Forum Index > Makers and Manufacturers Talk > Reground CS 1796 light cavalry sabre Reply to topic
Lukas MG
PostPosted: Sun 31 Dec, 2017 8:26 am    Post subject: Reground CS 1796 light cavalry sabre         Reply with quote
So, just finished a last project for 2017. This CS British 1796 sabre was reground to be more in line with the originals. Unlike most modern reproductions that are way too thin, this piece actually came with a decent base thickness of 7mm so it could be given a fitting concave distal taper down to just over 1mm at the tip. Without going for an original or a very high end custom, this is now as close as you'll get to "the real thing".
After final grinding, the blade was given a fine satin polish and sharpened to a shaving sharp edge. Should be a ferocious cutter...
I hope the owner will be pleased with this modification.
Happy New Year!
Custom sword maker:
http://www.lukasmaestlegoer.com
Lance Morris
PostPosted: Fri 05 Jan, 2018 10:05 pm    Post subject: That’s sexy         Reply with quote
That’s sexy!
Good work
B. Stark
PostPosted: Wed 01 Aug, 2018 12:11 pm    Post subject:         Reply with quote
Did you dismount the blade from the hilt?
"Wyrd bi∂ ful aræd"
