Forum Index > Makers and Manufacturers Talk > Messer build by Tods Workshop Reply to topic
Leo Todeschini
(3 total ▮ 100% positive)
PostPosted: Wed 04 Jul, 2018 1:24 pm    Post subject: Messer build by Tods Workshop         Quote
Hi All,
I have just finished this piece for a client and it has a couple of interesting features.
The messer is styled after late 15thC pieces and has a very broad blade, starting at 6mm thick at the hilt and dropping down to around 2mm near the tip and then it thickens out into a reinforced point around 4mm thick.
The handle scales are in bone with a central fuller, making its way back through the grip and is pinned with hollow steel rivets.
The scabbard has to be a little thicker than I would like all the way down as it needs clearance for the reinforced tip, but otherwise is made from poplar and covered in veg tan leather. A 'problem' that messer scabbards have is that the curve requires the the scabbard to be a little broader at the throat than the blade, so it rattles a little and this is generally unavoidable. The customer wanted a scabbard without this looseness, so suggested a rounded rain flap with a cut out for the nagel; it works well.
Blade length 63cm/25"
Blade width at hilt 52mm/2"
overall weight 1000g/2.2lbs
I hope you like it and any questions or comments, please fire away.
 Attachment: 138.64 KB
 Attachment: 165.8 KB
 Attachment: 163.43 KB
 Attachment: 135.67 KB
 Attachment: 187.22 KB
 Attachment: 144.04 KB
 Attachment: 141.16 KB
www.todsworkshop.com
www.todcutler.com
Profile PM Website
Preben B
PostPosted: Wed 04 Jul, 2018 1:28 pm    Post subject:         Quote
That would make a mess alright.
Stunning work as usual
Gregg Sobocinski
PostPosted: Thu 05 Jul, 2018 3:10 pm    Post subject:         Quote
That’s a fantastic piece, and I think the clip and curve of the blade are very aesthetically pleasing to my eye. That is surprisingly not easy to do. This may be my favorite looking messer ever!
I see a lot of metal on the “pommel area” of the hilt. Is this more than you would normally use? Does it give it more balance, or is it the chopper I imagine it to be?
M. Adair Orr
PostPosted: Fri 06 Jul, 2018 10:45 am    Post subject:         Quote
That is lovely. The nagel lapping onto the scales of the hilt is a great detail. Top notch.
-Adair
Leo Todeschini
PostPosted: Mon 09 Jul, 2018 10:18 am    Post subject:         Quote
Thanks guys - I appreciate it.
Hi Gregg, it is a little longer than I usually do, but a bit thinner and with the fuller it is much the same; but yes a chopper.
www.todcutler.com
Profile PM Website
Steven Lussenburg
PostPosted: Mon 09 Jul, 2018 1:35 pm    Post subject:         Quote
That's pretty much the perfect, messer, Tod!
Adam Bodorics
PostPosted: Tue 10 Jul, 2018 2:10 am    Post subject:         Quote
It is lovely and that rain flap is very smart.
Quick question if you don't mind - do you have any period source for the reinforced tip? I do about the same with some frequency since I saw it on a few sabers and it made perfect sense to reinforce an otherwise vulnerable part of such a blade, but I haven't spotted it on any original Messers so far.
J. Hargis
Likes: 22 pages
PostPosted: Tue 10 Jul, 2018 3:26 pm    Post subject:         Quote
Leo:
Bless you my son.
IOW: Damn, that's nice!
Jon
Leo Todeschini
PostPosted: Tue 10 Jul, 2018 11:21 pm    Post subject:         Quote
Thanks Guys.
Hi Adam,
Nor have I, but it is nice!
The story is.......
I made a similar one a couple of years ago. Matt Easton at Schola Gladiatoria reviewed it and noted that it should have a reinforced point for his tastes. The client for this piece requested a reinforced point and here we are.
www.todcutler.com
Profile PM Website
