted: Thu 22 Dec, 2005 12:04 pm    Post subject:         Reply with quote
Yeah, thinking about it a bit, I think that might be the best solution for now. I do hope to someday have an outdoor shop with the capabilities to forge and heat treat though Happy . I have a few connections through work for local heat treat facilities. I'm sure they would work with me for a specific heat treat process if I asked 'em. Just haven't had a chance to see how much that would cost? I've been too busy trying to figure out how to create and where to put a forge of my own Big Grin . Oh well, I guess I'll save the possibilities of a "volcano" to the more experienced...
Thanks for the advice,
-Aaron
Jason Dingledine
PostPosted: Thu 22 Dec, 2005 1:25 pm    Post subject: Re: Albion's On-Line Articles         Reply with quote
Hello everyone,
Thanks,
-Aaron
Sorry, that would be mostly my fault.
A few of the articles are waiting on me to write them, including the heat-treating article. With all that goes on in our shop, finding the time to take away from production to write is few and far between.
To reinforce the dangers of high-temp salts, even invisible moisture will set things off. The condensation expands 1000 times it's volume as it is super-heated, and there is absolutely no warning (no pop, sizzle, or fizz). I have a scar on my right arm from where LOW TEMP salt slashed up on me. That was only 500 degrees at the time.
Jason Dingledine
Jesse Frank
PostPosted: Thu 22 Dec, 2005 2:05 pm    Post subject:         Reply with quote
Yeah, it's scary stuff....
If you check out Don Fogg's forums, you will find a gargantuan amount of info on heat treating and the like, along with many knowledgeable smiths willing to help Happy
http://forums.dfoggknives.com/index.php?
You might find that it's not as difficult as you think to get set up... I started in an apartment with no more than a file, some sandpaper, a drill, and the willingness to screw up everything I tried Laughing Out Loud
Also, look into you local ABANA chapter, there are likely many smiths in your area willing to help Happy
PostPosted: Thu 22 Dec, 2005 8:48 pm    Post subject:         Reply with quote
Jason;
So juggling ice cubes over the salt is not recommended ? Razz Razz Razz
Hmmmmmm: I guess even sweathing to close to the salt baths would be something to worry about ! Eek!
Aaron Schnatterly
PostPosted: Fri 23 Dec, 2005 9:40 am    Post subject:         Reply with quote
Jean Thibodeau wrote:
Jason;
I sneezed in the direction of the salts while treating a blade up there... popped and cracked just on the couple of tiny droplets that settled on top of the bath. Rain or such would be downright dangerous.
Thanks, too, to Jesse and Jason for clarifying the subject a good deal. By "outside" work, by the way, I meant inside an unattached shop, not literally in the elements... should have been a lot clearer.
Steve Grisetti
Likes: 9 pages
Reading list: 28 books
PostPosted: Sat 24 Dec, 2005 2:05 pm    Post subject: Re: Albion's On-Line Articles         Reply with quote
Jason Dingledine wrote:
...I have a scar on my right arm from where LOW TEMP salt slashed up on me. That was only 500 degrees at the time.
"only 500 degrees", he says Eek! A few years ago, I studied up a little bit on temperatures of exposed surfaces in power plants. If I recall correctly, a surface at 170F or more will give you 3rd degree burns before you feel any burn at all.
- Sir Toby Belch
