Forum Index > Off-topic Talk > welding sheet metal Reply to topic
Ryan Brault
PostPosted: Sat 13 Aug, 2005 3:12 pm    Post subject: welding sheet metal         Quote
hi everybody,
I was wondering what kind of welder would be the right power to weld 18 ga. sheet steel but not just melt it.
ryan
"OH SWEET METAL CUTTING PARADISE, THY NAME BE BEVERLY"
Profile PM AIM
E.B. Erickson
PostPosted: Sat 13 Aug, 2005 6:39 pm    Post subject:         Quote
Hello Ryan,
Just about any type of equipment cab be used to weld sheet, but you'll have to set the machine on it's lowest settings, and practice on some scrap to see if you've got things (temperature and technique) right.
Back in the US, I had a MIG welder that I used for steel thinner than 18 guage, but it did take some practice.
Here in Thailand I've got your basic "buzz box", and I can do sheet that's about 1mm thick. There is,however, some bad language involved in this technique, and the ability to hold your mouth just right!
--ElJay
Profile PM Website
Ryan Brault
PostPosted: Sat 13 Aug, 2005 7:36 pm    Post subject:         Quote
thanks, i asked because i'm working on a breastplate that needs the bottom welded to get the right shape and i don't want to heat up more than i have to, to maintain the strength of work hardening.
thanks again,
ryan
Profile PM AIM
Mat Billings
PostPosted: Tue 16 Aug, 2005 1:23 pm    Post subject:         Quote
four words, "Pain in the ---". Your best bet would be to do it through a series of tack welds; you'll find a mig welder to be the easiest to do it with, but that isn't to say it may not be impossible to do through other methods. Try and move around a lot to keep the heat down, otherwise I garuntee you'll burn through. As long as you've got the machine set right, you shouldn't have too many issues; it is possible :D ;)
Profile PM YIM
Don Halter
PostPosted: Tue 16 Aug, 2005 2:49 pm    Post subject:         Quote
Find a friend with a TIG welder. I used to do 26 ga with a nice Lincoln TIG when I was welding every day on the job. If you have access to a stick welder....My personal machine is a stick welder (Miller thunderbolt 240). I can do 18 ga with 3/32", 7014 rod (shallow penetrating), DC- polarity and 70-75 A. Using an aluminum plate behind it as a heat sink helps also. You can use steel, but if you melt through, you just welded your object tot he heat sink! :eek: For some of the smaller stick welders, use a 1/16th" general purpose rod and about 60 A on a scrap piece and go from there. You'll still want to do several tack welds to keep the metal from pulling apart as you weld.
Don "Krag" Halter
Profile PM Website AIM
Ryan Brault
PostPosted: Tue 16 Aug, 2005 6:31 pm    Post subject:         Quote
thanks guys, this will definetly help.
ryan
Profile PM AIM
Russ Thomas
Reading list: 43 books
PostPosted: Fri 19 Aug, 2005 11:44 pm    Post subject:         Quote
Ryan,
I think that Don halter has definately hit the nail on the head here. TIG !
Welding thinner guages of steel is tricky at the best of times, personally , I use MIG most of the time, I am used to it, but Tig is wonderful stuff and you can weld really thin stuff with it. However, it gets extremely hot extremely quickly, so if you are not in practice with using it a big hole will very probably occur ! Gas , Oxy-acetylene I also use ,but after having discovered the delights of the TIG set up I do not think that I will use this anymore for welding armour, but it is great for a localised heat source for riveting up sword nuts etc.
The other beauty of Tig, is that like gas welding, it can be very heavilly hammered afterwards without fear of it cracking. I tried a piece and gave up before it cracked, and that was with me hammering carelessly and much more aggressively than I would ever have done for real. :wtf:
I make armour professionally, so for me I have to be able to use welding equipment, but for someone , possibly like yourself ( and forgive me if this is an erroneous assumtion ), that is only making the odd item, then I would find out someone with a TIG or gas set (that knows how to use it ! ), and ask them to weld it up for you.
But welding is fun to do and so handy to be able to do it yourself too. :)
Regards as ever,
Russ
Carpe diem, quam minimum credula postero !
http://www.living-history.no
Profile PM Website
