Forum Index > Historical Arms Talk > Opinions? Reply to topic
Taylor Ellis
PostPosted: Thu 30 Oct, 2003 10:52 pm    Post subject: Opinions?         Reply with quote
For those of you who are familiar with Xa.1 from Records, how do you think this design would would as a short longsword? I'm thinking of basically keeping it the same, except extending the tang and not hollowgrinding the blade. The wieght in the handle should balance increased weight of the blade. The blade length would stay at roughly 34 inches and I'm guessing the weight would go up to just over 3lbs. I'd also change the pommel to a octagonal scent stopper simply because I like those sort better. Handle would be a snakeskin or sharkskin style similar to the Edward III sword.
The smith I would comission is Kevin Cashen, so he'll no doubt know what will work and what won't but I just thought I'd get some general opinions by the fine blokes here. Happy
Russ Ellis
PostPosted: Fri 31 Oct, 2003 8:05 am    Post subject:         Reply with quote
I think having it as a shorter longsword you would have a very interesting item on your hands, however doing away with the hollow grinding I think does away with a lot of what IS this sword. One of the most unique features about it to my mind is the cross section introduced by the combination of the deep fuller and the hollow grinding. However as a nice sword I think it would be fine although very far removed from its parent it seems. Happy
TRITONWORKS Custom Scabbards
Taylor Ellis
PostPosted: Mon 03 Nov, 2003 6:58 pm    Post subject:         Reply with quote
For sure mate, but with the long fuller and blade shape that is unusual for a longsword it would be a fairly unique piece. I also really like the hexagonal section at the end of the sword too. It should be interesting anyway. Happy
Russ Ellis
PostPosted: Mon 03 Nov, 2003 8:21 pm    Post subject:         Reply with quote
Oh absolutely... I think it will be very interesting indeed and look forward to seeing the completed piece. Now what is this you are saying about a hexagonal cross section at the bottom... hmmm I need to go back and look at that book again....
Taylor Ellis
PostPosted: Mon 03 Nov, 2003 9:32 pm    Post subject:         Reply with quote
The blade goes from hollowground diamond section then to hexagonal section just as the fuller ends.
Russ Ellis
PostPosted: Tue 04 Nov, 2003 6:03 am    Post subject:         Reply with quote
Yikes! You are right! Now I've got to do some rethinking... Happy
Taylor Ellis
PostPosted: Tue 04 Nov, 2003 8:13 pm    Post subject:         Reply with quote
This is what I think I'm after. Add in some sort of inlayed script down the fuller and a sharkskin handle wrap (probably dyed green probably) maybe with gilded silver mounts (or just polished steel?) and a mirror finish on the blade.
 Attachment: 39.01 KB
Russ Ellis
PostPosted: Tue 04 Nov, 2003 8:36 pm    Post subject:         Reply with quote
Not to shabby at all...
Joe Fults
PostPosted: Wed 05 Nov, 2003 3:12 pm    Post subject:         Reply with quote
I think once the mechanics are worked out, it will look very nice.
Taylor Ellis
PostPosted: Thu 06 Nov, 2003 7:12 pm    Post subject:         Reply with quote
I think you are right Joe. In any case, it'll be different from the norm, especially with a gold inlay. Happy
Russ Ellis
PostPosted: Sun 09 Nov, 2003 6:37 pm    Post subject:         Reply with quote
Hey Taylor, where did you find that bit about the hexagonal cross section?
Taylor Ellis
PostPosted: Sun 09 Nov, 2003 9:43 pm    Post subject:         Reply with quote
I think it was from Records, or maybe from Bjorn's site?
